MMM-ModuleScheduler (how to use MMM-RemoteControl to HIDE/SHOW modules)?
7 Posts 2 Posters 2.7k Views 1 Watching
    BluP Project Sponsor
    Hi all,
    I’m using MMM-RemoteControl also from other devices to HIDE/SHOW modules (e.g. MMM-iFRAME with a video stream) via HTTP Get requests and that works nicely.
    http://My_MM_IP:8080/remote?action=SHOW&module=module_11_MMM-iFrame
    http://My_MM_IP:8080/remote?action=HIDE&module=module_11_MMM-iFrame
    This command is send from a Raspi running Motion with a connected USB CAM and will show/hide the videostream when this RasPi detects any motion. This works great.
    Now I’m also using MMM-traffic but would like to show the module only in the mornig hours during the working days and hide afterwards.
    I tried something like:
    // SHOW traffic module  on weekdays between 6:00 and 9:30
    {notification: 'REMOTE_ACTION', schedule: '0 6 * * MON-FRI', payload: {action: "SHOW&module=module_15_MMM-Traffic"}},
    {notification: 'REMOTE_ACTION', schedule: '30 9 * * MON-FRI', payload: {action: "HIDE&module=module_15_MMM-Traffic"}}
    but the module does not hide.
    For testing purposes I also tried this:
    {notification: 'REMOTE_ACTION', schedule:  '*/2 * * * MON-FRI', payload: {action: 'SHOW {"identifier":"module_15_MMM-Traffic"}'}},
                                    {notification: 'REMOTE_ACTION', schedule:  '1-59/2 * * * MON-FRI', payload: {action: 'HIDE {"identifier":"module_15_MMM-Traffic"}'}}
    Actually the moudle should be sown/hidden every other minute. In PM2 log I can see that there is some action going on, but I expect that simply my paload description is wrong.
    Any hints?
    Many thanks form Neuss/DE
      AxLed Module Developer
      what are the logs showing? (npm start dev [on Raspberry]) or (F12 [on broser like Firefox]).
      AxLED
      B 1 Reply Last reply Jun 16, 2018, 1:31 PM Reply Quote 0
        BluP Project Sponsor @AxLed
        @axled
        this is the PM2 logs output directly after restarting MM:
        pi@raspberrypi:~/MagicMirror $ pm2 logs MagicMirror
        [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
        /home/pi/.pm2/logs/MagicMirror-error-0.log last 15 lines:
        0|MagicMir |     at /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:68:31
        0|MagicMir |     at Git. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1482:10)
        0|MagicMir |     at done (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1354:21)
        0|MagicMir |     at ChildProcess. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1379:16)
        0|MagicMir |     at emitTwo (events.js:106:13)
        0|MagicMir |     at ChildProcess.emit (events.js:191:7)
        0|MagicMir |     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
        0|MagicMir | TypeError: Cannot read property 'hash' of null
        /home/pi/.pm2/logs/MagicMirror-out-0.log last 15 lines:
        0|MagicMir | MMM-ModuleScheduler is sending SEND_NOTIFICATION to REMOTE_ACTION
        0|MagicMir | MMM-ModuleScheduler will next send SEND_NOTIFICATION to REMOTE_ACTION at Sat Jun 16 2018 14:53:00 GMT+0200 (CEST) based on "1-59/2 * * * *"
        0|MagicMir | Shutting down server...
        0|MagicMir | Stopping module helper: updatenotification
        0|MagicMir | Stopping module helper: calendar
        0|MagicMir | Stopping module helper: MMM-DWD-WarnWeather
        0|MagicMir | Stopping module helper: MMM-Remote-Control
        0|MagicMir | Stopping module helper: MMM-NetworkScanner
        0|MagicMir | Stopping module helper: MMM-Traffic
        0|MagicMir | Stopping module helper: MMM-ModuleScheduler
        0|MagicMir | Stopping module helper: newsfeed
        0|MagicMir |
        0|MagicMir | > magicmirror@2.3.1 start /home/pi/MagicMirror
        0|MagicMir | > sh run-start.sh
        0|MagicMir |
        0|MagicMir | Starting MagicMirror: v2.3.1
        0|MagicMir | Loading config ...
        0|MagicMir | Loading module helpers ...
        0|MagicMir | No helper found for module: alert.
        0|MagicMir | Initializing new module helper ...
        0|MagicMir | Module helper loaded: updatenotification
        0|MagicMir | No helper found for module: clock.
        0|MagicMir | No helper found for module: calendar_monthly.
        0|MagicMir | Module helper loaded: calendar
        0|MagicMir | No helper found for module: MMM-EasyPix.
        0|MagicMir | No helper found for module: currentweather.
        0|MagicMir | No helper found for module: weatherforecast.
        0|MagicMir | Module helper loaded: MMM-DWD-WarnWeather
        0|MagicMir | No helper found for module: MMM-iFrame.
        0|MagicMir | No helper found for module: MMM-RandomPhoto.
        0|MagicMir | Module helper loaded: MMM-Remote-Control
        0|MagicMir | Module helper loaded: MMM-NetworkScanner
        0|MagicMir | No helper found for module: compliments.
        0|MagicMir | Module helper loaded: MMM-Traffic
        0|MagicMir | Module helper loaded: MMM-ModuleScheduler
        0|MagicMir | Module helper loaded: newsfeed
        0|MagicMir | All module helpers loaded.
        0|MagicMir | Starting server on port 8080 ...
        0|MagicMir | You're using a full whitelist configuration to allow for all IPs
        0|MagicMir | Server started ...
        0|MagicMir | Connecting socket for: updatenotification
        0|MagicMir | Connecting socket for: calendar
        0|MagicMir | Starting node helper for: calendar
        0|MagicMir | Connecting socket for: MMM-DWD-WarnWeather
        0|MagicMir | MMM-DWD-WarnWeather helper started...
        0|MagicMir | Connecting socket for: MMM-Remote-Control
        0|MagicMir | Starting node helper for: MMM-Remote-Control
        0|MagicMir | Connecting socket for: MMM-NetworkScanner
        0|MagicMir | Starting module: MMM-NetworkScanner
        0|MagicMir | Connecting socket for: MMM-Traffic
        0|MagicMir | MMM-Traffic helper started ...
        0|MagicMir | Connecting socket for: MMM-ModuleScheduler
        0|MagicMir | Starting node helper for: MMM-ModuleScheduler
        0|MagicMir | Connecting socket for: newsfeed
        0|MagicMir | Starting module: newsfeed
        0|MagicMir | Sockets connected & modules started ...
        0|MagicMir | Launching application.
        0|MagicMir | Whoops! There was an uncaught exception...
        0|MagicMir | TypeError: Cannot read property 'replace' of undefined
        0|MagicMir |     at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:240:24
        0|MagicMir |     at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/simple-git/src/git.js:768:18
        0|MagicMir |     at Git. (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/simple-git/src/git.js:808:18)
        0|MagicMir |     at done (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/simple-git/src/git.js:1354:21)
        0|MagicMir |     at ChildProcess. (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/simple-git/src/git.js:1379:16)
        0|MagicMir | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        0|MagicMir | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        0|MagicMir | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/***secret-stuff***/basic.ics - Interval: 300000
        0|MagicMir | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/de.german%23holiday%40group.v.calendar.google.com/public/basic.ics - Interval: 300000
        0|MagicMir | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/***Secret-stuff***.calendar.google.com/public/basic.ics - Interval: 300000
        0|MagicMir | MMM-NetworkScanner received CONFIG
        0|MagicMir | MMM-ModuleScheduler is removing all scheduled jobs
        0|MagicMir | MMM-ModuleScheduler received CREATE_NOTIFICATION_SCHEDULE
        0|MagicMir | MMM-ModuleScheduler is scheduling REMOTE_ACTION using "30 6 * * *
        0|MagicMir | MMM-ModuleScheduler has scheduled REMOTE_ACTION
        0|MagicMir | MMM-ModuleScheduler will next send REMOTE_ACTION at Sun Jun 17 2018 06:30:00 GMT+0200 (CEST)
        0|MagicMir | MMM-ModuleScheduler is scheduling REMOTE_ACTION using "30 22 * * *
        0|MagicMir | MMM-ModuleScheduler will next send REMOTE_ACTION at Sat Jun 16 2018 22:30:00 GMT+0200 (CEST)
        0|MagicMir | MMM-ModuleScheduler is scheduling REMOTE_ACTION using "0 2 * * SUN
        0|MagicMir | MMM-ModuleScheduler will next send REMOTE_ACTION at Sun Jun 17 2018 02:00:00 GMT+0200 (CEST)
        0|MagicMir | MMM-ModuleScheduler is scheduling REMOTE_ACTION using "*/2 * * * *
        0|MagicMir | MMM-ModuleScheduler will next send REMOTE_ACTION at Sat Jun 16 2018 14:54:00 GMT+0200 (CEST)
        0|MagicMir | MMM-ModuleScheduler is scheduling REMOTE_ACTION using "1-59/2 * * * *
        0|MagicMir | MMM-ModuleScheduler will next send REMOTE_ACTION at Sat Jun 16 2018 14:53:00 GMT+0200 (CEST)
        0|MagicMir | Create new news fetcher for url: https://www.n-tv.de/rss - Interval: 300000
        0|MagicMir | Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
        0|MagicMir | MMM-ModuleScheduler will next send SEND_NOTIFICATION to REMOTE_ACTION at Sat Jun 16 2018 14:55:00 GMT+0200 (CEST) based on "1-59/2 * * * *"
        0|MagicMir | MMM-ModuleScheduler will next send SEND_NOTIFICATION to REMOTE_ACTION at Sat Jun 16 2018 14:56:00 GMT+0200 (CEST) based on "*/2 * * * *"
        Thanks for the hint with “npm start dev”
        As beeing a newbie to npm this was not known to me.
        Within the “console” tab I can see notifications send from MMM-ModuleScheduler on a minute bais as expected.
        Is there a chance to see the content of the payload?
        I also recognized several error mesages from MM. …
        Thanks, Peter
          @blup said in MMM-ModuleScheduler (how to use MMM-RemoteControl to HIDE/SHOW modules)?:
          {notification: ‘REMOTE_ACTION’, schedule: ‘0 6 * * MON-FRI’, payload: {action: “SHOW&module=module_15_MMM-Traffic”}},
          Hi Peter,
          1st Tip:
          I think your syntax in config.js is wrong.
          You use:
          and i think (didnt test it) it should be
          {notification: 'REMOTE_ACTION', schedule: '0 6 * * MON-FRI', payload: {action: "SHOW", module: "module_15_MMM-Traffic"}},
          2nd Tip:
          Have you checked the config options of MMM-Traffic, see this entries:
          showWeekend, startHr, endHr, hideOffHours
          AxLED
          B 2 Replies Last reply Jun 16, 2018, 3:52 PM Reply Quote 1
            @axled
            Thanks for the tipps. I’ll check that.
            Yes, I checked the config options in MMM-traffic, but if you use them and the module is hidden, you can’t use MMM-remoteControl to Show them again.
            Nevertheless I’ll try your information to see what happens.
            Thanks a lot. I’ll keep you updated! :-)
              @axled
              Thanks a lot!
              Your syntax check did the trick. Now it works as expected!
              Many thanks!:thumbs_up:
                You are welcome, i had some visual basic skills in the past an trained myself javascript skills the last weeks, for modifying and writing own modules.
                I am sure in a few weeks, you are helping other MM Users to do some customizing on their mirrors.
                AxLED
