    MMM-tvservice
    6 Posts 4 Posters 6.5k Views 5 Watching
    • AlvingerA Offline
      Alvinger
      MMM-tvservice is a module that turns HDMI On or Off using the tvservice program.
      I got the idea from @ianperrin when he implemented notification functionality in MMM-ModuleScheduler. I highly recommend this module for scheduling On and Off times for MMM-tvservice.
      Check out the README ad https://github.com/Alvinger/MMM-tvservice.
      andrewchumchalA 1 Reply Last reply Reply Quote 0
      • andrewchumchalA Offline
        andrewchumchal @Alvinger
        This post is deleted!
        • paphkoP Offline
          paphko
          I like the idea of having fixed times to switch the mirror on and off, thank you for contributing this module :-)
          But your config looks unnecessarily complex. I would suggest such a format:
                  notification_schedule: [
                      { HDMI_ON: "30 6 * * *" },
                      { HDMI_OFF: "0 23 * * *" },
          • AlvingerA Offline
            Alvinger
            @paphko: the config is not the MMM-tvservice config, it is the MMM-ModuleScheduler config. I am using that module to send the notifications. Send your suggestions to @ianperrin who is the author of MMM-ModuleScheduler.
            However, as the MMM-ModuleScheduler needs to be generic in order to cover a vast number of use cases I think that this added complexity is not an issue.
            paphkoP 1 Reply Last reply Reply Quote 0
            • paphkoP Offline
              paphko @Alvinger
              @Alvinger Sorry, my fault - I indeed thought that this were the configuration of the MMM-tvservice module O:-)
              But for more convenient configuration of your module, you could consider adding some delegate to the schedule for the proposed format ;-)
              • G Offline
                gismo2006
                Hi, a little question, I read about the tvservice and that you will be to chance the console at wake up, before you can use your option. So Yesterday I found this you can use vcgencmd display_power 0 / vcgencmd display_power 1 for power down your hdmi port. And it schould be faster and you havent to chanche your console at wake up. I don´t know enough, but could it be a better option for slleping an wake up?
                Here is the link to the webpage, but its in german:
                https://pi-buch.info/tag/tvservice/
