    MMM-AssistantMk2
    421 Posts 61 Posters 673.6k Views 57 Watching
    • ? Offline
      A Former User @costascontis
      @costascontis
      But in that case, Other modules cannot use speaker-out. I rather recommend to use other speaker instead HDMI.
      • C Offline
        costascontis
        yes i understand,i just think that is a MMM-AssistantMk2 's problem because when i trigger MMM-Hotword it makes a ding sound to show that its listening and that sound i can always hear it so hdmi is awake ,then i make a request to MMM-AssistantMk2 and when it answers i cant hear the first word or the first letters of it anyway…
        • L Offline
          Lowis
          Hello
          how can MMM-AssistantMk2 start a webradio stream ? i tell the Assistant to play radio 1live. Respone is “OK” but nothing will come up.
          I say "show me a picture from a Dog . Respone “OK” but nothing comes up.
          BTW : Great Module !
          • ? Offline
            A Former User @Lowis
            @lowis
            Those features are allowed to REAL GOOGLE HOME devices at this moment. I hope somedays it could be allowed to Assistant SDK.
            • L Offline
              Lowis
              But a something like your youtube search and playing Should be possible for a webradio
              • ? Offline
                @lowis Youtube features are added by myself with Youtube API.
                • L Offline
                  Lowis
                  @Sean Yes i know. Great work ! Maybe it could expand with a webradio directory like shoutcast.com
                    Jmh474
                    I’m guessing that this question has been asked quite a few times so I’m sorry for the repeat.
                    I’ve got my mirror up and running using latest resabian, MagicMirror2, modules MMM-AssistantMk2 and MMM-HOTWORD.
                    Adding more modules soon just taking a step at a time as I’m a total beginner.
                    Seems to be running OK apart from the Google Assistant, its running so slow when asking questions and waiting for replies, and I don’t get voice response back just like a humming sound (I’m guessing this is when Google is answering), I know sound and mic are working as I can her myself talk when testing the mic.
                    Also what is the best setup for mic and speakers in using a USB sound card
                    Mic is just standard 3.5mm jack type
                    Speakers are running through a separate amp after the sound card.
                    One more this is there a way to add an Led for when the Google Assistant is listening??
                    Sorry for the long post I’m just so close
                    • ? Offline
                      A Former User @Jmh474
                      @jmh474
                      For slow speed, I have no idea about it. Maybe it is related with your network status. Usually others have no problem about speed.
                      I think, it is not about speed. You just couldn’t get the response with some reason.
                      Test like this;
                      • Stop the pm2 (If you are using)
                      • Execute MM with npm start dev on MagicMirror directory.
                      • See what happens on terminal shell.
                        There could be errors or some useful messages to examine.
                      • LicoriniL Offline
                        Licorini
                        Hello … I am a beginner, I am trying to install Mk2 following the instructions, however it presents errors as below:
                        magicmirror@2.6.0 start /home/pi/MagicMirror
                        sh run-start.sh
                        Starting MagicMirror: v2.6.0
                        Loading config …
                        Loading module helpers …
                        Initializing new module helper …
                        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
                        Expected directory: electron-v2.0-linux-arm-glibc
                        Found: [node-v64-linux-arm-glibc]
                        This problem can often be fixed by running “npm rebuild” on the current system
                        Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc/grpc_node.node’
                        App threw an error during load
                        at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
                        at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:63:3)
                        at Module._compile (module.js:642:30)
                        at Object.Module._extensions…js (module.js:653:10)
                        at Module.load (module.js:561:32)
                        at tryModuleLoad (module.js:504:12)
                        at Function.Module._load (module.js:496:3)
                        at Module.require (module.js:586:17)
                        at require (internal/module.js:11:18)
                        at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12)
                        Whoops! There was an uncaught exception…
                        { Error: Failed to load gRPC binary module because it was not installed for the current system
                        at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12) code: ‘MODULE_NOT_FOUND’ }
                        Launching application.
                        Can someone help me ??
                        • L Offline
                          Lowis @Guest
                          @sean but how can i setup the notification to start play MMM_Webradio ?
                          MMM_Webradio has this notifications :
                          WEBRADIO_ONOFF Starts / Pauses playback
                          WEBRADIO_VOLUP Volume up by 5%
                          WEBRADIO_VOLDOWN Volume down by 5%
                          WEBRADIO_NEXT Next station
                          WEBRADIO_PREV Previous station
                          • ? Offline
                            A Former User @Licorini
                            @licorini
                            You’ve missed or failed electron-rebuild step. Do it with instruction on README
                            • ? Offline
                              @lowis
                              There are two options to make custom commands - transcriptionHook and gAction.
                              I’ll explain with transcriptionHook because it is easier (but limited)
                              first. define hook phrase.
                              transcriptionHook: {
                                "RADIO": {
                                  pattern: "my radio",  // When you say "my radio",
                                  command: "RADIO_ONOFF" // command "RADIO_ONOFF" will be executed
                                ... // if you need more hooks, add here.
                              Then, Let’s make command RADIO_ONOFF to emit notification when your voice is hooked.
                              command: {
                                "RADIO_ONOFF": {
                                  notificationExec: {
                                    notification: "WEBRADIO_ONOFF",
                                ... // if you need more commands, add here.
                              Now, when you say “my radio” in your voice order, “RADIO_ONOFF” command will be executed to send notification “WEBRADIO_ONOFF”.
                              But, I think there could be a problem to use webradio. Because your radio sound will interrupt HOTWORD or AMK2 occasionally, it could make unintended misbehaviours. Anyway, I wish you good luck.
                              • L Offline
                                Lowis @Guest
                                @sean thank you very much for the detailed information . Webradio is running !
                                • T Offline
                                  teitlebot
                                  @Sean
                                  Thanks again for all the work and help
                                  So how would I get assistant module to disable and enable the google photo module?
                                  I would like to speak “Hide Photos” and the Google Photos will stop displaying.
                                  I know I need transition hook and command
                                  I tried learning how to do this using your example of hide clock except after I added the code nothing happened. When I say “hide clock” it searches google for hide clock instead of turning off module. So I must be doing something wrong
                                  BTW the hide all command works fine.
                                  • ? Offline
                                    A Former User @teitlebot
                                    @teitlebot
                                    I don’t know how you do your code. I have no second sight. Show your work to examine.
                                    • E Offline
                                      Egnos
                                      Hi @Sean.
                                      I have some questions to ask you:
                                      • I installed AssistantMK2 and Hotword successfully but the only way to wake up the assistant is to say “snowboy”. The hot word “smartmirror” and “jarvis” do not work. Can you help me? (my config.js below…)
                                      • When I ask for a song on youtube I can not stop the song anymore. The assistant does not listen to me. To talk to the assistant I have to wait for the end of the song. How do I solve?
                                      • When the assistant begins to speak, he cuts the first words, is it possible to solve?
                                      • The videos on youtube are reproduced in full screen. Is it possible to reproduce them in a small box (example: bottom right …)?
                                      Thanks you for your great work and patience! :winking_face:
                                      /* Magic Mirror Config Sample
                                       * MIT Licensed.
                                      var config = {
                                      	port: 8080,
                                      	language: "en",
                                      	timeFormat: 24,
                                      	units: "metric",
                                      		  module: "MMM-AssistantMk2",
                                      		    /*useWelcomeMessage: "brief today",*/
                                      		    deviceLocation: {
                                      					coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
                                      					latitude: 45.200049, // -90.0 - +90.0
                                      					longitude: 7.568917, // -180.0 - +180.0
                                      			profiles: {
                                      				"default" : { // profile name.
                                      				profileFile: "default.json", // profile file name.
                                      				lang: "it-IT",
                                      				//currently available (estimation, not all tested):
                                      				//  de-DE, en-AU, en-CA, en-GB, en-US, en-IN
                                      				// fr-CA, fr-FR, it-IT, ja-JP, es-ES, es-MX, ko-KR, pt-BR
                                      				// https://developers.google.com/assistant/sdk/reference/rpc/languages
                                      			record: { // Full values are in `FOR EXPERTS` section.
                                      				recordProgram: "arecord",  // Defaults to "arecord" - also supports "rec" and "sox"
                                      				device: "plughw:1"        // recording device (e.g.: "plughw:1")
                                      			play: { // Full values are in `FOR EXPERTS` section.
                                      				playProgram: "mpg321", // recommended.
                                      			notifications: {
                                              ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                                              ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                                          module: "MMM-Hotword",
                                            record: {
                                              recordProgram : "arecord",
                                              device        : "plughw:1",
                                            autostart:true,
                                            onDetected: {
                                              notification: function (payload) {
                                                return "ASSISTANT_ACTIVATE"
                                              payload: function (payload){
                                                return {
                                                  profile: payload.hotword
                                        module: 'MMM-Hotword',
                                          snowboy: [
                                          hotwords: "smartmirror", //this will be sent to other module for distinguishing which hotword is detected.
                                          file: "resources/models/smart_mirror.umdl",
                                          sensitivity: '0.5',
                                          hotwords: "snowboy",
                                          file: "resources/models/snowboy.umdl",
                                          sensitivity: '0.5',
                                          file: 'resources/models/jarvis.umdl',
                                          sensitivity: '0.8,0.80',
                                          hotwords: ['jarvis','jarvis'] //Kitt.ai changed their Jarvis UMDL, it has 2 models in one file. So weird.
                                          //anyway, you can give different name for each. ['jarvis_1', 'jarvis_2']. Even though I think this is useless.
                                          record: {
                                            sampleRate    : 16000,      // audio sample rate
                                            threshold     : 0.5,        // silence threshold (rec only)
                                            thresholdStart: null,       // silence threshold to start recording, overrides threshold (rec only)
                                            thresholdEnd  : null,       // silence threshold to end recording, overrides threshold (rec only)
                                            silence       : 1.0,        // seconds of silence before ending
                                            verbose       : true,      // log info to the console. Use this when you want to check mic working or not.
                                            recordProgram : 'arecord',  // Defaults to 'arecord' - also supports 'rec' and 'sox'
                                            device        : 'plughw:1'        // recording device (e.g.: 'plughw:1')
                                          autostart: true,              // if 'false', this module will wait for 'HOTWORD_RESUME' notification to start hotwords detection at the beginning.
                                          autorestart: false,          // You can set this 'true' when you want this module to go back to listening mode automatically again after hotword is detected. But use this carefully when your other modules are using microphone or speaker.
                                          // customizable notification trigger
                                          notifications: {
                                            PAUSE: "HOTWORD_PAUSE",
                                            RESUME: "HOTWORD_RESUME",
                                            LISTENING : "HOTWORD_LISTENING",
                                            SLEEPING : "HOTWORD_SLEEPING",
                                            ERROR : "HOTWORD_ERROR",
                                          onDetected: {
                                            notification: (payload) => {
                                              return "HOTWORD_DETECTED"
                                            payload: (payload) => {
                                              return payload
                                              module: 'MMM-pages',
                                                      modules:
                                                          [[ "weatherforecast", "newsfeed"],
                                                           [ "calendar", "compliments" ]],
                                                      excludes: ["clock", "currentweather", "MMM-page-indicator", "MMM-AssistantMk2"],
                                              module: 'MMM-page-indicator',
                                              position: 'bottom_bar',
                                                  pages: 3,
                                      			module: "alert",
                                      			module: "updatenotification",
                                      			position: "top_bar"
                                      			module: "clock",
                                      			position: "top_left"
                                      			header: "US Holidays",
                                      						symbol: "calendar-check-o ",
                                      						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                                      			module: "compliments",
                                      			position: "lower_third"
                                      			module: "currentweather",
                                      				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                                      				appid: "YOUR_OPENWEATHER_API_KEY"
                                      			module: "weatherforecast",
                                      			header: "Weather Forecast",
                                      				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                      			module: "newsfeed",
                                      			position: "bottom_bar",
                                      				feeds: [
                                      						title: "La Stampa",
                                      						url: "https://www.lastampa.it/rss.xml"
                                      				showSourceTitle: true,
                                      				showPublishDate: true
                                      • ? Offline
                                        A Former User @Egnos
                                        @egnos
                                        Adjust sensitivity.
                                        set pauseOnYoutube:false. You can activate hotword during videoplaying and it will stop the video. Anyway, there is a risk that your video sounds could also activate hotword.
                                        I think you are using HDMI as output. HDMI could have that symptom. Use other output.
                                        Redefine CSS selector #ASSISTANT_YOUTUBE in css/custom.css.
                                        E R 2 Replies Last reply Reply Quote 0
                                        • E Offline
                                          Egnos @Guest
                                          @sean said in MMM-AssistantMk2:
                                          Adjust sensitivity.
                                          The sensitivity of the microphone?
                                          If yes, how do you do it?
                                          Where should I make this modify?
                                          Thanks a lot!
                                          • ? Offline
                                            @egnos
                                                sensitivity: '0.5', // < - SENSITIVITY
                                            css/custom.css
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 21
                                            • 22
                                            • 12 / 22
