    MMM-ModuleScheduler (how to use MMM-RemoteControl to HIDE/SHOW modules)?
    7 Posts 2 Posters 2.9k Views 1 Watching
      BluP Project Sponsor
      Hi all,
      I’m using MMM-RemoteControl also from other devices to HIDE/SHOW modules (e.g. MMM-iFRAME with a video stream) via HTTP Get requests and that works nicely.
      http://My_MM_IP:8080/remote?action=SHOW&module=module_11_MMM-iFrame
      http://My_MM_IP:8080/remote?action=HIDE&module=module_11_MMM-iFrame
      This command is send from a Raspi running Motion with a connected USB CAM and will show/hide the videostream when this RasPi detects any motion. This works great.
      Now I’m also using MMM-traffic but would like to show the module only in the mornig hours during the working days and hide afterwards.
      I tried something like:
      // SHOW traffic module  on weekdays between 6:00 and 9:30
      {notification: 'REMOTE_ACTION', schedule: '0 6 * * MON-FRI', payload: {action: "SHOW&module=module_15_MMM-Traffic"}},
      {notification: 'REMOTE_ACTION', schedule: '30 9 * * MON-FRI', payload: {action: "HIDE&module=module_15_MMM-Traffic"}}
      but the module does not hide.
      For testing purposes I also tried this:
      {notification: 'REMOTE_ACTION', schedule:  '*/2 * * * MON-FRI', payload: {action: 'SHOW {"identifier":"module_15_MMM-Traffic"}'}},
                                      {notification: 'REMOTE_ACTION', schedule:  '1-59/2 * * * MON-FRI', payload: {action: 'HIDE {"identifier":"module_15_MMM-Traffic"}'}}
      Actually the moudle should be sown/hidden every other minute. In PM2 log I can see that there is some action going on, but I expect that simply my paload description is wrong.
      Any hints?
      Many thanks form Neuss/DE
        AxLed Module Developer
        what are the logs showing? (npm start dev [on Raspberry]) or (F12 [on broser like Firefox]).
        AxLED
          BluP Project Sponsor @AxLed
          @axled
          this is the PM2 logs output directly after restarting MM:
          pi@raspberrypi:~/MagicMirror $ pm2 logs MagicMirror
          [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
          /home/pi/.pm2/logs/MagicMirror-error-0.log last 15 lines:
          0|MagicMir |     at /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:68:31
          0|MagicMir |     at Git. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1482:10)
          0|MagicMir |     at done (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1354:21)
          0|MagicMir |     at ChildProcess. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1379:16)
          0|MagicMir |     at emitTwo (events.js:106:13)
          0|MagicMir |     at ChildProcess.emit (events.js:191:7)
          0|MagicMir |     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
          0|MagicMir | TypeError: Cannot read property 'hash' of null
          /home/pi/.pm2/logs/MagicMirror-out-0.log last 15 lines:
          0|MagicMir | MMM-ModuleScheduler is sending SEND_NOTIFICATION to REMOTE_ACTION
          0|MagicMir | MMM-ModuleScheduler will next send SEND_NOTIFICATION to REMOTE_ACTION at Sat Jun 16 2018 14:53:00 GMT+0200 (CEST) based on "1-59/2 * * * *"
          0|MagicMir | Shutting down server...
          0|MagicMir | Stopping module helper: updatenotification
          0|MagicMir | Stopping module helper: calendar
          0|MagicMir | Stopping module helper: MMM-DWD-WarnWeather
          0|MagicMir | Stopping module helper: MMM-Remote-Control
          0|MagicMir | Stopping module helper: MMM-NetworkScanner
          0|MagicMir | Stopping module helper: MMM-Traffic
          0|MagicMir | Stopping module helper: MMM-ModuleScheduler
          0|MagicMir | Stopping module helper: newsfeed
          0|MagicMir |
          0|MagicMir | > magicmirror@2.3.1 start /home/pi/MagicMirror
          0|MagicMir | > sh run-start.sh
          0|MagicMir |
          0|MagicMir | Starting MagicMirror: v2.3.1
          0|MagicMir | Loading config ...
          0|MagicMir | Loading module helpers ...
          0|MagicMir | No helper found for module: alert.
          0|MagicMir | Initializing new module helper ...
          0|MagicMir | Module helper loaded: updatenotification
          0|MagicMir | No helper found for module: clock.
          0|MagicMir | No helper found for module: calendar_monthly.
          0|MagicMir | Module helper loaded: calendar
          0|MagicMir | No helper found for module: MMM-EasyPix.
          0|MagicMir | No helper found for module: currentweather.
          0|MagicMir | No helper found for module: weatherforecast.
          0|MagicMir | Module helper loaded: MMM-DWD-WarnWeather
          0|MagicMir | No helper found for module: MMM-iFrame.
          0|MagicMir | No helper found for module: MMM-RandomPhoto.
          0|MagicMir | Module helper loaded: MMM-Remote-Control
          0|MagicMir | Module helper loaded: MMM-NetworkScanner
          0|MagicMir | No helper found for module: compliments.
          0|MagicMir | Module helper loaded: MMM-Traffic
          0|MagicMir | Module helper loaded: MMM-ModuleScheduler
          0|MagicMir | Module helper loaded: newsfeed
          0|MagicMir | All module helpers loaded.
          0|MagicMir | Starting server on port 8080 ...
          0|MagicMir | You're using a full whitelist configuration to allow for all IPs
          0|MagicMir | Server started ...
          0|MagicMir | Connecting socket for: updatenotification
          0|MagicMir | Connecting socket for: calendar
          0|MagicMir | Starting node helper for: calendar
          0|MagicMir | Connecting socket for: MMM-DWD-WarnWeather
          0|MagicMir | MMM-DWD-WarnWeather helper started...
          0|MagicMir | Connecting socket for: MMM-Remote-Control
          0|MagicMir | Starting node helper for: MMM-Remote-Control
          0|MagicMir | Connecting socket for: MMM-NetworkScanner
          0|MagicMir | Starting module: MMM-NetworkScanner
          0|MagicMir | Connecting socket for: MMM-Traffic
          0|MagicMir | MMM-Traffic helper started ...
          0|MagicMir | Connecting socket for: MMM-ModuleScheduler
          0|MagicMir | Starting node helper for: MMM-ModuleScheduler
          0|MagicMir | Connecting socket for: newsfeed
          0|MagicMir | Starting module: newsfeed
          0|MagicMir | Sockets connected & modules started ...
          0|MagicMir | Launching application.
          0|MagicMir | Whoops! There was an uncaught exception...
          0|MagicMir | TypeError: Cannot read property 'replace' of undefined
          0|MagicMir |     at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:240:24
          0|MagicMir |     at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/simple-git/src/git.js:768:18
          0|MagicMir |     at Git. (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/simple-git/src/git.js:808:18)
          0|MagicMir |     at done (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/simple-git/src/git.js:1354:21)
          0|MagicMir |     at ChildProcess. (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/simple-git/src/git.js:1379:16)
          0|MagicMir | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|MagicMir | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          0|MagicMir | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/***secret-stuff***/basic.ics - Interval: 300000
          0|MagicMir | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/de.german%23holiday%40group.v.calendar.google.com/public/basic.ics - Interval: 300000
          0|MagicMir | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/***Secret-stuff***.calendar.google.com/public/basic.ics - Interval: 300000
          0|MagicMir | MMM-NetworkScanner received CONFIG
          0|MagicMir | MMM-ModuleScheduler is removing all scheduled jobs
          0|MagicMir | MMM-ModuleScheduler received CREATE_NOTIFICATION_SCHEDULE
          0|MagicMir | MMM-ModuleScheduler is scheduling REMOTE_ACTION using "30 6 * * *
          0|MagicMir | MMM-ModuleScheduler has scheduled REMOTE_ACTION
          0|MagicMir | MMM-ModuleScheduler will next send REMOTE_ACTION at Sun Jun 17 2018 06:30:00 GMT+0200 (CEST)
          0|MagicMir | MMM-ModuleScheduler is scheduling REMOTE_ACTION using "30 22 * * *
          0|MagicMir | MMM-ModuleScheduler will next send REMOTE_ACTION at Sat Jun 16 2018 22:30:00 GMT+0200 (CEST)
          0|MagicMir | MMM-ModuleScheduler is scheduling REMOTE_ACTION using "0 2 * * SUN
          0|MagicMir | MMM-ModuleScheduler will next send REMOTE_ACTION at Sun Jun 17 2018 02:00:00 GMT+0200 (CEST)
          0|MagicMir | MMM-ModuleScheduler is scheduling REMOTE_ACTION using "*/2 * * * *
          0|MagicMir | MMM-ModuleScheduler will next send REMOTE_ACTION at Sat Jun 16 2018 14:54:00 GMT+0200 (CEST)
          0|MagicMir | MMM-ModuleScheduler is scheduling REMOTE_ACTION using "1-59/2 * * * *
          0|MagicMir | MMM-ModuleScheduler will next send REMOTE_ACTION at Sat Jun 16 2018 14:53:00 GMT+0200 (CEST)
          0|MagicMir | Create new news fetcher for url: https://www.n-tv.de/rss - Interval: 300000
          0|MagicMir | Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
          0|MagicMir | MMM-ModuleScheduler will next send SEND_NOTIFICATION to REMOTE_ACTION at Sat Jun 16 2018 14:55:00 GMT+0200 (CEST) based on "1-59/2 * * * *"
          0|MagicMir | MMM-ModuleScheduler will next send SEND_NOTIFICATION to REMOTE_ACTION at Sat Jun 16 2018 14:56:00 GMT+0200 (CEST) based on "*/2 * * * *"
          Thanks for the hint with “npm start dev”
          As beeing a newbie to npm this was not known to me.
          Within the “console” tab I can see notifications send from MMM-ModuleScheduler on a minute bais as expected.
          Is there a chance to see the content of the payload?
          I also recognized several error mesages from MM. …
          Thanks, Peter
            @blup said in MMM-ModuleScheduler (how to use MMM-RemoteControl to HIDE/SHOW modules)?:
            {notification: ‘REMOTE_ACTION’, schedule: ‘0 6 * * MON-FRI’, payload: {action: “SHOW&module=module_15_MMM-Traffic”}},
            Hi Peter,
            1st Tip:
            I think your syntax in config.js is wrong.
            You use:
            and i think (didnt test it) it should be
            {notification: 'REMOTE_ACTION', schedule: '0 6 * * MON-FRI', payload: {action: "SHOW", module: "module_15_MMM-Traffic"}},
            2nd Tip:
            Have you checked the config options of MMM-Traffic, see this entries:
            showWeekend, startHr, endHr, hideOffHours
            AxLED
            B 2 Replies Last reply Reply Quote 1
              @axled
              Thanks for the tipps. I’ll check that.
              Yes, I checked the config options in MMM-traffic, but if you use them and the module is hidden, you can’t use MMM-remoteControl to Show them again.
              Nevertheless I’ll try your information to see what happens.
              Thanks a lot. I’ll keep you updated! :-)
                @axled
                Thanks a lot!
                Your syntax check did the trick. Now it works as expected!
                Many thanks!:thumbs_up:
                  You are welcome, i had some visual basic skills in the past an trained myself javascript skills the last weeks, for modifying and writing own modules.
                  I am sure in a few weeks, you are helping other MM Users to do some customizing on their mirrors.
                  AxLED
