    MMM-Nest-Thermostat: Display Nest Thermostats in Magic Mirror
    4 Posts 4 Posters 3.4k Views 4 Watching
    • mrmidiM
      mrmidi
      Greetings,
      Just wrapped up a new Magic Mirror Module that adds Nest Thermostats.
      https://github.com/manifestinteractive/MMM-Nest-Thermostat
      screenshot
      Features:
      • Fetches all thermostats in your house
      • Can be displayed in one of four sizes
      • Cherry-pick which thermostats to display
      • Shows current status and temperature of thermostats
      • There is also a bash script to help generate the Nest API Token
        smallfishhk
        Hi , I am new to MagicMirror. just try to install the Nest. Mirror would not start and indicated that it need config file.
        my entry in config file as follow
              		module: :"MMM-Nest-Thermostat",
                	token: ."c.xxxxxxE4jV1tO4jKqyLwTIosBXxEtewFAfLNxLUAM4JY574ZhZGNmdHBn4t0ysH9ngIg2081ATeJfrlKQ" ,
                	onlineOnly: true,
                	roomFilter: ['']
        May you help and what go wrong? Thanks inadvance
        • Y
          yawns Moderator
          There is a : too much in the module line, and there is a dot before the token value
          • M
            maugerc
            Hi, I installed this new Nest thermostat module and i’m very happy with it, but it never seems to update. I connected and it is showing the thermostats i have correctly, but i never updates itself from there. I have the updateInterval set to 6000, but still nothing. I took the token out just for viewing purposes. Any thoughts on why this isn’t updating info?
                  		module: 'MMM-Nest-Thermostat',
                  		position: 'lower_third',
                    			token: "xxxxxxxxxx",
                    			onlineOnly: true,
                    			roomFilter: [''],
            				updateInterval: 6000
