MMM-Nest-Thermostat: Display Nest Thermostats in Magic Mirror
4 Posts 4 Posters 3.1k Views 4 Watching
    mrmidi
    Greetings,
    Just wrapped up a new Magic Mirror Module that adds Nest Thermostats.
    https://github.com/manifestinteractive/MMM-Nest-Thermostat
    screenshot
    Features:
    • Fetches all thermostats in your house
    • Can be displayed in one of four sizes
    • Cherry-pick which thermostats to display
    • Shows current status and temperature of thermostats
    • There is also a bash script to help generate the Nest API Token
      smallfishhk
      Hi , I am new to MagicMirror. just try to install the Nest. Mirror would not start and indicated that it need config file.
      my entry in config file as follow
            		module: :"MMM-Nest-Thermostat",
              	token: ."c.xxxxxxE4jV1tO4jKqyLwTIosBXxEtewFAfLNxLUAM4JY574ZhZGNmdHBn4t0ysH9ngIg2081ATeJfrlKQ" ,
              	onlineOnly: true,
              	roomFilter: ['']
      May you help and what go wrong? Thanks inadvance
      • Y Offline
        yawns Moderator
        There is a : too much in the module line, and there is a dot before the token value
          maugerc
          Hi, I installed this new Nest thermostat module and i’m very happy with it, but it never seems to update. I connected and it is showing the thermostats i have correctly, but i never updates itself from there. I have the updateInterval set to 6000, but still nothing. I took the token out just for viewing purposes. Any thoughts on why this isn’t updating info?
                		module: 'MMM-Nest-Thermostat',
                		position: 'lower_third',
                  			token: "xxxxxxxxxx",
                  			onlineOnly: true,
                  			roomFilter: [''],
          				updateInterval: 6000
