    Microsoft To-Do (wunderlist replacement?)
    45 Posts 17 Posters 29.9k Views 19 Watching
    • O Offline
      open_book
      @thobach thanks for your effort. Just got this up and running from your instructions in the README. Very pleased. :thumbs_up:
      sudo insert motivational.quote
        Mighty Mouseq @thobach
        @thobach said in Microsoft To-Do (wunderlist replacement?):
        I don’t plan to implement a fade-option, sorry, it would require quite some effort given the current implementation.
        I have been able to add a fade-option by looking at how this option has been implemented in the MMM-nstreinen module by @qistoph. Since I am not familiair with JS coding I don’t know wether it has been coded as it should.
        My addition takes two parameters from config.js: ‘fade’, which can be true or false and ‘fadePoint’, which takes a decimal value between 0 and 1 and marks the point where the fade starts.
        I added the code after the listItem styling.
        // needed for the fade effect
                itemCounter += 1
                // Create fade effect.
                if (self.config.fade && self.config.fadePoint < 1) {
                  if (self.config.fadePoint < 0) {
        	          self.config.fadePoint = 0;
        	        var startingPoint = self.config.itemLimit * self.config.fadePoint;
        	        var steps = self.config.itemLimit - startingPoint;
        	        if (itemCounter >= startingPoint) {
                    var currentStep = itemCounter - startingPoint;
                    listItem.style.opacity = 1 - (1 / steps * currentStep);
        • T Offline
          thobach @Mighty Mouseq
          @Mighty-Mouseq Nice! Do you want to create a pull request? I could then merge it into the main branch for everyone.
            @thobach I do not consider myself a developer :-). I do not even have a GitHub account. If you prefer to implement this change through a pull request then I will have a look at the process. For such a minor change it might be a lot easier if you, or another developer, added the code in your repository.
              @thobach I think I have created a pull request for the fade effect.
              • 3 / 3
