    back screan when start up an errors.....
    5 Posts 2 Posters 2.0k Views 2 Watching
    • jcklerkJ Offline
      jcklerk
      is have installt it on ubuntu 16.04
      and i have this problem
      it start up whit errors and whit the server Only version i have no errors but still blank screan and th consel on Web Browser is spammed full…
      and when i start it up using npm start it have som errors i cant figger it out what the problem is…
      start up error:
      root@smart-mirror-jcklerk:~/MagicMirror# npm start
      > magicmirror@2.4.1 start /root/MagicMirror
      > sh run-start.sh
      (electron:6583): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
      (electron:6583): GLib-GIO-CRITICAL **: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
      Starting MagicMirror: v2.4.1
      Loading config ...
      Loading module helpers ...
      All module helpers loaded.
      Starting server on port 8989 ...
      You're using a full whitelist configuration to allow for all IPs
      Server started ...
      Starting module: newsfeed
      (electron:6583): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
      Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
      Launching application.
      Shutting down server...
      Stopping module helper: updatenotification
      Stopping module helper: calendar
      Stopping module helper: newsfeed
      **test **
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'test:e2e' ]
      2 info using npm@6.1.0
      3 info using node@v10.7.0
      4 verbose run-script [ 'pretest:e2e', 'test:e2e', 'posttest:e2e' ]
      5 info lifecycle magicmirror@2.4.1~pretest:e2e: magicmirror@2.4.1
      6 info lifecycle magicmirror@2.4.1~test:e2e: magicmirror@2.4.1
      7 verbose lifecycle magicmirror@2.4.1~test:e2e: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.4.1~test:e2e: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/root/MagicMirror/node_modules/.bin:/usr/local$
      9 verbose lifecycle magicmirror@2.4.1~test:e2e: CWD: /root/MagicMirror
      10 silly lifecycle magicmirror@2.4.1~test:e2e: Args: [ '-c',
      10 silly lifecycle   'NODE_ENV=test ./node_modules/mocha/bin/mocha tests/e2e --recursive' ]
      11 silly lifecycle magicmirror@2.4.1~test:e2e: Returned: code: 39  signal: null
      12 info lifecycle magicmirror@2.4.1~test:e2e: Failed to exec test:e2e script
      13 verbose stack Error: magicmirror@2.4.1 test:e2e: `NODE_ENV=test ./node_modules/mocha/bin/mocha tests/e2e --recursive`
      13 verbose stack Exit status 39
      13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:304:16)
      13 verbose stack     at EventEmitter.emit (events.js:182:13)
      13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack     at ChildProcess.emit (events.js:182:13)
      13 verbose stack     at maybeClose (internal/child_process.js:961:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:5)
      14 verbose pkgid magicmirror@2.4.1
      15 verbose cwd /root/MagicMirror
      16 verbose Linux 4.15.0-29-generic
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "run" "test:e2e"
      18 verbose node v10.7.0
      19 verbose npm  v6.1.0
      20 error code ELIFECYCLE
      21 error errno 39
      22 error magicmirror@2.4.1 test:e2e: `NODE_ENV=test ./node_modules/mocha/bin/mocha tests/e2e --recursive`
      22 error Exit status 39
      23 error Failed at the magicmirror@2.4.1 test:e2e script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 39, true ]
      i hope sam one can help me
      • jcklerkJ Offline
        jcklerk
        chek:
        npm install errors magicmirror@2.4.1 &
        dbus-deamon is running under the user jcklerk and i start up magicmirror whif root user
        but still black screen
        • ? Offline
          A Former User @jcklerk
          @jcklerk
          Try this.
          npm start -- --disable-gpu
          In my case, it worked.
          jcklerkJ 1 Reply Last reply Reply Quote 0
          • jcklerkJ Offline
            jcklerk @Guest
            @sean Nope doesn’t work for me…
            root@smart-mirror-jcklerk:~/MagicMirror# npm start -- --disable-gpu
            > sh run-start.sh "--disable-gpu"
            (electron:7962): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
            (electron:7962): GLib-GIO-CRITICAL **: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
            Loading config ...
            Server started ...
            (electron:7962): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
            • jcklerkJ Offline
              jcklerk
              I’m are going to re install ubuntu and chek if i have the same error bicase i have som oudio problems whit google assistant after i install magicmirror…
              • jcklerkJ Offline
                jcklerk
                chek:
