Navigation
    • Search
    MagicMirror² v2.15.0 is available! For more information about this release, check out this topic.
    UNSOLVED MMM-MyRadio is silent
    Troubleshooting
    • K
      Klaus last edited by
      I am making a MagicMirror 2.4.1 with MMM-Myradio 1.01 on RPI 3, to have RadioParadise playing.
      Installation worked like a charm. Config was easy (and got the scripts set x-ecutable)
      But, not a sound.
      If I run the RadioParadise.sh manually, It plays the stream, and RDS data appears in the app.
      When I CTRL+C the stream it stops.
      What have I missed something in the installation ?
      • A
        AxLed Module Developer last edited by
        @Klaus
        Did you make tue. sh Scripts executable?
        See Readme.md of Module.
        Make sure that all scripts in “scripts” folder are set as executable!
        AxLed
        • K
          They are executable.
          That’s what is so puzzling.
          The scripts work, when run manually.
          But I am not able to run them through Myradio
          • M
            Mike7400 last edited by
            same problem here. Do you have a solution?
