MMM-MyRadio is silent
4 Posts 3 Posters 1.5k Views 2 Watching
  • K Offline
    Klaus
    I am making a MagicMirror 2.4.1 with MMM-Myradio 1.01 on RPI 3, to have RadioParadise playing.
    Installation worked like a charm. Config was easy (and got the scripts set x-ecutable)
    But, not a sound.
    If I run the RadioParadise.sh manually, It plays the stream, and RDS data appears in the app.
    When I CTRL+C the stream it stops.
    What have I missed something in the installation ?
      AxLed Module Developer
      @Klaus
      Did you make tue. sh Scripts executable?
      See Readme.md of Module.
      Make sure that all scripts in “scripts” folder are set as executable!
      AxLed
      • K Offline
        Klaus
        They are executable.
        That’s what is so puzzling.
        The scripts work, when run manually.
        But I am not able to run them through Myradio
          Mike7400
          same problem here. Do you have a solution?
