    MMM-AssistantMk2
    421 Posts 61 Posters 713.8k Views 57 Watching
    • ? Offline
      [[global:former-user]] @teitlebot
      @teitlebot said in MMM-AssistantMk2 & MMM-GAction:
      @Sean Any suggestions of integration facial recognition to the magic mirror?
      I made this module to work with other modules by NotificationTrigger. So Another Facial recognition module could activate AssistantMK2 if there is a proper notification broadcasting. There is no need to implement that function in AssistantMk2 itself.
      • T Offline
        teitlebot @Guest
        @sean Thank You. Some more learning on my part. I plan on installing
        https://github.com/paviro/MMM-Facial-Recognition and will report back here.
        • T Offline
          teitlebot
          For those interested, I upgraded from a tiny usb mic to a playstation eye and had much improvement on voice recognition.
            mirror.master
            Hey guys any idea why my Google assistant won’t go back to sleep after use? It’s honestly recent, and weird. I can use it as normal, but the Mic stays blue after the fact and doesn’t turn off.
            • V Offline
              vijayrraut @Guest
              Hello @sean , I am also looking for a “ding” sound on hotword detection, but no luck. Did you get a chance to add this feature to assistantmk2. It would be of great help when talking to the mirror from far distance.
              ? 2 Replies Last reply Reply Quote 0
              • ? Offline
                [[global:former-user]] @vijayrraut
                @vijayrraut
                I’ll consider it.
                • ? Offline
                  @vijayrraut
                  Ver 1.1.0 is ready. (not yet merged into master branch)
                  You can use ding sound on 1.1.0. It will be my pleasure if you test this for me.
                  https://github.com/eouia/MMM-AssistantMk2/tree/1.1.0
                  T V 2 Replies Last reply Reply Quote 0
                  • T Offline
                    teitlebot @Guest
                    @sean I’ll give it a try. How do I install something that isnt in the master branch?
                    • ? Offline
                      @teitlebot
                      sudo apt-get install mpg321
                      cd ~/MagicMirror/modules/MMM-AssistantMk2
                      git pull
                      git checkout 1.1.0
                      npm install --save wav
                      • ? Offline
                        UPDATE
                        [1.1.0] - 2018.10.04
                        • MP3 Output is supported. Now you can get more unchunky sound result.(Set audio.encodingOut to MP3 // OGG is not yet supported.)
                        • ding.wav will be played when Assistant is ready to hear your voice.
                        • How to update from prior version
                        git pull
                        • T Offline
                          teitlebot @Guest
                          @sean Thank You
                          Ding is working just fine. Thank You. A little annoying sound and I was thinking of replacing it with another sound file. What if I wanted google to say something instead of ding, can I give it text to say easily?
                          • ? Offline
                            @teitlebot
                            change other wav file and rename it as ding.wav,
                            Anyway, if you mean Text-To-Speech, nope. (My prior had that functionality but I abandoned it) I don’t want to back again.
                            • C Offline
                              cola0927 @teitlebot
                              @teitlebot totally agree!
                              • T Offline
                                teitlebot @Guest
                                @sean ok. Can I ask why you abandoned it?
                                • ? Offline
                                  @teitlebot
                                  Complexity. And most TTS solutions ate not so good to hear. The best Google solution is not free.
                                  T 2 Replies Last reply Reply Quote 0
                                  • T Offline
                                    teitlebot @Guest
                                    @sean I see. I manually created a sound file and replaced it and it works fine, although a bit choppy.
                                    • T Offline
                                      teitlebot @Guest
                                      @sean Next Question
                                      Why doesnt google allow me to use the MM to play music. I can get it to play out of my google home mini in my kitchen using the MM but there doesnt seem a way to use the MM speaker to play. not even spotify.
                                      Although youtube does work as you seem to have added that functionality.
                                      • ? Offline
                                        @teitlebot
                                        Idk. Because this sdk might be just on beta stage?
                                        • V Offline
                                          vijayrraut @Guest
                                          @sean Thank you very much. The changes for “ding” sound are working like a charm. Initially I got error while git pull as I had my own changes to my .js files. I did ‘git stash’ and merged the new changes. Thank you so much.
                                          git stash
                                          git pull
                                          git stash pop
                                            Stabber
                                            Hi. I have a problem at this point:
                                            In your SBC, you can run auth-tool for authentification. (not via SSH)
                                            node auth_and_test.js
                                            and i see this:
                                            1. That’s an error.
                                            Error: disabled_client
                                            A native application: project-1019057327317
                                            You can email the developer of this application at: unconfiguredapp@google.com
                                            This app is not yet configured to make OAuth requests. To do that, set up the app’s OAuth consent screen in the Google Cloud Console.
                                            Probably SSH is the problem, but I don’t understand this: “(So you’d better to execute this script in your RPI shell, not via SSH)”
                                            Could you help me with this?
                                            • 6
                                            • 7
                                            • 8
                                            • 21
                                            • 22
                                            • 6 / 22
