    MMM-Page-Selector: A page switcher that can set positions of modules
    94 Posts 14 Posters 108.0k Views 15 Watching
    • V
      Veldrovive Module Developer
      Ah right. I need to get around to making those changes. I’ll start on them in the morning.
      • V
        @rudibarani,
        Ok, the development branch now has support for the new class name changes. When a module is shown on a page, it will be given the class page_{Current Page} and then the class will be removed when the module is hidden.
        rudibaraniR 1 Reply Last reply Reply Quote 0
          Johans @Veldrovive
          @veldrovive
          Hi, just made a fresh install, and applied your module and MMM-Page-indicator.
          Pages are shown, but page indicator and newsfeed module are not on the screen.
          When I disbable MMM-Page-Selector, then Newsfeed & MMM-Page-indicator are visisble.
          As far as I understand, config is OK
          			module: "alert",
          			pages: "all",
          			disabled: false,
          		        module: "MMM-Page-Selector",
          		        position: "top_bar",
          			        defaultPage: "Page1",
          		                displayTitle: true,
          			        selectPageNotif: ["SELECT_PAGE"],
          		                incrementPageNotif: ["PAGE_UP"],
          		                decrementPageNotif: ["PAGE_DOWN"],
             			        autoChange: {
          				     	    interval: 100,    // Change page every 100 sec
          			module: "updatenotification",
          			pages: {"Page1": "top_bar"},
          			module: "clock",
          			pages: {"Page1": "top_left", "Page2": "top_left", "Page3": "top_left", "Page4": "top_left"},
          			module: "compliments",
          			position: "lower_third",
          			pages: {"Page1": "lower_third", "Page2": "lower_third", "Page3": "lower_third", "Page4": "lower_third"},
          		        disabled: false,
          			module: "MMM-rain-forecast",
          			position: "top_right",   // see mirror setting for options
          			pages: {"Page1": "top_right"},
          			//header: "Regen Voorspelling",
          		                lat: 50.908529,
          		                lon: 3.965639,
          				pleaseWait: "Wachten a.u.b",
          				noRainText: "Tot %s GEEN regen",
          				fillColour: '#0074d9'   // This is a blue color you can also use blue, cyan etc
          			module: "newsfeed",
          			position: "bottom_bar",
          			pages: "all",
          				feeds: [
          						title: "New York Times",
          				showSourceTitle: true,
          				showPublishDate: true
          			disabled: false,
          		        module: "MMM-page-indicator",
          			pages: "all",
          		            //pages: 4,  // No need to set this
          			module: 'MMM-Cursor',
          			pages: "all",
          • V
            @Johans,
            Ah, I believe the confusion comes from the fact that old discussions on this forum do not reflect the current functionality of the module. I try not to make any changes that break old config files, but one was necessary.
            In order to fix this config, you need to replace any instance of pages: "all" with pages: {"all": "some_position"}
            New versions don’t require you to have a position prop at all and you can just use the pages one.
            For more information, refer to the README.
            Hope this helps.
              Johans @Veldrovive
              @veldrovive said in MMM-Page-Selector: A page switcher that can set positions of modules:
              pages: {“all”: “some_position”}
              Thanks for the info, I should have read the README first. Sorry.
              • rudibaraniR
                rudibarani Project Sponsor @Veldrovive
                @veldrovive
                Thanks again for implementing the current page as “dynamic” class. If I get it right, you had to code procedures to add and remove the page class when switching pages.
                Would it be possible to make these procedures accessible via notifications? I am still looking for a way to add and remove classes based on external triggers. A scheme could be like this:
                Notification: "MMM_Page-Selector_Update_Class"
                Payload: {"add":["Module_1_Name:ClassA_to_add", "Module_2_Name:ClassB_to_add"], "remove":["Module_3_Name:ClassC_to_remove", "Module_4_Name:ClassD_to_remove"]}
                • V
                  @rudibarani
                  If I am understanding what you are asking for correctly, this function seems to be out of the scope that Page-Selector encompasses. I would develop a module to include this functionality, but I have been inactive in the world of Magic Mirror as of lately. As it stands, I would post this request to the module suggestions forum or ask somebody to include it in a module that has a closer association with this type of purpose. MMM-Remote-Control could be a good candidate.
                  • rudibaraniR
                    @veldrovive
                    OK - thanks for the reply anyway!
                      smarthome @rudibarani
                      Hi all
                      To make MMM-page-indicator work with MMM-Page-Selector, we must add MMM-page-indicator in to pages
                      			"pages": {"Home": "bottom_bar", "News": "bottom_bar","Weather": "bottom_bar","Entertaiment": "bottom_bar","Smarthome": "bottom_bar","System": "bottom_bar"},
                      			pages: 6,
                        smarthome @Johans
                        @Johans
                        pages: "all",
                        You forgot the quotation mark before and after pages
                        "pages": "all",
                          Brandenborg
                          I love this module especially in use together with the MMM-navbar.
                          Is there any config using existing code that will let me make it return me to “default” page after a given period of time after changing page?
                          • V
                            Veldrovive Module Developer @Brandenborg
                            @Brandenborg
                            This is not a default function of this module. However, if you can edit a small amount of code, it should be easy to implement.
                            Just copy these lines of code right after line 235 of MMM-Page-Selector.js. This lines should be selectPage(payload);
                            clearTimeout(self.default_timeout);
                            if(![0, this.config.defaultPage].includes(payload)){
                                self.default_timeout = setTimeout(() => {
                                    selectPage(this.config.defaultPage);
                                }, TIME)
                            Then just replace TIME with the number of milliseconds you want to remain on the page before it automatically switches back to default. You may also have to change the 0 in the if statement if your default page isn’t at the 0th position.
                              Brandenborg @Veldrovive
                              @Veldrovive thanks a lot. I should manage that.
                              I recon the 0 position is the first page I define the contents of?
                              • V
                                @Brandenborg
                                The 0 should be the position of your default page in the page list. The furthest left is 0.
                                  @Veldrovive
                                  Thanks. And thank you for a really useful module!
                                  • V
                                    @Brandenborg
                                    The latest version of this module now has this as a (Not very well tested) feature.
                                    You can now specify a restoreDefault prop in the MMM-Page-Selector config with the number of seconds you want before it returns to the default page.
                                      m1scha
                                      Hi first of all thanks for this great module, Works great. I wanto to remotely change the pages which works with this commands:
                                      http://ip:8080/remote?action=NOTIFICATION&notification=PAGE_DOWN
                                      http://ip:8080/remote?action=NOTIFICATION&notification=PAGE_UP
                                      But if I want to go to a specific page it does noct work with this command:
                                      http://ip:8080/remote?action=NOTIFICATION&notification="SELECT_PAGE"&payload="0"
                                      Can somebody tell me whats wrong?
                                      • V
                                        Veldrovive Module Developer @m1scha
                                        @m1scha
                                        Hello, glad you’re enjoying the module.
                                        I am assuming that your page has some name that is not "0".
                                        I haven’t extensively tested with magic mirror remote, but I imagine the issue is with setting payload to be a string. When it gets a string, MMM-Page-Selector assumes it is the name of the page, not a page index. If an integer is sent, it assumes it is a page index.
                                        I don’t know how remote works, but you might be able to use
                                        http://ip:8080/remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=0
                                        Or you could specify your page name as
                                        http://ip:8080/remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=“YOUR_PAGE_NAME”
                                          m1scha @Veldrovive
                                          Hi, thanks for you reply.
                                          I tested this in several variations, but I get a sucess Message, but change of page.
                                          • V
                                            @m1scha
                                            I checked out MMM-Remote-Control and it is just a problem with string representations.
                                            remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=0 sends the literal notification “SELECT_PAGE” including the quotes. A more correct request would be remote?action=NOTIFICATION&notification=SELECT_PAGE&payload=Main which would switch the the page called main.
                                            However, in order to support other modules, pages are 1 indexed by notification so to switch to the first page, you would send remote?action=NOTIFICATION&notification=SELECT_PAGE&payload=1
                                            Strings that are numbers are handled correctly by MMM-Page-Selector.
                                            • 4 / 5
