    MMM-Page-Selector: A page switcher that can set positions of modules
    94 Posts 14 Posters 100.1k Views 15 Watching
      Brandenborg @Veldrovive
      @Veldrovive thanks a lot. I should manage that.
      I recon the 0 position is the first page I define the contents of?
      • V Offline
        Veldrovive Module Developer @Brandenborg
        @Brandenborg
        The 0 should be the position of your default page in the page list. The furthest left is 0.
          @Veldrovive
          Thanks. And thank you for a really useful module!
          • V Offline
            @Brandenborg
            The latest version of this module now has this as a (Not very well tested) feature.
            You can now specify a restoreDefault prop in the MMM-Page-Selector config with the number of seconds you want before it returns to the default page.
              m1scha
              Hi first of all thanks for this great module, Works great. I wanto to remotely change the pages which works with this commands:
              http://ip:8080/remote?action=NOTIFICATION&notification=PAGE_DOWN
              http://ip:8080/remote?action=NOTIFICATION&notification=PAGE_UP
              But if I want to go to a specific page it does noct work with this command:
              http://ip:8080/remote?action=NOTIFICATION&notification="SELECT_PAGE"&payload="0"
              Can somebody tell me whats wrong?
              • V Offline
                Veldrovive Module Developer @m1scha
                @m1scha
                Hello, glad you’re enjoying the module.
                I am assuming that your page has some name that is not "0".
                I haven’t extensively tested with magic mirror remote, but I imagine the issue is with setting payload to be a string. When it gets a string, MMM-Page-Selector assumes it is the name of the page, not a page index. If an integer is sent, it assumes it is a page index.
                I don’t know how remote works, but you might be able to use
                http://ip:8080/remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=0
                Or you could specify your page name as
                http://ip:8080/remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=“YOUR_PAGE_NAME”
                  m1scha @Veldrovive
                  @veldrovive said in MMM-Page-Selector: A page switcher that can set positions of modules:
                  Hi, thanks for you reply.
                  I tested this in several variations, but I get a sucess Message, but change of page.
                  • V Offline
                    @m1scha
                    I checked out MMM-Remote-Control and it is just a problem with string representations.
                    remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=0 sends the literal notification “SELECT_PAGE” including the quotes. A more correct request would be remote?action=NOTIFICATION&notification=SELECT_PAGE&payload=Main which would switch the the page called main.
                    However, in order to support other modules, pages are 1 indexed by notification so to switch to the first page, you would send remote?action=NOTIFICATION&notification=SELECT_PAGE&payload=1
                    Strings that are numbers are handled correctly by MMM-Page-Selector.
                    • I Offline
                      innovation @Veldrovive
                      @veldrovive Hello! I want to use this module for
                      1. An intro screen - only for 10 secs
                      2. Move into screen 2 - stay there
                      Can I only have one screen to have a time interval and the other doesn’t? If so how?
                        Riaanh
                        Good day @Veldrovive thanks for the brilliant work you have done on this, and your comments on this is really helpful.
                        I have an issue to get this going, and been researching and trying for the past two days with no success. I even tried using some of the users on this thread’s config as posted here, and loaded the modules they refer to, but I always end up with a blank page once I load the portion for MMM-Page-Selector.
                        As soon as I add this portion below, it only display a blank page, or if I comment it out, then the page will display again.
                        			disabled: false,
                        		        module: "MMM-Page-Selector",
                        		        position: "top_bar",
                        			        defaultPage: "Page1",
                        		                displayTitle: true,
                        			        selectPageNotif: ["SELECT_PAGE"],
                        		                incrementPageNotif: ["PAGE_UP"],
                        		                decrementPageNotif: ["PAGE_DOWN"],
                        Any advice or even just guidance on where to look further would be greatly appreciated.
                          sdetweil @Riaanh
                          @Riaanh said in MMM-Page-Selector: A page switcher that can set positions of modules:
                          MMM-Page-Selector
                          can u show the messages from where u start MagicMirror
                          either npm start
                          or pm2
                          if using pm2,. then
                          pm2 logs --lines=100
                          will show the messages
                          blank screen is usually a missing library , see
                            Riaanh @sdetweil
                            @sdetweil said in MMM-Page-Selector: A page switcher that can set positions of modules:
                            0 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                            1 info using npm@7.5.2
                            2 info using node@v12.22.5
                            3 timing config:load:defaults Completed in 4ms
                            4 timing config:load:file:/usr/share/nodejs/npm/npmrc Completed in 7ms
                            5 timing config:load:builtin Completed in 8ms
                            6 timing config:load:cli Completed in 4ms
                            7 timing config:load:env Completed in 1ms
                            8 timing config:load:file:/home/pi/magicmirror/mounts/modules/.npmrc Completed in 1ms
                            9 timing config:load:project Completed in 3ms
                            10 timing config:load:file:/home/pi/.npmrc Completed in 0ms
                            11 timing config:load:user Completed in 0ms
                            12 timing config:load:file:/etc/npmrc Completed in 0ms
                            13 timing config:load:global Completed in 0ms
                            14 timing config:load:cafile Completed in 1ms
                            15 timing config:load:validate Completed in 1ms
                            16 timing config:load:setUserAgent Completed in 2ms
                            17 timing config:load:setEnvs Completed in 2ms
                            18 timing config:load Completed in 29ms
                            19 verbose npm-session 72db9025016605ec
                            20 timing npm:load Completed in 58ms
                            21 timing command:run-script Completed in 45ms
                            22 timing command:start Completed in 59ms
                            23 verbose stack Error: missing script: start
                            23 verbose stack     at runScript (/usr/share/nodejs/npm/lib/run-script.js:54:11)
                            24 verbose cwd /home/pi/magicmirror/mounts/modules
                            25 verbose Linux 5.10.92-v7l+
                            26 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                            27 verbose node v12.22.5
                            28 verbose npm  v7.5.2
                            29 error missing script: start
                            30 verbose exit 1
                            Thanks for responding, is this what you are referring to?
                              sdetweil @Riaanh
                              @Riaanh how do you start MagicMirror normally?
                                sdetweil @Riaanh
                                @Riaanh this looks like being started under docker
                                • 5 / 5
