    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil following my last message I did:
      pm2 stop all
      and then I made your script:
      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
      then I went to the folder:
      ~/MagicMirror/installers/upgrade.log
      and I copied the last lines of:
      "upgrade started"
      I don’t know if I did the right thing but I took the history of what you asked me to do
      Upgrade started - ven. janv. 26 13:36:00 CET 2024
      system is Linux MagicMirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
      n (node version manager tool) not installed, doing test run, install skipped
      Minimum Node version: v18.18.0
      Installed Node version: v14.21.3
      Node should be upgraded.
      Node.js upgrade defered, doing test run
      Minimum npm version: V9.8.1
      Installed npm version: V6.14.18
      npm should be upgraded.
      npm upgrade defered, doing test run  ...
      saving custom.css
      remote name = origin
      upgrading from version 2.23.0 to 2.26.0
      fetching latest revisions
      git fetch rc=0
      current branch = master
      On branch master
      Your branch is behind 'origin/master' by 213 commits, and can be fast-forwarded.
        (use "git pull" to update your local branch)
        (use "git add <file>..." to update what will be committed)
        (use "git checkout -- <file>..." to discard changes in working directory)
      	modified:   css/main.css
      	modified:   fonts/package-lock.json
      	modified:   modules/default/calendar/calendar.js
      	modified:   modules/default/weather/weather.js
      	modified:   package-lock.json
      	modified:   vendor/package-lock.json
      Untracked files:
        (use "git add <file>..." to include in what will be committed)
      	core
      	css/icons/
      	css/save_custom.css
      	howEnd: false,
      	liceMultiDayEvents: false,
      	modules/default/currentweather/
      	nohup.out
      	tDaysCount: 0,
      	"ter(\"calendar\", {mberOfDays: 365,"
      no changes added to commit (use "git add" and/or "git commit -a")
      there are 6 local files that are different than the master repo
         css/main.css
         package-lock.json
      save/restore files selection = n
      restoring css/main.css from repo
      skipping restore for css/main.css, doing test run
      restoring fonts/package-lock.json from repo
      skipping restore for fonts/package-lock.json, doing test run
      restoring modules/default/calendar/calendar.js from repo
      skipping restore for modules/default/calendar/calendar.js, doing test run
      restoring modules/default/weather/weather.js from repo
      skipping restore for modules/default/weather/weather.js, doing test run
      restoring package-lock.json from repo
      skipping restore for package-lock.json, doing test run
      restoring vendor/package-lock.json from repo
      skipping restore for vendor/package-lock.json, doing test run
      test merge result rc='' , if empty, no conflicts
      skipping merge, only test run
      downloading dumpactivemodules script
      updating dependencies for active modules with package.json files
      	processing for module MMM-SmartWebDisplay please wait
      	skipped processing for MMM-SmartWebDisplay, doing test run
      	processing complete for module MMM-SmartWebDisplay
      	processing for module MMM-ISS-Live please wait
      	skipped processing for MMM-ISS-Live, doing test run
      	processing complete for module MMM-ISS-Live
      restoring custom.css
      removing git alias
      Upgrade ended - ven. janv. 26 13:36:17 CET 2024
        sdetweil @Manu85
        @Manu85 but that is test mode, no changes.
        and the changed mm files are still there
        main.css…
        I thought u restored the originals as you migrated the changes…
          sdetweil @Manu85
          @Manu85 as I will be in the car all day,
          make sure to stop mm before running the upgrade
          pm2 stop all
          I added code a few changes ago to detect and stop mm, but it appears not to be working for you
            Manu85 @sdetweil
            @sdetweil Thank you for your answer if I understand correctly for safety I do
            pm2 stop all
            pi@MagicMirror:~/MagicMirror $ pm2 stop all
            after that
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
            that’s it ? and should I pass this line to the root of the MM or in the MM folder
            pi@MagicMirror:~$
            Or
            I’m waiting for your response before making a mistake
              sdetweil @Manu85
              @Manu85 the current directory does not matter,
              the script goes to it on its own
              M 3 Replies Last reply Reply Quote 0
                Manu85 @sdetweil
                @sdetweil ok, I’ll try it, I’ll let you know if everything went well…
                  Manu85 @sdetweil
                  @sdetweil I ran your update script, I don’t get an error message, are there any additional operations or do I reboot the pi?
                    Manu85 @sdetweil
                    @sdetweil hello, I did a reboot of the pi and… it restarted magic (like the mirror :-)) I have some small settings for which I cannot find solutions
                    For Weather:
                    the 1st: it’s the temperature which displays more than 280° C, I know that there is global warming but still…
                    the 2nd: the display of the weather forecast for the following days is a little confusing and I can’t find the settings in the console ctrl+shift+i and do you think I can write the sentence “Feels Like” in French?
                    for calendar:
                    I had put icons for each calendar in config.js, 1 for mine, 1 for my wife etc. ex: {
                    symbol: 'male',
                    url: 'webcal://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12OfzlWCbJPUrEhN49IHC1yeFEfqRieBnpxxxxxxxxxxxxx'
                    symbol: 'birthday-cake',
                    url: 'webcal://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWxxxxxxxxxxx'
                    in the custom css I had added color to each symbol to differentiate them (I saw that it was necessary to change .fa.fa in the custom css to .fas.fa) ex:
                    .fas.fa-male {
                       color: #2B60DE; /* Dodger Blue */
                    .fas.fa-birthday-cake {
                       color: #ff0000; /* Red */
                    .fas.fa-trash-o {
                       color: #00FF00; /* Green */
                    they all work except this one
                    symbol: 'trash-o',
                    for this one I don’t have any symbol
                      sdetweil @Manu85
                      @Manu85 trash-o is just fa.
                      you have .fas.fa
                      which means MUST HAVE BOTH on the same element
                      add a space
                      but also maybe take .fas off
                        sdetweil @Manu85
                        @Manu85 you just restart mm…(pm2 restart MagicMirror)
                        any how, on the weather
                        I think you have a conflict on how the API reports and what the module thinks it is
                        I think the API is reporting in Fahrenheit, but the code thinks in Celsius
                        see config options
                          sdetweil @Manu85
                          @Manu85 of, feels like…
                          see the translations/fr.json
                          its precip
                          percent possibility of precipitation, (rain.snow)
                          chance of rain or snow
                          some languages don’t have a term for that
                          I think you could change it to blank " "
                          but , then this will be a file to watch out for on future upgrades
                            Manu85 @sdetweil
                            @sdetweil ok, thank you for this information, I will try to resolve one by one, to
                            symbol: 'trash-o',
                            I tried all your suggestions and I still have the same result, what is strange is that for the other icons ex:
                            I do have a birthday cake
                              sdetweil @Manu85
                              @Manu85 see this post where someone needed a custom css class setting
                              https://forum.magicmirror.builders/post/114837
                              and your custom.css would have been
                              .calendar .fa-trash-o {
                              right?
                                Manu85 @sdetweil
                                @sdetweil I just did like that but still nothing I have the impression that the symbol in my js.config is not known
                                symbol: 'trash-o',
                                url: 'webcal://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12xxxxxxxxxxxxxxxxxx'
                                and all other symbols are ok
                                  sdetweil @Manu85
                                  @Manu85 use
                                   "fa-trash-o"
                                    Manu85 @sdetweil
                                    @sdetweil does not work
                                      sdetweil @Manu85
                                      @Manu85 in the developers window what do you see in the html and console tab view , 401, 404
                                      in console tab, put weath in the filter field
                                        Manu85 @sdetweil
                                        @sdetweil is this what is needed?
                                          sdetweil @Manu85
                                          @Manu85 no… you are looking at weather, not calendar for the trash icon
                                          need the line in calendar where it SHOULD BE
                                          sorry, in console should be calen for filter… oops
                                            Manu85 @sdetweil
                                            @sdetweil ok, like this I selected the line where the icon should appear, is it ok? for the selection that you asked me I was surprised to select the calendar, but you are the professional :-)
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 12 / 16
