    Switched to development branch, mirror stopped launching
    3 Posts 2 Posters 2.5k Views 2 Watching
    • C Offline
      Canterrain
      Just like the preview says. I switched to development branch (an issue I had was supposed to be solved in development) and since then the mirror won’t launch Pm2 start mm leads to a success message, that part seems to be working.
      Npm start leads to the following error:
      JavaSript error, unchaught exception.
      cannot file module 'express.ipfilter'
      I tried updating node.js at one point (because I forgot to change directory when I attempted npm start) but haven’t had any other luck otherwise. Anyone else run into this?
        Jopyth Moderator @Canterrain
        @Canterrain Please run npm install in your MagicMirror folder (again). It should install the missing dependency.
        Helpful sticky: How to troubleshoot
        • C Offline
          Canterrain
          Should have updated, closed. I thought of it right after I posted, and yeah that took care of the problem. Thanks!
