    Is it possible to have custom information for each module in the config file?
    2 Posts 1 Posters 995 Views 1 Watching
    • V
      Veldrovive Module Developer
      In order to improve the usability of my page system, I would like to be able to use a custom piece of information in the config file to define pages and positions for the Modules.
          "module": "clock",
          "position": "top_right",
          "pages": {"pageName": "position"},
          "config": {}
      However, it seems just using getModules.enumerate() doesn’t supply that new pages object.
      As a workaround, I noticed that the config for each module is given and so the page’s object could be stored inside that. However, for less confusing use, I would rather have it outside.
      The other option I would explore is simply importing the config into my node_helper and then parsing the config manually, but before I went ahead with the plan I wanted to see if there is some reason to refrain from that.
      Is there a correct way to do this? Is it correct to do this at all?
      • V
        After trying out the method of importing the config, it works well and seems to be stable. If anyone has any reason why not to require the config.js in a node_helper file, I would appreciate an explanation.
