    MMM-GooglePhotos
    294 Posts 56 Posters 383.2k Views 59 Watching
    • T Offline
      teitlebot @Guest
      @Sean I think I can access IFTTT or Webhooks from my arduino. Is it possible to send out notifications that way?
      ? 2 Replies Last reply Reply Quote 0
      • ? Offline
        [[global:former-user]] @teitlebot
        @teitlebot yes but… image itself will not be rotated by frames direction. It should be rotated again by direction. Think about it. It is totally different work.
        • ? Offline
          @teitlebot
          There could be some issues.
          Just rotation will not be what you expect
          Unfortunately, as far as I know GooglePhotos remove all your EXIF and it’s metadata has no direction info. So cannot catch the photo direction.
          With local stored original photos (or in Dropbox), it might be able to be done.
          But it would be totally different program.
          • T Offline
            teitlebot @Guest
            @Sean cant you also catch the direction by height/width?
            • ? Offline
              @teitlebot
              impossible only with width/height. Imagine some pictures in your mind and rotate it. :D
              Or…
              Which direction should this photo be rotated? clockwise? counterclockwise? How can we know the direction with only width/height?
              • T Offline
                teitlebot @Guest
                @Sean Interesting but Google Photos already rotates the picture correctly for us before it sends it to the mirror. So assuming it shows correct in the google photos album it will be correct in the mirror. Now take any picture that is width/height >1 and rotate the picture one way and rotate the screen in the opposite direction and it should work.
                • ? Offline
                  @teitlebot
                  If so, you can do that without notification. Just add eventlistener to target photo container element and check whether src be changed. Then you can activate xmlHTTPrequest to send request to your IFTTT server.
                  • T Offline
                    teitlebot @Guest
                    @Sean Thank You. Will learn up on this and see if I can do it myself
                      mirrorman2
                      Brilliant module - thanks for the development.
                      I am trying to get two instances of this module running on one magic mirror, so I can show one photo at the top and one at the bottom.
                      I have copied the module into a different folder, renaming it (and in the CSS files as necessary). I also set up a separate google API project and separate authorisation to see if that was an issue.
                      Both modules run, but the photos get loaded one on top of the other despite having different positions:
                        module: "MMM-GooglePhotos",
                        position: "top_center",
                          albumId: "blanked for posting", // your album id(s) from result of `auth_and_test.js`
                          refreshInterval: 1000*20,
                          scanInterval: 1000*60*10, // too many scans might cause API quota limit also.
                          //note(2018-07-29). It is some weird. API documents said temporal image url would live for 1 hour, but it might be broken shorter. So, per 10 min scanning could prevent dead url.
                          sort: "random", //'time', 'reverse', 'random'
                          showWidth: "800px", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
                          showHeight: "400px",
                          originalWidthPx: 1024, // original size of loaded image. (related with image quality)
                          originalHeightPx: 728, // Bigger size gives you better quality, but can give you network burden.
                          mode: "hybrid", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
                          //ADDED. "hybrid" : if you set as "hybrid" it will change "cover" and "contain" automatically by aspect ratio.
                        module: "MMM-GooglePhotos2",
                        position: "bottom_left",
                          refreshInterval: 1000*15,
                          showWidth: "1024px", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
                          showHeight: "728px",
                      Any ideas where I have gone wrong? Thanks!
                      • ? Offline
                        [[global:former-user]] @mirrorman2
                        @mirrorman2
                        Each instance would be rendering different doms but they have same “Id”. That would make this behavior. Sorry, I haven’t considered duplicated instances on development.
                        If you want duplicated instances, modify source where “id” is used.
                        By example;
                        wrapper.id = “GPHOTO”
                          stephaniesal
                          This post is deleted!
                          • ? Offline
                            [[global:former-user]] @stephaniesal
                            @stephaniesal
                            Is there any error or suspicious log message on execution? Without log, I cannot guess what happened.
                              stephaniesal @Guest
                              • G Offline
                                gekberlin
                                Hi there,
                                is it possible just to show the last three images of the given album ? And moreover is there any chance to display the comments which belongs to the photo ?
                                • ? Offline
                                  [[global:former-user]] @gekberlin
                                  @gekberlin
                                  1. Cannot limit the number currently. And I thought, If you want just a few pictures, you’d better to store your photos locally and to display them with other local-based module.
                                    The better way I think is, to create new album for selected photos and use it.
                                  2. There is no API to get comment. Sorry.
                                    redink
                                    Thank you for making this great module and a very a good set of instuctions. I am struggling with the last step.
                                    I run the node auth_and_test.jsand it opens the browser windows asking me to login. I proceed to do that, go through my 2FA and then land on a page which is asking me to select a google account form a list of 1 (just my account). Clicking my account just redirects me back to the same exact page. Have you seen this issue before? Any idea on how to fix this?
                                    • ? Offline
                                      [[global:former-user]] @redink
                                      @redink Somebody has same issue. Copy the URL and use another browser. (Or another device - like your dev pc). I think it could be some kind of cookie issue.
                                        redink @Guest
                                        Thanks for the quick reply. I assumed this had to happen from the exact same machine that MagicMirror was running out, because it would set a local cookie or something. But, I’ll try opening the URL from a different machine and report back tonight.
                                          redink
                                          It worked! Thanks!
                                          Is there a config to fade the picture, or do an 50% transparent black overlay? I am sure I can do this with some custom CSS, but was wondering of the module supports it.
                                          • ? Offline
                                            @redink adjust css. i prefer to control looks by css.
                                            • 6
                                            • 7
                                            • 8
                                            • 14
                                            • 15
                                            • 6 / 15
