    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil I ran your update script, I don’t get an error message, are there any additional operations or do I reboot the pi?
        Manu85 @sdetweil
        @sdetweil hello, I did a reboot of the pi and… it restarted magic (like the mirror :-)) I have some small settings for which I cannot find solutions
        For Weather:
        the 1st: it’s the temperature which displays more than 280° C, I know that there is global warming but still…
        the 2nd: the display of the weather forecast for the following days is a little confusing and I can’t find the settings in the console ctrl+shift+i and do you think I can write the sentence “Feels Like” in French?
        for calendar:
        I had put icons for each calendar in config.js, 1 for mine, 1 for my wife etc. ex: {
        symbol: 'male',
        url: 'webcal://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12OfzlWCbJPUrEhN49IHC1yeFEfqRieBnpxxxxxxxxxxxxx'
        symbol: 'birthday-cake',
        url: 'webcal://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWxxxxxxxxxxx'
        in the custom css I had added color to each symbol to differentiate them (I saw that it was necessary to change .fa.fa in the custom css to .fas.fa) ex:
        .fas.fa-male {
           color: #2B60DE; /* Dodger Blue */
        .fas.fa-birthday-cake {
           color: #ff0000; /* Red */
        .fas.fa-trash-o {
           color: #00FF00; /* Green */
        they all work except this one
        symbol: 'trash-o',
        for this one I don’t have any symbol
          sdetweil @Manu85
          @Manu85 trash-o is just fa.
          you have .fas.fa
          which means MUST HAVE BOTH on the same element
          add a space
          but also maybe take .fas off
            sdetweil @Manu85
            @Manu85 you just restart mm…(pm2 restart MagicMirror)
            any how, on the weather
            I think you have a conflict on how the API reports and what the module thinks it is
            I think the API is reporting in Fahrenheit, but the code thinks in Celsius
            see config options
              sdetweil @Manu85
              @Manu85 of, feels like…
              see the translations/fr.json
              its precip
              percent possibility of precipitation, (rain.snow)
              chance of rain or snow
              some languages don’t have a term for that
              I think you could change it to blank " "
              but , then this will be a file to watch out for on future upgrades
                Manu85 @sdetweil
                @sdetweil ok, thank you for this information, I will try to resolve one by one, to
                symbol: 'trash-o',
                I tried all your suggestions and I still have the same result, what is strange is that for the other icons ex:
                I do have a birthday cake
                  sdetweil @Manu85
                  @Manu85 see this post where someone needed a custom css class setting
                  https://forum.magicmirror.builders/post/114837
                  and your custom.css would have been
                  .calendar .fa-trash-o {
                  right?
                    Manu85 @sdetweil
                    @sdetweil I just did like that but still nothing I have the impression that the symbol in my js.config is not known
                    symbol: 'trash-o',
                    url: 'webcal://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12xxxxxxxxxxxxxxxxxx'
                    and all other symbols are ok
                      sdetweil @Manu85
                      @Manu85 use
                       "fa-trash-o"
                        Manu85 @sdetweil
                        @sdetweil does not work
                          sdetweil @Manu85
                          @Manu85 in the developers window what do you see in the html and console tab view , 401, 404
                          in console tab, put weath in the filter field
                            Manu85 @sdetweil
                            @sdetweil is this what is needed?
                              sdetweil @Manu85
                              @Manu85 no… you are looking at weather, not calendar for the trash icon
                              need the line in calendar where it SHOULD BE
                              sorry, in console should be calen for filter… oops
                                Manu85 @sdetweil
                                @sdetweil ok, like this I selected the line where the icon should appear, is it ok? for the selection that you asked me I was surprised to select the calendar, but you are the professional :-)
                                  Manu85 @Manu85
                                  @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
                                  @sdetweil ok, like this I selected the line where the icon should appear, is it ok? for the selection that you asked me I was surprised to select the weather, but you are the professional :-)
                                    sdetweil @Manu85
                                    @Manu85 fa-trash-o is wrong, added fa- again
                                    and you did not put
                                    calen
                                    in the console tab filter field to get just messages from calendar module
                                      sdetweil @Manu85
                                      @Manu85 they have renamed it to trash-can in fa 6 which we ship now
                                      also it is in the fa-solid connection
                                      so you may need
                                      "fa-solid trash-can"
                                      and maybe
                                      "fa-solid fa-trash-can"
                                        Manu85 @sdetweil
                                        @sdetweil you are too strong!!! now I will try to understand the weather temperature
                                          sdetweil @Manu85
                                          @Manu85 which symbol string did you use?
                                            Manu85 @sdetweil
                                            @sdetweil in config.js
                                            symbol: 'trash-can',
                                            in custom css
                                            .fas.fa-trash-can
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 12 / 16
