    MMM-Page-Selector: A page switcher that can set positions of modules
    94 Posts 14 Posters 106.4k Views 15 Watching
    • V
      Veldrovive Module Developer
      @rudibarani
      If I am understanding what you are asking for correctly, this function seems to be out of the scope that Page-Selector encompasses. I would develop a module to include this functionality, but I have been inactive in the world of Magic Mirror as of lately. As it stands, I would post this request to the module suggestions forum or ask somebody to include it in a module that has a closer association with this type of purpose. MMM-Remote-Control could be a good candidate.
      rudibaraniR 1 Reply Last reply Reply Quote 0
      • rudibaraniR
        rudibarani Project Sponsor @Veldrovive
        @veldrovive
        OK - thanks for the reply anyway!
          smarthome @rudibarani
          Hi all
          To make MMM-page-indicator work with MMM-Page-Selector, we must add MMM-page-indicator in to pages
          			module: "MMM-page-indicator",
          			position: "bottom_bar",
          			"pages": {"Home": "bottom_bar", "News": "bottom_bar","Weather": "bottom_bar","Entertaiment": "bottom_bar","Smarthome": "bottom_bar","System": "bottom_bar"},
          			pages: 6,
            smarthome @Johans
            @Johans
            pages: "all",
            You forgot the quotation mark before and after pages
            "pages": "all",
              Brandenborg
              I love this module especially in use together with the MMM-navbar.
              Is there any config using existing code that will let me make it return me to “default” page after a given period of time after changing page?
              • V
                Veldrovive Module Developer @Brandenborg
                @Brandenborg
                This is not a default function of this module. However, if you can edit a small amount of code, it should be easy to implement.
                Just copy these lines of code right after line 235 of MMM-Page-Selector.js. This lines should be selectPage(payload);
                clearTimeout(self.default_timeout);
                if(![0, this.config.defaultPage].includes(payload)){
                    self.default_timeout = setTimeout(() => {
                        selectPage(this.config.defaultPage);
                    }, TIME)
                Then just replace TIME with the number of milliseconds you want to remain on the page before it automatically switches back to default. You may also have to change the 0 in the if statement if your default page isn’t at the 0th position.
                  Brandenborg @Veldrovive
                  @Veldrovive thanks a lot. I should manage that.
                  I recon the 0 position is the first page I define the contents of?
                  • V
                    @Brandenborg
                    The 0 should be the position of your default page in the page list. The furthest left is 0.
                      @Veldrovive
                      Thanks. And thank you for a really useful module!
                      • V
                        @Brandenborg
                        The latest version of this module now has this as a (Not very well tested) feature.
                        You can now specify a restoreDefault prop in the MMM-Page-Selector config with the number of seconds you want before it returns to the default page.
                          m1scha
                          Hi first of all thanks for this great module, Works great. I wanto to remotely change the pages which works with this commands:
                          http://ip:8080/remote?action=NOTIFICATION&notification=PAGE_DOWN
                          http://ip:8080/remote?action=NOTIFICATION&notification=PAGE_UP
                          But if I want to go to a specific page it does noct work with this command:
                          http://ip:8080/remote?action=NOTIFICATION&notification="SELECT_PAGE"&payload="0"
                          Can somebody tell me whats wrong?
                          • V
                            Veldrovive Module Developer @m1scha
                            @m1scha
                            Hello, glad you’re enjoying the module.
                            I am assuming that your page has some name that is not "0".
                            I haven’t extensively tested with magic mirror remote, but I imagine the issue is with setting payload to be a string. When it gets a string, MMM-Page-Selector assumes it is the name of the page, not a page index. If an integer is sent, it assumes it is a page index.
                            I don’t know how remote works, but you might be able to use
                            http://ip:8080/remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=0
                            Or you could specify your page name as
                            http://ip:8080/remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=“YOUR_PAGE_NAME”
                              m1scha @Veldrovive
                              @veldrovive said in MMM-Page-Selector: A page switcher that can set positions of modules:
                              Hi, thanks for you reply.
                              I tested this in several variations, but I get a sucess Message, but change of page.
                              • V
                                @m1scha
                                I checked out MMM-Remote-Control and it is just a problem with string representations.
                                remote?action=NOTIFICATION&notification=“SELECT_PAGE”&payload=0 sends the literal notification “SELECT_PAGE” including the quotes. A more correct request would be remote?action=NOTIFICATION&notification=SELECT_PAGE&payload=Main which would switch the the page called main.
                                However, in order to support other modules, pages are 1 indexed by notification so to switch to the first page, you would send remote?action=NOTIFICATION&notification=SELECT_PAGE&payload=1
                                Strings that are numbers are handled correctly by MMM-Page-Selector.
                                • I
                                  innovation @Veldrovive
                                  @veldrovive Hello! I want to use this module for
                                  1. An intro screen - only for 10 secs
                                  2. Move into screen 2 - stay there
                                  Can I only have one screen to have a time interval and the other doesn’t? If so how?
                                    Riaanh
                                    Good day @Veldrovive thanks for the brilliant work you have done on this, and your comments on this is really helpful.
                                    I have an issue to get this going, and been researching and trying for the past two days with no success. I even tried using some of the users on this thread’s config as posted here, and loaded the modules they refer to, but I always end up with a blank page once I load the portion for MMM-Page-Selector.
                                    As soon as I add this portion below, it only display a blank page, or if I comment it out, then the page will display again.
                                    			disabled: false,
                                    		        module: "MMM-Page-Selector",
                                    		        position: "top_bar",
                                    			        defaultPage: "Page1",
                                    		                displayTitle: true,
                                    			        selectPageNotif: ["SELECT_PAGE"],
                                    		                incrementPageNotif: ["PAGE_UP"],
                                    		                decrementPageNotif: ["PAGE_DOWN"],
                                    Any advice or even just guidance on where to look further would be greatly appreciated.
                                      sdetweil @Riaanh
                                      @Riaanh said in MMM-Page-Selector: A page switcher that can set positions of modules:
                                      MMM-Page-Selector
                                      can u show the messages from where u start MagicMirror
                                      either npm start
                                      or pm2
                                      if using pm2,. then
                                      pm2 logs --lines=100
                                      will show the messages
                                      blank screen is usually a missing library , see
                                        Riaanh @sdetweil
                                        @sdetweil said in MMM-Page-Selector: A page switcher that can set positions of modules:
                                        0 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                                        1 info using npm@7.5.2
                                        2 info using node@v12.22.5
                                        3 timing config:load:defaults Completed in 4ms
                                        4 timing config:load:file:/usr/share/nodejs/npm/npmrc Completed in 7ms
                                        5 timing config:load:builtin Completed in 8ms
                                        6 timing config:load:cli Completed in 4ms
                                        7 timing config:load:env Completed in 1ms
                                        8 timing config:load:file:/home/pi/magicmirror/mounts/modules/.npmrc Completed in 1ms
                                        9 timing config:load:project Completed in 3ms
                                        10 timing config:load:file:/home/pi/.npmrc Completed in 0ms
                                        11 timing config:load:user Completed in 0ms
                                        12 timing config:load:file:/etc/npmrc Completed in 0ms
                                        13 timing config:load:global Completed in 0ms
                                        14 timing config:load:cafile Completed in 1ms
                                        15 timing config:load:validate Completed in 1ms
                                        16 timing config:load:setUserAgent Completed in 2ms
                                        17 timing config:load:setEnvs Completed in 2ms
                                        18 timing config:load Completed in 29ms
                                        19 verbose npm-session 72db9025016605ec
                                        20 timing npm:load Completed in 58ms
                                        21 timing command:run-script Completed in 45ms
                                        22 timing command:start Completed in 59ms
                                        23 verbose stack Error: missing script: start
                                        23 verbose stack     at runScript (/usr/share/nodejs/npm/lib/run-script.js:54:11)
                                        24 verbose cwd /home/pi/magicmirror/mounts/modules
                                        25 verbose Linux 5.10.92-v7l+
                                        26 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                                        27 verbose node v12.22.5
                                        28 verbose npm  v7.5.2
                                        29 error missing script: start
                                        30 verbose exit 1
                                        Thanks for responding, is this what you are referring to?
                                          sdetweil @Riaanh
                                          @Riaanh how do you start MagicMirror normally?
                                            sdetweil @Riaanh
                                            @Riaanh this looks like being started under docker
                                            • 5 / 5
