    write access to git repository
    3 Posts 2 Posters 1.3k Views 2 Watching
      sten82
      Hey there,
      this is maybe a stupid questions for all you github pro’s, but I’m really struggling to commit a tiny fix and it already costs me some hours to provide this contribution.
      What I have done so far:
      • cloned repository
      • created new branch
      • added changes
      • commit changes
      But when I try to push it fails, however pull from master works.
      ~/Documents/Sandbox/privat/MagicMirror (add-translation)
      git push --set-upstream origin add-translation
      Enter passphrase for key '/c/Users/carsten/.ssh/id_rsa':
      ERROR: Permission to MichMich/MagicMirror.git denied to sten82.
      fatal: Could not read from remote repository.
      Please make sure you have the correct access rights
      and the repository exists.
      ~/Documents/Sandbox/privat/MagicMirror (master)
      git pull
      Already up-to-date.
      I’m running on Windows 10 with git console. I have stored ssh key in Github (and checked if it works) and changed gitconfig to use ssh instead of https.
      What am I doing wrong?
      Thank you in advance,
      Carsten
        sdetweil
        YOU cannot push to the core repo… you can create a fork (under YOUR github userid), and then clone/push to THAT repo…
        you can then propose changes to the master repo, by submitting a pull request, for your branch back to the master (and some branch, usually dev) … and the master owner can accept it , or not… and then merge it with the master branch whenever…
          sten82
          Hi sdetweil,
          thank you for the clarification, since I have never contributed before I didn’t knew that. That really helped my a lot.
          Thanks,
          Carsten
