    MMM-Page-Selector: A page switcher that can set positions of modules
    94 Posts 14 Posters 93.8k Views 15 Watching
      sdetweil @Riaanh
      @Riaanh said in MMM-Page-Selector: A page switcher that can set positions of modules:
      MMM-Page-Selector
      can u show the messages from where u start MagicMirror
      either npm start
      or pm2
      if using pm2,. then
      pm2 logs --lines=100
      will show the messages
      blank screen is usually a missing library , see
        Riaanh @sdetweil
        @sdetweil said in MMM-Page-Selector: A page switcher that can set positions of modules:
        0 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
        1 info using npm@7.5.2
        2 info using node@v12.22.5
        3 timing config:load:defaults Completed in 4ms
        4 timing config:load:file:/usr/share/nodejs/npm/npmrc Completed in 7ms
        5 timing config:load:builtin Completed in 8ms
        6 timing config:load:cli Completed in 4ms
        7 timing config:load:env Completed in 1ms
        8 timing config:load:file:/home/pi/magicmirror/mounts/modules/.npmrc Completed in 1ms
        9 timing config:load:project Completed in 3ms
        10 timing config:load:file:/home/pi/.npmrc Completed in 0ms
        11 timing config:load:user Completed in 0ms
        12 timing config:load:file:/etc/npmrc Completed in 0ms
        13 timing config:load:global Completed in 0ms
        14 timing config:load:cafile Completed in 1ms
        15 timing config:load:validate Completed in 1ms
        16 timing config:load:setUserAgent Completed in 2ms
        17 timing config:load:setEnvs Completed in 2ms
        18 timing config:load Completed in 29ms
        19 verbose npm-session 72db9025016605ec
        20 timing npm:load Completed in 58ms
        21 timing command:run-script Completed in 45ms
        22 timing command:start Completed in 59ms
        23 verbose stack Error: missing script: start
        23 verbose stack     at runScript (/usr/share/nodejs/npm/lib/run-script.js:54:11)
        24 verbose cwd /home/pi/magicmirror/mounts/modules
        25 verbose Linux 5.10.92-v7l+
        26 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
        27 verbose node v12.22.5
        28 verbose npm  v7.5.2
        29 error missing script: start
        30 verbose exit 1
        Thanks for responding, is this what you are referring to?
          sdetweil @Riaanh
          @Riaanh how do you start MagicMirror normally?
            sdetweil @Riaanh
            @Riaanh this looks like being started under docker
            • 6
            • 7
            • 8
            • 9
            • 10
            • 10 / 10
