    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      sdetweil @Manu85
      @Manu85 yes
        Manu85 @sdetweil
        @sdetweil ok, I do it you are too strong
          Manu85 @sdetweil
          @sdetweil for calendar I got this return and the cursor did not return to cd ~/MagicMirror/ I just have two points at the bottom of the file
          pi@MagicMirror:~/MagicMirror $ git diff modules/default/calendar/calendar.js
          diff --git a/modules/default/calendar/calendar.js b/modules/default/calendar/cal        endar.js
          index 2ef9ca9c..4f70a1e9 100644
          --- a/modules/default/calendar/calendar.js
          +++ b/modules/default/calendar/calendar.js
          @@ -1,6 +1,6 @@
           /* global cloneObject */
          -/* MagicMirror²
          +/* Magic Mirror
            * Module: Calendar
            * By Michael Teeuw https://michaelteeuw.nl
          @@ -11,11 +11,8 @@ Module.register("calendar", {
                  defaults: {
                          maximumEntries: 10, // Total Maximum Entries
                          maximumNumberOfDays: 365,
          -               limitDays: 0, // Limit the number of days shown, 0 = no limit
          -               pastDaysCount: 0,
                          displaySymbol: true,
          -               defaultSymbol: "calendar-alt", // Fontawesome Symbol see https:/        /fontawesome.com/cheatsheet?from=io
          -               defaultSymbolClassName: "fas fa-fw fa-",
          :...skipping...
          diff --git a/modules/default/calendar/calendar.js b/modules/default/calendar/calendar.js
          @@ -1,6 +1,6 @@
          -/* MagicMirror²
          +/* Magic Mirror
            * Module: Calendar
                  defaults: {
          -               pastDaysCount: 0,
          -               defaultSymbol: "calendar-alt", // Fontawesome Symbol see https://fontawesome.com/cheatsheet?from=io
          +               defaultSymbol: "calendar", // Fontawesome Symbol see https://fontawesome.com/cheatsheet?from=io
                          showLocation: false,
                          displayRepeatingCountTitle: false,
                          defaultRepeatingCountTitle: "",
          @@ -27,25 +24,23 @@ Module.register("calendar", {
                          maxEventTitleLines: 3,
                          fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                          animationSpeed: 2000,
          -               fade: true,
          +               fade: false,
                          urgency: 7,
          -               timeFormat: "relative",
          -               dateFormat: "MMM Do",
          +               timeFormat: "absolute",
          +               dateFormat: "Do MMM HH:mm",
                          dateEndFormat: "LT",
          -               fullDayEventDateFormat: "MMM Do",
          +               fullDayEventDateFormat: "Do MMM",
                          showEnd: false,
                          getRelative: 6,
                          fadePoint: 0.25, // Start on 1/4th of the list.
                          hidePrivate: false,
                          hideOngoing: false,
          -               hideTime: false,
          -               showTimeToday: false,
                          colored: false,
          -               customEvents: [], // Array of {keyword: "", symbol: "", color: ""} where Keyword is a regexp and symbol/color are to be applied for matched
          +               coloredSymbolOnly: false,
                          tableClass: "small",
          -                               symbol: "calendar-alt",
          +                               symbol: "calendar",
                                          url: "https://www.calendarlabs.com/templates/ical/US-Holidays.ics"
          @@ -60,18 +55,9 @@ Module.register("calendar", {
                          excludedEvents: [],
                          sliceMultiDayEvents: false,
                          broadcastPastEvents: false,
          -               nextDaysRelative: false,
            sdetweil @Manu85
            @Manu85 all of those changes need to go in config.js
            (ps, THIS is why you don’t change our files… )
            and THIS is why test mode… so you have a chance to save your stuff.
            and AFTER these changes are in config.js , and custom.css
            AND you tested,
            THEN u restore the original file
            and TEST AGAIN… to make sure everything is right.
            THEN you can upgrade… and these files will all have been restored
            and won’t show in the changed list (I would run test mode over and over til these problems go away)
              Manu85 @sdetweil
              @sdetweil yes, now thanks to you I understand the importance of js and css files
                Manu85 @sdetweil
                @sdetweil So I have to make the corrections manually in the files concerned by replacing the red lines with green lines, is that it?
                  sdetweil @Manu85
                  @Manu85 you don’t have to correct the files… , just move the changes (green) to config.js and custom.css
                  to restore a file to its release level content do
                  ~/MagicMirror
                  git checkout full_path_and_filename
                  example
                  git checkout css/main.css
                  this will restore the file from the local (hidden) source repository
                  dont do this til you have at least tested once for each file changed…
                  and you MAY want to copy the affected file to a saved version (add .save to its filename)
                  in case you missed one of the changes after you restore the file…
                  M 3 Replies Last reply Reply Quote 0
                    Manu85 @sdetweil
                    @sdetweil I’m trying to understand and I’m having a lot of trouble, in the following example, I haven’t touched anything (I’m almost sure) and I have two lines, the first in red and the second in Green:
                    -/* MagicMirror²
                    +/* Magic Mirror
                    I can’t put the green line in my js.config file, right?
                    I’m sorry but I’m trying to understand
                    @@ -1,6 +1,6 @@
                    -/* MagicMirror²
                    +/* Magic Mirror
                      * Module: Calendar
                      Manu85 @sdetweil
                      @sdetweil another example that bothers me
                        Manu85 @sdetweil
                        @sdetweil one last one for which I don’t know what to do either, thank you again for your help
                          sdetweil @Manu85
                          @Manu85 not the -lock.json files , these are generated by npm install
                          the MagicMirror thing is inside a comment, so not important.
                          the default symbol, the green goes in config.js for the calendar module. don’t worry about the red
                            Manu85 @sdetweil
                            @sdetweil ok, thank you for your answers, I’m going to do the weather.js and according to what you tell me I’m going to leave aside the 2 lock.json and then I’ll stop for this evening my brain is upside down , have a good day…and see you tomorrow if you want to continue helping me
                              Manu85 @sdetweil
                              @sdetweil I’m still here, I made the modifications in css main and js.config I placed the command:
                              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                              here is what I have
                              pi@MagicMirror:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                              Minimum Node version: v18.18.0
                              Installed Node version: v14.21.3
                              Node should be upgraded.
                              pi@MagicMirror:~ $
                                sdetweil @Manu85
                                @Manu85 well…let me check when I get home. maybe 30 mins from now 1800 my time US central
                                  sdetweil @Manu85
                                  @Manu85 fixed, run again
                                    Manu85 @sdetweil
                                    @sdetweil hello, I rebotted the pi and ran the command again
                                    and I have the impression that it remains stuck in the same place the cursor does not display:
                                    pi@MagicMirror:~ $
                                      sdetweil @Manu85
                                      @Manu85 can you post the last part of
                                      ~/MagicMirror/installers/upgrade.log
                                      from the last
                                      "upgrade started"
                                        Manu85 @sdetweil
                                        @sdetweil ```
                                        pi@MagicMirror:~ $ ~/MagicMirror/installers/upgrade.log
                                        -bash: /home/pi/MagicMirror/installers/upgrade.log: Permission non accord▒e
                                        pi@MagicMirror:~ $
                                          sdetweil @Manu85
                                          @Manu85 no. not execute . open and look at
                                          copy last few lines here
                                            Manu85 @sdetweil
                                            @sdetweil I copied everything, if necessary
                                            Upgrade started - mer. janv. 24 17:51:10 CET 2024
                                            system is Linux MagicMirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
                                            the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                                            n (node version manager tool) not installed, doing test run, install skipped
                                            Node.js upgrade defered, doing test run
                                            Minimum npm version: V9.8.1
                                            Installed npm version: V6.14.18
                                            npm should be upgraded.
                                            npm upgrade defered, doing test run  ...
                                            saving custom.css
                                            remote name = origin
                                            upgrading from version 2.23.0 to 2.26.0
                                            fetching latest revisions
                                            git fetch rc=0
                                            current branch = master
                                            On branch master
                                            Your branch is behind 'origin/master' by 213 commits, and can be fast-forwarded.
                                              (use "git pull" to update your local branch)
                                              (use "git add <file>..." to update what will be committed)
                                              (use "git checkout -- <file>..." to discard changes in working directory)
                                            	modified:   css/main.css
                                            	modified:   fonts/package-lock.json
                                            	modified:   modules/default/calendar/calendar.js
                                            	modified:   modules/default/weather/weather.js
                                            	modified:   package-lock.json
                                            	modified:   vendor/package-lock.json
                                            Untracked files:
                                              (use "git add <file>..." to include in what will be committed)
                                            	core
                                            	css/icons/
                                            	css/save_custom.css
                                            	modules/default/currentweather/
                                            	nohup.out
                                            no changes added to commit (use "git add" and/or "git commit -a")
                                            there are 6 local files that are different than the master repo
                                               css/main.css
                                               package-lock.json
                                            save/restore files selection = n
                                            restoring css/main.css from repo
                                            skipping restore for css/main.css, doing test run
                                            restoring fonts/package-lock.json from repo
                                            skipping restore for fonts/package-lock.json, doing test run
                                            restoring modules/default/calendar/calendar.js from repo
                                            skipping restore for modules/default/calendar/calendar.js, doing test run
                                            restoring modules/default/weather/weather.js from repo
                                            skipping restore for modules/default/weather/weather.js, doing test run
                                            restoring package-lock.json from repo
                                            skipping restore for package-lock.json, doing test run
                                            restoring vendor/package-lock.json from repo
                                            skipping restore for vendor/package-lock.json, doing test run
                                            test merge result rc='' , if empty, no conflicts
                                            skipping merge, only test run
                                            downloading dumpactivemodules script
                                            updating dependencies for active modules with package.json files
                                            	processing for module MMM-OneCallWeather please wait
                                            	skipped processing for MMM-OneCallWeather, doing test run
                                            	processing complete for module MMM-OneCallWeather
                                            	processing for module MMM-SmartWebDisplay please wait
                                            	skipped processing for MMM-SmartWebDisplay, doing test run
                                            	processing complete for module MMM-SmartWebDisplay
                                            	processing for module MMM-ISS-Live please wait
                                            	skipped processing for MMM-ISS-Live, doing test run
                                            	processing complete for module MMM-ISS-Live
                                            restoring custom.css
                                            removing git alias
                                            Upgrade ended - mer. janv. 24 18:06:38 CET 2024
                                            Upgrade started - mer. janv. 24 20:51:08 CET 2024
                                            Upgrade started - mer. janv. 24 21:02:28 CET 2024
                                            Upgrade started - mer. janv. 24 21:26:35 CET 2024
                                            Upgrade started - mer. janv. 24 21:31:01 CET 2024
                                            Upgrade started - jeu. janv. 25 08:56:35 CET 2024
                                            Upgrade started - jeu. janv. 25 09:02:37 CET 2024
                                            Upgrade started - jeu. janv. 25 10:04:34 CET 2024
                                            A npm process is currently running. Can't upgrade.
                                            Please quit all npm processes and restart the installer.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
