    MMM-Page-Selector: A page switcher that can set positions of modules
    94 Posts 14 Posters 100.1k Views 15 Watching
      robiv8
      Wow, that was fast.
      Will it morning look at rest, and test.
      But what I read so far looks like this for me:
      First list all the modules as before.
      Below that, under “pages:” and the page names, insert the module names with location.
      And I have to give the modules a name (name:) which is then used in pages: for the position.
      So roughly right?
      Oh! One question:
      How implement more then 1 module in exclusion?
      exclusion: [
      "module": "MMM-Cursor"
      "MMM-page-indicator",
          position: "bottom_center"
      • V Offline
        Veldrovive Module Developer
        So the exclusions array takes a list of selectors. Those selectors could be the name of a module (Like MMM-Cursor) or they could be the prop name. Here’s some sample code:
        This is the inside the module array:
            module: "MMM-page-indicator",
        And then this is the exclusions:
            "noHide",
        This one works because the name noHide is a selector.
        You could also just use the name of the module:
            "MMM-Cursor",
        because it is also just a selector.
        The pages config also works off of selectors in the same way. noHide is a selector that you assign with the name prop while MMM-page-indicator is a selector that is assigned via the fact that it is the name of the module.
        • P Offline
          Peter_Froberg @Veldrovive
          @veldrovive Thanks, for the reply. I finnaly did find the problem. It was as always a typo from my side. I have now konverted the config to the “second” config option which I like better as I can gather all the pages config in one section.
          Thanks for a greate module :)
          • V Offline
            Ah good. I’m glad that the changes I’m making are improving the module.
            Thank you for the kind words.
              Johans
              @Veldrovive Installed your module, along with the MMM-page-indicator.
              Page1 shows OK, but I can’t move to Page2.
              What i’m doing wrong?
              Here’s my config
              			module: "alert",
              			pages: "all",
              			disabled: false,
              		        module: "MMM-Page-Selector",
              		        position: "top_bar",
              			    defaultPage: "Page1",
              		            displayTitle: true,
              			    selectPageNotif: ["SELECT_PAGE"],
              		            incrementPageNotif: ["PAGE_UP"],
              		            decrementPageNotif: ["PAGE_DOWN"]
              			disabled: false,
              		        module: 'MMM-page-indicator',
              		        position: 'bottom_bar',
              			pages: "all",
              		            pages: 3,
              			module: "updatenotification",
              			pages: {"Page1": "top_bar"},
              			disabled: false,
              			module: "clock",
              			pages: {"Page1": "top_left"},
              			disabled: false,
              			module: "compliments",
              			position: "lower_third",
              			pages: {"Page2": "lower_third"},
              	                disabled: false,
              	                module: 'MMM-Lunartic',
              	                position: 'top_center', // Best in left, center, or right regions
              		        pages: {"Page3": "top_center"},
              		                mode: "rotating", // rotating or static
              		                image: "current", // animation, current, DayNight or static
              		                distance: "km", // miles or km
              		                useHeader: false, // true if you want a header
              		                header: "Huidige Maan stand", // Any text you want
              		                maxWidth: "300px",
              		                animationSpeed: 0,
              		                rotateInterval: 15000,
              		        disabled: false,
              			module: 'MMM-BackgroundSlideshow',
              		        position: 'fullscreen_below',
              			pages: {"Page1": "fullscreen_below"},
               		                imagePaths: ['modules/MMM-BackgroundSlideshow/Images/'],
              		                transitionImages: true,
              			        slideshowSpeed: 20000,  // 20 Seconds
              			        //transitionSpeed: '2s',
              		                randomizeImageOrder: true,
              			module: 'MMM-Cursor',
              			pages: "all",
              I have installed MMM-Voice-Command as well, but I really don’t need voice for the moment so I didn’t add this in the config.
              • V Offline
                One small thing before I actually get into the meat of the issue. It is not necessary to specify the number of pages for MMM-page-indicator since it is overridden by the page selector.
                While I was developing the new page system, I forgot about the very important issue of capitalization. Basically what was happening is that it was trying to switch to pages that did not exist. If you pull the update, everything should work fine.
                  Johans @Veldrovive
                  @veldrovive Wow, that was a quick. Works fantastic now. Great job!! Thanks.
                    Banandze
                    Hi @Veldrovive ! Can you help me to solve some problems with pages? The first is that it doesn’t swith sometimes. it works, but not the whole time. The second is rhat pages show modules while they don’t havw to. There are config file and examples. So the main page (главная) shows weather data but it doesn’t have to. The same situation with other pages (example - calendar “календарь”). While the weather page (with earth) doesn’t show these modules. Wrehe is the problem? Sorry for bad structure…
                    2_1541775272883_yEWh3L69-34.jpg 1_1541775272882_Jwv8wrCwI6c.jpg 0_1541775272882_dO_MUnExwk8.jpg
                    var config = {
                    	port: 8080,
                    	language: "ru",
                    	timeFormat: 24,
                    	units: "metric",
                    			"module": "MMM-Page-Selector",
                    			"position": "top_center",
                    			"config": {
                    				"defaultPage": "главная",
                    				"displayTitle": true,
                    				"selectPageNotif": [],
                    				"incrementPageNotif": [],
                    				"decrementPageNotif": []
                                       "pages": "all",
                                       pages: 6,
                                       activeBright: true,
                                       inactiveHollow: true,
                         			module: "alert",
                                            "pages": "all",
                    		module: 'MMM-PIR-Sensor',
                    	        "pages": "all",
                                             sensorPIN: 22,
                                             powerSaving: true,
                                             powerSavingDelay: 120,
                                    module:     'MMM-3Day-Forecast',
                                    position:   'top_right',
                                    "pages": {"главная": "top_right"},
                    		api_key:    '2f91769xxxxxxxxxxxxxxx',
                    		lat:        54.61972,
                    		lon:        39.740002,
                    		units:      'M',
                    		lang:       'ru',
                    		interval:   900000,
                    		module: "currentweather",
                                    animationSpeed: 500,                     	// This can be any of the regions.
                    		"pages": {"погода": "top_left"},							// Best results in left or right regions.
                    			locationID: "500096", //Location ID from http://openweathermap.org/help/city_list.txt
                    			appid: "ab3164xxxxxxxxxxxx" //openweathermap.org API key.
                                    module: "MMM-EARTH",
                                    position: "bottom_center",
                                    "pages": {"погода": "middle_center"},
                                    mode: "Natural",
                                    rotateInterval: 5000,
                                    MaxWidth: "50%",
                                    MaxHeight: "50%",
                                    module: "weatherforecast",
                                    position: "left",       // This can be any of the regions.
                                    colored: true,
                                    pages: {погода: "left"},
                                            locationID: "500096", //Location ID from http://openwea$
                                            appid: "ab31646bxxxxxxxxxxxxx" //openweather
                                            "pages": "all",
                    			module: "clock",
                                            "pages":{"главная": "top_left", "погода": "top_left", "почта": "top_left", "новости": "top_left", "календарь": "top_left", "фото": "top_left" },
                    			header: "US Holidays",
                    	                "pages": {"календарь": "upper-third"},
                    						symbol: "calendar-check-o ",
                    						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                            		module: "newsfeed",
                    			position: "bottom_bar",
                    			"pages": {"главная": "bottom_bar", "новости": "bottom_bar"},
                    				feeds: [
                    						title: "Финансовые новости MFD",
                    						url: "http://mfd.ru/rss/news/handler.ashx"
                    				showSourceTitle: true,
                    				showPublishDate: true
                    			"module": "MMM-Cursor",
                    • V Offline
                      Hey @Banandze,
                      I have added a lockstring so that modules cannot show themselves which was causing the issue where the weather module showed itself. Pull the new changes to fix that issue.
                      The issue with the module not showing on the weather page I cannot replicate, but it is most likely due to the position being set to left which is not a valid position in Magic Mirror. Refer to this this for a list of positions.
                      I am also unable to replicate the problem where the page switching does not work. When it fails to switch, is there any output to the console?
                      • rudibaraniR Offline
                        rudibarani Project Sponsor
                        Dear @Veldrovive,
                        thank you very much for this fantastic module! I am trying to use MMM-Remote-Control to control the currently shown page through notifications which are sent via HTTP from my home automation (FHEM), depending on who is in the bathroom.
                        These two calls work fine with MMM-Page-Selector: (I had to insert a space into the URL when pasting it here as “&n” is replaced with a newline character by this website")
                        http://192.0.0.60:8080/remote?action=NOTIFICATION& notification=PAGE_UP
                        http://192.0.0.60:8080/remote?action=NOTIFICATION& notification=PAGE_DOWN
                        But i am struggling to use SELECT_PAGE to go directly to a desired page.
                        http://192.0.0.60:8080/remote?action=NOTIFICATION& notification=SELECT_PAGE&payload={"test"}
                        This call returns {"status":"success"}, but does not show the page “test”. Do you have an idea, what I am doing wrong?
                        • V Offline
                          Hey @rudibarani,
                          Yea, that was completely on me. The new version should fix the issue. There was a really obvious bug that was stopping the PAGE_SELECT system from working. If it still does not work, make sure that the payload that is being sent is actually just the string name of the page and not an object.
                          rudibaraniR 1 Reply Last reply Reply Quote 0
                            rudibarani Project Sponsor @Veldrovive
                            @veldrovive Thank you very much for the quick fix! Now everything works like magic :man_mage:
                            I am putting a working example here for others, if they want to use MMM-Remote-Control with MMM-Page-Selector as well:
                            http://192.0.0.60:8080/remote?action=NOTIFICATION& notification=SELECT_PAGE&payload="test"
                            • V Offline
                              As an update, it is now possible to have your pages automatically rotate on a certain interval. Refer to usage and configuration in the Readme.
                                Banandze
                                @Veldrovive thank you for reply! I will check the changes on the weekend. What shall I use to make weather data more structure? I want one module upper than another. I put first one upper in config file and wrote “top_left” for both modules but they are shown in wrong way. And another question about not swithing, I didn’t understand your question exactly. I turn ii on and it works four times, then it doesn’t swith and my screen becomes slightly darker, then after few munites it works again fout times.
                                • V Offline
                                  @Banandze,
                                  I’m going to address the issue with the switching only working four times before shutting down. First, are you using pm2 to manage you mirror? If that is the case, try just starting it from a terminal instance so it does not automatically restart if it crashes.
                                  When I said “Is there any output to the console”, what I meant is, in the terminal window where you started magic mirror, is there any text that prints out when the issues start? Also, in your electron instance, in the top menu, when you click on view then toggle developer tools, it will bring up a window with a console in it. If there is anything in red there I would like to see it.
                                  What I am assuming is happening is that magic mirror itself is running out of resources and causing the issues.
                                  I am not quite certain what you mean by:
                                  “I put first one upper in config file and wrote “top_left” for both modules but they are shown in wrong way”
                                  Are you saying that you want one module to appear above another, but it is instead appearing below? If that is the case then I will need to see your config again to know exactly what you mean and attempt to fix the problem.
                                    Banandze
                                    @Veldrovive I will try it on the weekend. Yes, you ynderstand me with the problem of appearing. There is my config
                                    var config = {
                                    	port: 8080,
                                    	language: "ru",
                                    	timeFormat: 24,
                                    	units: "metric",
                                    			"config": {
                                                       "pages": "all",
                                                       pages: 6,
                                                       activeBright: true,
                                         			module: "alert",
                                                            "pages": "all",
                                    	        "pages": "all",
                                                             sensorPIN: 22,
                                                             powerSaving: true,
                                    		lat:        54.61972,
                                    		lon:        39.740002,
                                    		units:      'M',
                                    		lang:       'ru',
                                    		interval:   900000,
                                                    mode: "Natural",
                                                    MaxWidth: "50%",
                                                    MaxHeight: "50%",
                                                    colored: true,
                                                            "pages": "all",
                                    			module: "clock",
                                            		module: "newsfeed",
                                    				feeds: [
                                    • V Offline
                                      @Banandze,
                                      I’ll take a look at it. It is very possible that I made a mistake while refactoring and module precedence has been swapped.
                                      • V Offline
                                        Changes that edit the way users must set up their config.js file have been made to this module. The position prop is no longer necessary to have inside the module config and the way to exclusions are handled has changed. For more information, look at the updated readme in the development branch of the GitHub page.
                                        These changes will be merged into the master branch in a couple of days which will cause errors if your config is not updated.
                                          Dear @Veldrovive,
                                          would it be possible to add an option to make the current page persistent until the next page change?
                                          I have to use cases where this would help:
                                          • if the Pi restarts, the Mirror always shows the standard page - no matter what page was active before the restart.
                                          • if you open the Mirror on a browser (e.g. mobile phone), you always see the standard page until the next page change happens.
                                          In both cases, if would be great to see the currently “active” page. Maybe there is a way to store and restore the current page?
                                          Thanks a lot for your active development of the module!
                                          • V Offline
                                            Persistent properties such as those could be achieved through a temp file so definitely something that could be implemented.
                                            My reading week is over so I don’t have as much time to do development now, but I’ll get it done in some free time.
                                            • 2 / 5
