    Volkswagen CarNet
    6 Posts 3 Posters 2.7k Views 3 Watching
      jorgeb1502
      Was wondering if it would be possible to make a module that shows battery percentage and other stuff from the CarNet-app/server. Found this npm, but don’t know if it’s still working: https://www.npmjs.com/package/vw-carnet
      • ? Offline
        A Former User @jorgeb1502
        @jorgeb1502 Its github repository is broken. I think it might be out-of-date.
          jorgeb1502
          This post is deleted!
            jorgeb1502 @Guest
            @sean
            Would it be possible to use this one? https://github.com/wez3/volkswagen-carnet-client
            Edit:
            I have tested it, and I it works. Is it possible to use python in a module?
            • ? Offline
              @jorgeb1502 you can make python app and run as daemon. And add some communication part with RESTful API or any other spec. Your another nodejs mm module can talk with with your python app, I guess.
              • N Offline
                nekman
                You can also try https://www.npmjs.com/package/node-vw-carnet (if you have not already solved your problem)
