    MMM-PIR-Sensor interferes with MMM-RTSPStream
    4 Posts 3 Posters 1.8k Views 2 Watching
    • binderthB
      binderth
      Hi there,
      after some struggle, I managed to get MMM-RTSPStream running with my FOSCAM FI9900P. But if MMM-PIR-Sensor ist started in parallel, I got these entries in the log and the Stream won’t show:
      > magicmirror@2.3.1 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.3.1
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-PIR-Sensor
      Module helper loaded: MMM-RTSPStream
      You're using a full whitelist configuration to allow for all IPs
      Server started ...
      Connecting socket for: MMM-PIR-Sensor
      Connecting socket for: MMM-RTSPStream
      Launching application.
      Starting stream stream1 with args: [
          "--avdict",
          "rtsp_transport:tcp",
          "--win",
          "332, 1260, 684, 1502",
          "--live",
          "--video_queue",
          "4",
          "--fps",
          "30",
          "rtsp://user:pass@192.168.xx.xx:88/videoMain"
      PM2: omx_stream1 already running. Stopping old instance...
      Starting PM2 for omx_stream1
      PM2 started for omx_stream1
      Stopping stream stream1
      Stopping PM2 process: omx_stream1
          "--avdict",
          "--win",
          "332, 1225, 684, 1467",
          "--live",
          "--video_queue",
          "4",
          "--fps",
          "30",
          "--avdict",
          "--win",
          "332, 1190, 684, 1432",
          "--live",
          "--video_queue",
          "4",
          "--fps",
          "30",
      Stopping all OMXPlayer Streams...
      PM2: Stopping omx_stream1...
          "--avdict",
          "--win",
          "--live",
          "--video_queue",
          "4",
          "--fps",
          "30",
      the console pm2 logs shows an additional:
      0|mm       | Launching application.
      0|mm       | Starting stream stream1 with args: [
      0|mm       |     "--avdict",
      0|mm       |     "rtsp_transport:tcp",
      0|mm       |     "--win",
      0|mm       |     "332, 1260, 684, 1502",
      0|mm       |     "--live",
      0|mm       |     "--video_queue",
      0|mm       |     "4",
      0|mm       |     "--fps",
      0|mm       |     "30",
      0|mm       |     "rtsp://user:pass@192.168.xx.xx:88/videoMain"
      0|mm       | ]
      0|mm       | PM2: omx_stream1 already running. Stopping old instance...
      0|mm       | Starting PM2 for omx_stream1
      PM2        | Stopping app:omx_stream1 id:1
      PM2        | pid=5695 msg=failed to kill - retrying in 100ms
      1|omx_stre | Video codec omx-h264 width 640 height 360 profile 100 fps 30.000000
      1|omx_stre | Audio codec pcm_mulaw channels 1 samplerate 8000 bitspersample 8
      1|omx_stre | Subtitle count: 0, state: off, index: 1, delay: 0
      1|omx_stre | V:PortSettingsChanged: 640x360@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
      1|omx_stre | have a nice day ;)
      PM2        | App [omx_stream1] with id [1] and pid [5695], exited with code [1] via signal [SIGINT]
      PM2        | pid=5695 msg=process killed
      PM2        | Starting execution sequence in -fork mode- for app name:omx_stream1 id:1
      PM2        | App name:omx_stream1 id:1 online
      0|mm       | PM2 started for omx_stream1
      0|mm       | Stopping stream stream1
      0|mm       | Stopping PM2 process: omx_stream1
      0|mm       |     "--avdict",
      0|mm       |     "--win",
      0|mm       |     "332, 1225, 684, 1467",
      0|mm       |     "--live",
      0|mm       |     "4",
      0|mm       |     "--fps",
      0|mm       |     "30",
      0|mm       | ]
      PM2        | Process with pid 5846 already exists
      PM2        | App [omx_stream1] with id [1] and pid [5846], exited with code [0] via signal [SIGINT]
      PM2        | pid=5846 msg=process killed
      0|mm       |     "--avdict",
      0|mm       |     "--win",
      0|mm       |     "332, 1190, 684, 1432",
      0|mm       |     "--live",
      0|mm       |     "4",
      0|mm       |     "--fps",
      0|mm       |     "30",
      0|mm       | ]
      0|mm       | Stopping all OMXPlayer Streams...
      0|mm       | PM2: Stopping omx_stream1...
      PM2        | App [omx_stream1] with id [1] and pid [5956], exited with code [0] via signal [SIGINT]
      PM2        | pid=5956 msg=process killed
      0|mm       |     "--avdict",
      0|mm       |     "--win",
      0|mm       |     "--live",
      0|mm       |     "4",
      0|mm       |     "--fps",
      0|mm       |     "30",
      0|mm       | ]
      PM2        | pid=5982 msg=failed to kill - retrying in 100ms
      PM2        | Process with pid 5982 still alive after 1600ms, sending it SIGKILL now...
      PM2        | App [omx_stream1] with id [1] and pid [5982], exited with code [0] via signal [SIGKILL]
      PM2        | pid=5982 msg=process killed
      Is there something I can do?
      • B
        barnosch
        maybe use another PIR activation, not as a mirror module.
        I use this scripts from @cowboysdude
        https://github.com/cowboysdude/Pir-Sensor
        binderthB 1 Reply Last reply
        Reply Quote 1
        • binderthB
          binderth @barnosch
          Thanks! Worth a try!
          • V
            Volkae
            Hi binderth,
            i have the same problem. Did you find a solution?
