Navigation
    • Search
    UNSOLVED Weather Module feels like is a little high
    Troubleshooting
    • J
      jtmoore81 last edited by
      Is this something that I’ve done wrong or is the data from the api incorrect? I thought it felt a little warm outside 🙂
      WayneRigley 1 Reply Last reply Reply Quote 0
      • WayneRigley
        WayneRigley @jtmoore81 last edited by
        @jtmoore81 i think your Feels like is showing in Kalvin Temp. make sure your main config units are set correct… unless you live beside a steam bath lol
        • J
          jtmoore81 @WayneRigley last edited by
          @waynerigley I have the config units set as imperial which is why I get the 90.0. I’ve even tried do set the units in the module config as well but get the same results.
          • WayneRigley
            @jtmoore81 huh, i had the same issues with my time also but soon as i set my timezone on my Raspberry Pi everything came into play… so i would check your local MM Config and also the module config file and force it in there
            • J
              Not sure what changed. I had the MM running overnight and when I checked it this morning the Feels like temp was correct. My guess is that there was an issue with the OpenWeather api.
              Thanks,
