    MMM-Page-Selector: A page switcher that can set positions of modules
    94 Posts 14 Posters 108.0k Views 15 Watching
    • rudibaraniR
      rudibarani Project Sponsor
      Dear @Veldrovive,
      oh - I have to run and hide somewhere. I did forget to clone the development branch when setting up the Mac Mini. Sorry for bothering you with this :unamused_face:
      As always, if you do things right, they work :smiling_face_with_smiling_eyes:
      You said you it would be a quick change to update the class list to contain the current page. If you have time to add this, it would help me a lot!
      • V
        Veldrovive Module Developer
        Ah right. I need to get around to making those changes. I’ll start on them in the morning.
        • V
          @rudibarani,
          Ok, the development branch now has support for the new class name changes. When a module is shown on a page, it will be given the class page_{Current Page} and then the class will be removed when the module is hidden.
          rudibaraniR 1 Reply Last reply Reply Quote 0
            Johans @Veldrovive
            @veldrovive
            Hi, just made a fresh install, and applied your module and MMM-Page-indicator.
            Pages are shown, but page indicator and newsfeed module are not on the screen.
            When I disbable MMM-Page-Selector, then Newsfeed & MMM-Page-indicator are visisble.
            As far as I understand, config is OK
            			module: "alert",
            			pages: "all",
            			disabled: false,
            		        module: "MMM-Page-Selector",
            		        position: "top_bar",
            			        defaultPage: "Page1",
            		                displayTitle: true,
            			        selectPageNotif: ["SELECT_PAGE"],
            		                incrementPageNotif: ["PAGE_UP"],
            		                decrementPageNotif: ["PAGE_DOWN"],
               			        autoChange: {
            				     	    interval: 100,    // Change page every 100 sec
            			module: "updatenotification",
            			pages: {"Page1": "top_bar"},
            			module: "clock",
            			pages: {"Page1": "top_left", "Page2": "top_left", "Page3": "top_left", "Page4": "top_left"},
            			module: "compliments",
            			position: "lower_third",
            			pages: {"Page1": "lower_third", "Page2": "lower_third", "Page3": "lower_third", "Page4": "lower_third"},
            		        disabled: false,
            			module: "MMM-rain-forecast",
            			position: "top_right",   // see mirror setting for options
            			pages: {"Page1": "top_right"},
            			//header: "Regen Voorspelling",
            		                lat: 50.908529,
            		                lon: 3.965639,
            				pleaseWait: "Wachten a.u.b",
            				noRainText: "Tot %s GEEN regen",
            				fillColour: '#0074d9'   // This is a blue color you can also use blue, cyan etc
            			module: "newsfeed",
            			position: "bottom_bar",
            			pages: "all",
            				feeds: [
            						title: "New York Times",
            				showSourceTitle: true,
            				showPublishDate: true
            			disabled: false,
            		        module: "MMM-page-indicator",
            			pages: "all",
            		            //pages: 4,  // No need to set this
            			module: 'MMM-Cursor',
            			pages: "all",
            • V
              @Johans,
              Ah, I believe the confusion comes from the fact that old discussions on this forum do not reflect the current functionality of the module. I try not to make any changes that break old config files, but one was necessary.
              In order to fix this config, you need to replace any instance of pages: "all" with pages: {"all": "some_position"}
              New versions don’t require you to have a position prop at all and you can just use the pages one.
              For more information, refer to the README.
              Hope this helps.
                Johans @Veldrovive
                @veldrovive said in MMM-Page-Selector: A page switcher that can set positions of modules:
                pages: {“all”: “some_position”}
                Thanks for the info, I should have read the README first. Sorry.
                • rudibaraniR
                  rudibarani Project Sponsor @Veldrovive
                  @veldrovive
                  Thanks again for implementing the current page as “dynamic” class. If I get it right, you had to code procedures to add and remove the page class when switching pages.
                  Would it be possible to make these procedures accessible via notifications? I am still looking for a way to add and remove classes based on external triggers. A scheme could be like this:
                  Notification: "MMM_Page-Selector_Update_Class"
                  Payload: {"add":["Module_1_Name:ClassA_to_add", "Module_2_Name:ClassB_to_add"], "remove":["Module_3_Name:ClassC_to_remove", "Module_4_Name:ClassD_to_remove"]}
                  • V
                    @rudibarani
                    If I am understanding what you are asking for correctly, this function seems to be out of the scope that Page-Selector encompasses. I would develop a module to include this functionality, but I have been inactive in the world of Magic Mirror as of lately. As it stands, I would post this request to the module suggestions forum or ask somebody to include it in a module that has a closer association with this type of purpose. MMM-Remote-Control could be a good candidate.
                    • rudibaraniR
                      @veldrovive
                      OK - thanks for the reply anyway!
                        smarthome @rudibarani
                        Hi all
                        To make MMM-page-indicator work with MMM-Page-Selector, we must add MMM-page-indicator in to pages
                        			"pages": {"Home": "bottom_bar", "News": "bottom_bar","Weather": "bottom_bar","Entertaiment": "bottom_bar","Smarthome": "bottom_bar","System": "bottom_bar"},
                        			pages: 6,
                          smarthome @Johans
                          @Johans
                          pages: "all",
                          You forgot the quotation mark before and after pages
                          "pages": "all",
                            Brandenborg
                            I love this module especially in use together with the MMM-navbar.
                            Is there any config using existing code that will let me make it return me to “default” page after a given period of time after changing page?
                            • V
                              Veldrovive Module Developer @Brandenborg
                              @Brandenborg
                              This is not a default function of this module. However, if you can edit a small amount of code, it should be easy to implement.
                              Just copy these lines of code right after line 235 of MMM-Page-Selector.js. This lines should be selectPage(payload);
                              clearTimeout(self.default_timeout);
                              if(![0, this.config.defaultPage].includes(payload)){
                                  self.default_timeout = setTimeout(() => {
                                      selectPage(this.config.defaultPage);
                                  }, TIME)
                              Then just replace TIME with the number of milliseconds you want to remain on the page before it automatically switches back to default. You may also have to change the 0 in the if statement if your default page isn’t at the 0th position.
                                Brandenborg @Veldrovive
                                @Veldrovive thanks a lot. I should manage that.
                                I recon the 0 position is the first page I define the contents of?
                                • V
                                  @Brandenborg
                                  The 0 should be the position of your default page in the page list. The furthest left is 0.
                                    @Veldrovive
                                    Thanks. And thank you for a really useful module!
                                    • V
                                      @Brandenborg
                                      The latest version of this module now has this as a (Not very well tested) feature.
                                      You can now specify a restoreDefault prop in the MMM-Page-Selector config with the number of seconds you want before it returns to the default page.
                                        m1scha
                                        Hi first of all thanks for this great module, Works great. I wanto to remotely change the pages which works with this commands:
                                        http://ip:8080/remote?action=NOTIFICATION&notification=PAGE_DOWN
                                        http://ip:8080/remote?action=NOTIFICATION&notification=PAGE_UP
                                        But if I want to go to a specific page it does noct work with this command:
                                        http://ip:8080/remote?action=NOTIFICATION&notification="SELECT_PAGE"&payload="0"
                                        Can somebody tell me whats wrong?
                                        • V
                                          Veldrovive Module Developer @m1scha
                                          @m1scha
                                          Hello, glad you’re enjoying the module.
                                          I am assuming that your page has some name that is not "0".
                                          I haven’t extensively tested with magic mirror remote, but I imagine the issue is with setting payload to be a string. When it gets a string, MMM-Page-Selector assumes it is the name of the page, not a page index. If an integer is sent, it assumes it is a page index.
                                          I don’t know how remote works, but you might be able to use
                                          http://ip:8080/remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=0
                                          Or you could specify your page name as
                                          http://ip:8080/remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=“YOUR_PAGE_NAME”
                                            m1scha @Veldrovive
                                            Hi, thanks for you reply.
                                            I tested this in several variations, but I get a sucess Message, but change of page.
                                            • 4 / 5
