    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      sdetweil @Manu85
      @Manu85 you don’t have to correct the files… , just move the changes (green) to config.js and custom.css
      to restore a file to its release level content do
      ~/MagicMirror
      git checkout full_path_and_filename
      example
      git checkout css/main.css
      this will restore the file from the local (hidden) source repository
      dont do this til you have at least tested once for each file changed…
      and you MAY want to copy the affected file to a saved version (add .save to its filename)
      in case you missed one of the changes after you restore the file…
      M 3 Replies Last reply Reply Quote 0
        Manu85 @sdetweil
        @sdetweil I’m trying to understand and I’m having a lot of trouble, in the following example, I haven’t touched anything (I’m almost sure) and I have two lines, the first in red and the second in Green:
        -/* MagicMirror²
        +/* Magic Mirror
        I can’t put the green line in my js.config file, right?
        I’m sorry but I’m trying to understand
        diff --git a/modules/default/calendar/calendar.js b/modules/default/calendar/cal        endar.js
        index 2ef9ca9c..4f70a1e9 100644
        --- a/modules/default/calendar/calendar.js
        +++ b/modules/default/calendar/calendar.js
        @@ -1,6 +1,6 @@
         /* global cloneObject */
        -/* MagicMirror²
        +/* Magic Mirror
          * Module: Calendar
          Manu85 @sdetweil
          @sdetweil another example that bothers me
            Manu85 @sdetweil
            @sdetweil one last one for which I don’t know what to do either, thank you again for your help
              sdetweil @Manu85
              @Manu85 not the -lock.json files , these are generated by npm install
              the MagicMirror thing is inside a comment, so not important.
              the default symbol, the green goes in config.js for the calendar module. don’t worry about the red
                Manu85 @sdetweil
                @sdetweil ok, thank you for your answers, I’m going to do the weather.js and according to what you tell me I’m going to leave aside the 2 lock.json and then I’ll stop for this evening my brain is upside down , have a good day…and see you tomorrow if you want to continue helping me
                  Manu85 @sdetweil
                  @sdetweil I’m still here, I made the modifications in css main and js.config I placed the command:
                  bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                  here is what I have
                  pi@MagicMirror:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                  Minimum Node version: v18.18.0
                  Installed Node version: v14.21.3
                  Node should be upgraded.
                  pi@MagicMirror:~ $
                    sdetweil @Manu85
                    @Manu85 well…let me check when I get home. maybe 30 mins from now 1800 my time US central
                      sdetweil @Manu85
                      @Manu85 fixed, run again
                        Manu85 @sdetweil
                        @sdetweil hello, I rebotted the pi and ran the command again
                        and I have the impression that it remains stuck in the same place the cursor does not display:
                        pi@MagicMirror:~ $
                          sdetweil @Manu85
                          @Manu85 can you post the last part of
                          ~/MagicMirror/installers/upgrade.log
                          from the last
                          "upgrade started"
                            Manu85 @sdetweil
                            @sdetweil ```
                            pi@MagicMirror:~ $ ~/MagicMirror/installers/upgrade.log
                            -bash: /home/pi/MagicMirror/installers/upgrade.log: Permission non accord▒e
                            pi@MagicMirror:~ $
                              sdetweil @Manu85
                              @Manu85 no. not execute . open and look at
                              copy last few lines here
                                Manu85 @sdetweil
                                @sdetweil I copied everything, if necessary
                                Upgrade started - mer. janv. 24 17:51:10 CET 2024
                                system is Linux MagicMirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
                                the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                                n (node version manager tool) not installed, doing test run, install skipped
                                Node.js upgrade defered, doing test run
                                Minimum npm version: V9.8.1
                                Installed npm version: V6.14.18
                                npm should be upgraded.
                                npm upgrade defered, doing test run  ...
                                saving custom.css
                                remote name = origin
                                upgrading from version 2.23.0 to 2.26.0
                                fetching latest revisions
                                git fetch rc=0
                                current branch = master
                                On branch master
                                Your branch is behind 'origin/master' by 213 commits, and can be fast-forwarded.
                                  (use "git pull" to update your local branch)
                                  (use "git add <file>..." to update what will be committed)
                                  (use "git checkout -- <file>..." to discard changes in working directory)
                                	modified:   css/main.css
                                	modified:   fonts/package-lock.json
                                	modified:   modules/default/calendar/calendar.js
                                	modified:   modules/default/weather/weather.js
                                	modified:   package-lock.json
                                	modified:   vendor/package-lock.json
                                Untracked files:
                                  (use "git add <file>..." to include in what will be committed)
                                	core
                                	css/icons/
                                	css/save_custom.css
                                	modules/default/currentweather/
                                	nohup.out
                                no changes added to commit (use "git add" and/or "git commit -a")
                                there are 6 local files that are different than the master repo
                                   css/main.css
                                   package-lock.json
                                save/restore files selection = n
                                restoring css/main.css from repo
                                skipping restore for css/main.css, doing test run
                                restoring fonts/package-lock.json from repo
                                skipping restore for fonts/package-lock.json, doing test run
                                restoring modules/default/calendar/calendar.js from repo
                                skipping restore for modules/default/calendar/calendar.js, doing test run
                                restoring modules/default/weather/weather.js from repo
                                skipping restore for modules/default/weather/weather.js, doing test run
                                restoring package-lock.json from repo
                                skipping restore for package-lock.json, doing test run
                                restoring vendor/package-lock.json from repo
                                skipping restore for vendor/package-lock.json, doing test run
                                test merge result rc='' , if empty, no conflicts
                                skipping merge, only test run
                                downloading dumpactivemodules script
                                updating dependencies for active modules with package.json files
                                	processing for module MMM-OneCallWeather please wait
                                	skipped processing for MMM-OneCallWeather, doing test run
                                	processing complete for module MMM-OneCallWeather
                                	processing for module MMM-SmartWebDisplay please wait
                                	skipped processing for MMM-SmartWebDisplay, doing test run
                                	processing complete for module MMM-SmartWebDisplay
                                	processing for module MMM-ISS-Live please wait
                                	skipped processing for MMM-ISS-Live, doing test run
                                	processing complete for module MMM-ISS-Live
                                restoring custom.css
                                removing git alias
                                Upgrade ended - mer. janv. 24 18:06:38 CET 2024
                                Upgrade started - mer. janv. 24 20:51:08 CET 2024
                                Upgrade started - mer. janv. 24 21:02:28 CET 2024
                                Upgrade started - mer. janv. 24 21:26:35 CET 2024
                                Upgrade started - mer. janv. 24 21:31:01 CET 2024
                                Upgrade started - jeu. janv. 25 08:56:35 CET 2024
                                Upgrade started - jeu. janv. 25 09:02:37 CET 2024
                                Upgrade started - jeu. janv. 25 10:04:34 CET 2024
                                A npm process is currently running. Can't upgrade.
                                Please quit all npm processes and restart the installer.
                                  sdetweil @Manu85
                                  @Manu85 you have your MagicMirror running from
                                  npm start
                                  right?
                                  you need to stop it, ctrl-c in that terminal window
                                  also show output of
                                  pm2 status
                                    sdetweil @Manu85
                                    @Manu85 I added a couple more fixes to the pm2 stop…
                                    tested here… give it a try again…
                                    I am busy most of the day… will try to check in when I can
                                    traveling tomorrow
                                    M M 3 Replies Last reply Reply Quote 0
                                      Manu85 @sdetweil
                                      @sdetweil sorry but I didn’t understand what to do, my MM is running, I don’t know if it’s running from
                                      npm start
                                      you say (you need to stop it, ctrl-c in that terminal window) in which terminal? do you have to press the “ctrl-c” keys on the keyboard? sorry for my stupid questions
                                        manu85340 @sdetweil
                                        @sdetweil I hadn’t seen your message… it’s not urgent and everyone has their own jobs, you’ll answer me when you can, have a good trip
                                          Manu85 @sdetweil
                                          @sdetweil after a night’s sleep I think I understood…
                                            Manu85 @sdetweil
                                            @sdetweil following my last message I did:
                                            pm2 stop all
                                            and then I made your script:
                                            then I went to the folder:
                                            and I copied the last lines of:
                                            "upgrade started"
                                            I don’t know if I did the right thing but I took the history of what you asked me to do
                                            Upgrade started - ven. janv. 26 13:36:00 CET 2024
                                            saving custom.css
                                            git fetch rc=0
                                            On branch master
                                            Untracked files:
                                            	core
                                            	css/icons/
                                            	css/save_custom.css
                                            	howEnd: false,
                                            	liceMultiDayEvents: false,
                                            	nohup.out
                                            	tDaysCount: 0,
                                            	"ter(\"calendar\", {mberOfDays: 365,"
                                               css/main.css
                                               package-lock.json
                                            removing git alias
                                            Upgrade ended - ven. janv. 26 13:36:17 CET 2024
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
