    MMM-Page-Selector: A page switcher that can set positions of modules
    94 Posts 14 Posters 109.5k Views 15 Watching
    • rudibaraniR
      rudibarani Project Sponsor @Veldrovive
      @veldrovive
      Thanks again for implementing the current page as “dynamic” class. If I get it right, you had to code procedures to add and remove the page class when switching pages.
      Ok, the development branch now has support for the new class name changes. When a module is shown on a page, it will be given the class page_{Current Page} and then the class will be removed when the module is hidden.
      Would it be possible to make these procedures accessible via notifications? I am still looking for a way to add and remove classes based on external triggers. A scheme could be like this:
      Notification: "MMM_Page-Selector_Update_Class"
      Payload: {"add":["Module_1_Name:ClassA_to_add", "Module_2_Name:ClassB_to_add"], "remove":["Module_3_Name:ClassC_to_remove", "Module_4_Name:ClassD_to_remove"]}
      • V
        Veldrovive Module Developer
        @rudibarani
        If I am understanding what you are asking for correctly, this function seems to be out of the scope that Page-Selector encompasses. I would develop a module to include this functionality, but I have been inactive in the world of Magic Mirror as of lately. As it stands, I would post this request to the module suggestions forum or ask somebody to include it in a module that has a closer association with this type of purpose. MMM-Remote-Control could be a good candidate.
        rudibaraniR 1 Reply Last reply
        • rudibaraniR
          @veldrovive
          OK - thanks for the reply anyway!
            smarthome @rudibarani
            Hi all
            To make MMM-page-indicator work with MMM-Page-Selector, we must add MMM-page-indicator in to pages
            			module: "MMM-page-indicator",
            			position: "bottom_bar",
            			"pages": {"Home": "bottom_bar", "News": "bottom_bar","Weather": "bottom_bar","Entertaiment": "bottom_bar","Smarthome": "bottom_bar","System": "bottom_bar"},
            			pages: 6,
              smarthome @Johans
              @Johans
              pages: "all",
              You forgot the quotation mark before and after pages
              "pages": "all",
                Brandenborg
                I love this module especially in use together with the MMM-navbar.
                Is there any config using existing code that will let me make it return me to “default” page after a given period of time after changing page?
                V 1 Reply Last reply
                • V
                  Veldrovive Module Developer @Brandenborg
                  @Brandenborg
                  This is not a default function of this module. However, if you can edit a small amount of code, it should be easy to implement.
                  Just copy these lines of code right after line 235 of MMM-Page-Selector.js. This lines should be selectPage(payload);
                  clearTimeout(self.default_timeout);
                  if(![0, this.config.defaultPage].includes(payload)){
                      self.default_timeout = setTimeout(() => {
                          selectPage(this.config.defaultPage);
                      }, TIME)
                  Then just replace TIME with the number of milliseconds you want to remain on the page before it automatically switches back to default. You may also have to change the 0 in the if statement if your default page isn’t at the 0th position.
                  B 1 Reply Last reply
                    Brandenborg @Veldrovive
                    @Veldrovive thanks a lot. I should manage that.
                    I recon the 0 position is the first page I define the contents of?
                    • V
                      @Brandenborg
                      The 0 should be the position of your default page in the page list. The furthest left is 0.
                        @Veldrovive
                        Thanks. And thank you for a really useful module!
                        • V
                          @Brandenborg
                          The latest version of this module now has this as a (Not very well tested) feature.
                          You can now specify a restoreDefault prop in the MMM-Page-Selector config with the number of seconds you want before it returns to the default page.
                            m1scha
                            Hi first of all thanks for this great module, Works great. I wanto to remotely change the pages which works with this commands:
                            http://ip:8080/remote?action=NOTIFICATION&notification=PAGE_DOWN
                            http://ip:8080/remote?action=NOTIFICATION&notification=PAGE_UP
                            But if I want to go to a specific page it does noct work with this command:
                            http://ip:8080/remote?action=NOTIFICATION&notification="SELECT_PAGE"&payload="0"
                            Can somebody tell me whats wrong?
                            • V
                              Veldrovive Module Developer @m1scha
                              @m1scha
                              Hello, glad you’re enjoying the module.
                              I am assuming that your page has some name that is not "0".
                              I haven’t extensively tested with magic mirror remote, but I imagine the issue is with setting payload to be a string. When it gets a string, MMM-Page-Selector assumes it is the name of the page, not a page index. If an integer is sent, it assumes it is a page index.
                              I don’t know how remote works, but you might be able to use
                              http://ip:8080/remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=0
                              Or you could specify your page name as
                              http://ip:8080/remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=“YOUR_PAGE_NAME”
                              M 1 Reply Last reply
                                m1scha @Veldrovive
                                @veldrovive said in MMM-Page-Selector: A page switcher that can set positions of modules:
                                Hi, thanks for you reply.
                                I tested this in several variations, but I get a sucess Message, but change of page.
                                • V
                                  @m1scha
                                  I checked out MMM-Remote-Control and it is just a problem with string representations.
                                  remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=0 sends the literal notification “SELECT_PAGE” including the quotes. A more correct request would be remote?action=NOTIFICATION&notification=SELECT_PAGE&payload=Main which would switch the the page called main.
                                  However, in order to support other modules, pages are 1 indexed by notification so to switch to the first page, you would send remote?action=NOTIFICATION&notification=SELECT_PAGE&payload=1
                                  Strings that are numbers are handled correctly by MMM-Page-Selector.
                                  • I
                                    innovation @Veldrovive
                                    @veldrovive Hello! I want to use this module for
                                    1. An intro screen - only for 10 secs
                                    2. Move into screen 2 - stay there
                                    Can I only have one screen to have a time interval and the other doesn’t? If so how?
                                      Riaanh
                                      Good day @Veldrovive thanks for the brilliant work you have done on this, and your comments on this is really helpful.
                                      I have an issue to get this going, and been researching and trying for the past two days with no success. I even tried using some of the users on this thread’s config as posted here, and loaded the modules they refer to, but I always end up with a blank page once I load the portion for MMM-Page-Selector.
                                      As soon as I add this portion below, it only display a blank page, or if I comment it out, then the page will display again.
                                      			disabled: false,
                                      		        module: "MMM-Page-Selector",
                                      		        position: "top_bar",
                                      			        defaultPage: "Page1",
                                      		                displayTitle: true,
                                      			        selectPageNotif: ["SELECT_PAGE"],
                                      		                incrementPageNotif: ["PAGE_UP"],
                                      		                decrementPageNotif: ["PAGE_DOWN"],
                                      Any advice or even just guidance on where to look further would be greatly appreciated.
                                        sdetweil @Riaanh
                                        @Riaanh said in MMM-Page-Selector: A page switcher that can set positions of modules:
                                        MMM-Page-Selector
                                        can u show the messages from where u start MagicMirror
                                        either npm start
                                        or pm2
                                        if using pm2,. then
                                        pm2 logs --lines=100
                                        will show the messages
                                        blank screen is usually a missing library , see
                                          Riaanh @sdetweil
                                          @sdetweil said in MMM-Page-Selector: A page switcher that can set positions of modules:
                                          0 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                                          1 info using npm@7.5.2
                                          2 info using node@v12.22.5
                                          3 timing config:load:defaults Completed in 4ms
                                          4 timing config:load:file:/usr/share/nodejs/npm/npmrc Completed in 7ms
                                          5 timing config:load:builtin Completed in 8ms
                                          6 timing config:load:cli Completed in 4ms
                                          7 timing config:load:env Completed in 1ms
                                          8 timing config:load:file:/home/pi/magicmirror/mounts/modules/.npmrc Completed in 1ms
                                          9 timing config:load:project Completed in 3ms
                                          10 timing config:load:file:/home/pi/.npmrc Completed in 0ms
                                          11 timing config:load:user Completed in 0ms
                                          12 timing config:load:file:/etc/npmrc Completed in 0ms
                                          13 timing config:load:global Completed in 0ms
                                          14 timing config:load:cafile Completed in 1ms
                                          15 timing config:load:validate Completed in 1ms
                                          16 timing config:load:setUserAgent Completed in 2ms
                                          17 timing config:load:setEnvs Completed in 2ms
                                          18 timing config:load Completed in 29ms
                                          19 verbose npm-session 72db9025016605ec
                                          20 timing npm:load Completed in 58ms
                                          21 timing command:run-script Completed in 45ms
                                          22 timing command:start Completed in 59ms
                                          23 verbose stack Error: missing script: start
                                          23 verbose stack     at runScript (/usr/share/nodejs/npm/lib/run-script.js:54:11)
                                          24 verbose cwd /home/pi/magicmirror/mounts/modules
                                          25 verbose Linux 5.10.92-v7l+
                                          26 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                                          27 verbose node v12.22.5
                                          28 verbose npm  v7.5.2
                                          29 error missing script: start
                                          30 verbose exit 1
                                          Thanks for responding, is this what you are referring to?
                                          S 2 Replies Last reply
                                            sdetweil @Riaanh
                                            @Riaanh how do you start MagicMirror normally?
                                            • 5 / 5
