    MMM-Page-Selector: A page switcher that can set positions of modules
    94 Posts 14 Posters 93.8k Views 15 Watching
    • rudibaraniR Offline
      rudibarani Project Sponsor
      Dear @Veldrovive,
      I have reduced my config file to very few modules but my MagicMirror keeps restarting every few seconds. That does not happen, if I stick with the “old” style of configuring Pages within MagicMirror. It seems, I make a general mistake with the way, the second Page setup should be done.
      Would you mind having a look, why this slimmed down version does not work?
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
        address: '0.0.0.0', // Address to listen on, can be:
        // - 'localhost', '127.0.0.1', '::1' to listen on loopback interface
        // - '', '0.0.0.0', '::' to listen on any interface
        // Default, when address config is left out, is 'localhost'
        port: 8080,
        ipWhitelist: [
          '127.0.0.1',
          '::ffff:127.0.0.1',
          '::1',
          ['192.0.0.60', '192.0.0.189']
        ], // Set [] to allow all IP addresses
        // ['127.0.0.1', '::ffff:127.0.0.1', '::1', '::ffff:192.168.1.5'],
        // ['127.0.0.1', '::ffff:127.0.0.1', '::1', '::ffff:192.168.3.0/28'],
        language: 'de',
        timeFormat: 24,
        units: 'metric',
        customCss: 'css/custom.css',
            module: 'MMM-Page-Selector',
            position: 'top_bar',
              defaultPage: 'tag', // Tag
              displayTitle: true, // disable in production mode
              persistentPages: true,
              selectPageNotif: ['SELECT_PAGE'],
              incrementPageNotif: ['PAGE_UP'],
              decrementPageNotif: ['PAGE_DOWN']
            module: 'alert',
            disabled: false,
            config: {}
            module: 'MMM-WatchDog',
            disabled: false,
            module: 'MMM-Remote-Control',
            disabled: false
            module: 'MMM-Remote-Control-Repository',
            disabled: false
            module: 'updatenotification',
            disabled: false
            module: 'MMM-Snow',
            disabled: true, // final: set to false, hide in Remote Control & Save
              flakeCount: 111,
              theme: 'winter' // Possible values are winter, love, and water
            module: 'MMM-Love',
              flakeCount: 111,
              theme: 'love' // Possible values are winter, love, and water
            module: 'MMM-ip',
            disabled: false,
            config: {}
            module: 'clock',
            disabled: false,
              clockBold: false,
              displaySeconds: false,
              dateFormat: 'dddd, ll'
            module: 'MMM-TextClock',
            disabled: false,
              layout: 'Field', // options are 'Line' and 'Field'
              its24: 'ES IST', // text before hour
              to24: ' ', // text between hour and minute
              after24: 'UHR', // text after minute
              marked: 'color: white; font-weight: 400;', // css code to mark current time in Field layout
              offset: 2 // standard: 2
            module: 'newsfeed',
            disabled: false,
              // The config property is optional.
              // If no config is set, an example calendar is shown.
              feeds: [
                  title: 'Tagesschau',
                  url: 'http://www.tagesschau.de/xml/rss2'
        ], // top_bar, top_left, top_center, top_right, upper_third, middle_center, lower_third, bottom_left, bottom_center, bottom_right, bottom_bar, fullscreen_above, and fullscreen_below
        pages: {
          tag: {
            'clock': 'bottom_left',
            'newsfeed': 'bottom_bar'
          abend: {
          nacht: {
            'MMM-TextClock': 'bottom_center' // Bottom Center nur für MMM-TextClock verwenden. CSS verändert!!!
          wochenende: {
          annika: {
          phillip: {
            'updatenotification': 'top_bar',
          kinder: {
            'newsfeed': 'bottom_left'
          system: {
            'updatenotification': 'bottom_bar',
            'MMM-ip': 'bottom_right',
            'MMM-Remote-Control': 'bottom_right' // uncomment the following line to show the URL of the remote control on the mirror
          test: {
        exclusions: {
      /** ************* DO NOT EDIT THE LINE BELOW ***************/
      if (typeof module !== 'undefined') {
        module.exports = config;
        robiv8
        I guess it’s the MM-WatchDog module
        Check that out
        MMM-WatchDog module keeps an eye on your UI and quits app in case the UI crashes. If you combine this with the PM2 process manager, MM2 will automaticly restart after a UI failure.
        So you said: “my MagicMirror keeps restarting every few seconds.”
        • V Offline
          Veldrovive Module Developer
          Yep, I can verify that it is in fact WatchDog.
          I can also provide an explanation and a patch that you can do yourself. The way I made it possible to not include the position prop anymore is by building a temporary config, loading that one, restarting magic mirror, and then replacing the temporary with the original. I’m really sure of the underlying reason, but this process seems to trigger WatchDog to trigger an abort.
          As robiv says, combined with pm2, this causes a restart loop.
          The two easiest ways to get around this are:
          1. Don’t use watchdog. If you don’t think that you are going to experience crashes, then that works
          2. Give a position prop to every module. Including position props doesn’t change any of the visual function and that way, Page-Selector never triggers a restart and the problem doesn’t occur in the first place. The config for any given module should follow this format:
              module: 'MMM-module-name',
              position: 'any_position' //It doesn't matter what it is
              disabled: false,
          I will try to find a way to make the modules play well together, but that might take a while.
          rudibaraniR 2 Replies Last reply Reply Quote 0
            robiv8
            Hallo Veldrovive,
            I just asked you a question on GitHub about Button.
            Should I write this here or on GitHub? Where do you prefer it?
            • V Offline
              Hey robiv,
              I do actually prefer to have issues opened on GitHub. That way I can more easily keep track of them and also it provides a record of my work in case I want to use it in order to prove my merit.
              Thanks for asking.
                robiv8
                OK Thanks.
                It’s not really an issue, its a question about Button with Selector Howto ;-)
                  rudibarani Project Sponsor @Veldrovive
                  @veldrovive @robiv8 Thank you two for the quick feedback and nailing it down so quickly.
                  I will disable Watchdog for the time being. I was using it as I experienced crashes when using an iFrame module for video playback (ISS livestream on my night-page). But it should be OK to live without that for a while.
                    @veldrovive said in MMM-Page-Selector: A page switcher that can set positions of modules:
                    Ok, I’ve implemented persistent pages. In order to access them right now, you need to be in the development branch since I don’t have the time to do extensive testing.
                    Thanks again for the persistent pages feature. I have tried it all day in different scenarios and it was working reliably and as expected. :clapping_hands:
                      @veldrovive PS: I tried following your workaround and just wanted to let you know that it works :) Now I am able to use your new config option for pages which makes it so much easier to set them up! Great idea to implement it!
                      • V Offline
                        @rudibarani
                        Good stuff. I’m glad everything is working out.
                        rudibaraniR 1 Reply Last reply Reply Quote 0
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 6 / 10
