    Fu.. OFF... What happned? Unexpected Token
    3 Posts 2 Posters 1.7k Views 2 Watching
    • B
      bjoern
      After 7 Day i works fine. Today i have a Problem, but i have nothing NOTHING configured or else.
      What odes it means? I have no time to reconfigured the system every weeks again and again!
       pm2 restart mm
      /usr/lib/node_modules/pm2/node_modules/supports-color/index.js:1
      (function (exports, require, module, __filename, __dirname) { );return d?(d.path=c,f(d)):c}function h(a,d){""===a&&(a=".");""===d&&(d=".");var c=b(d),n=b(a);n&&(a=n.path||"/");if(c&&!c.scheme)return n&&(c.scheme=n.scheme),f(c);if(c||d.match(z))return d;if(n&&!n.host&&!n.path)return n.host=d,f(n);c="/"===d.charAt(0)?d:k(a.replace(/\/+$/,"")+"/"+d);return n?(n.path=c,f(n)):c}function d(a){return a}
      SyntaxError: Unexpected token )
          at new Script (vm.js:51:7)
          at NativeCompileCache._moduleCompile (/usr/lib/node_modules/pm2/node_modules/v8-compile-cache/v8-compile-cache.js:226:18)
          at Module._compile (/usr/lib/node_modules/pm2/node_modules/v8-compile-cache/v8-compile-cache.js:172:36)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
          at Module.load (internal/modules/cjs/loader.js:566:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
          at Function.Module._load (internal/modules/cjs/loader.js:498:3)
          at Module.require (internal/modules/cjs/loader.js:598:17)
          at require (/usr/lib/node_modules/pm2/node_modules/v8-compile-cache/v8-compile-cache.js:159:20)
          at Object.<anonymous> (/usr/lib/node_modules/pm2/node_modules/chalk/index.js:4:21)
      • C
        Charley Module Developer
        That ) in the second doesn’t look like something proper.
        When did this happen?
        What modules do you have installed?
        MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
        • B
          bjoern
          That’s the crazy one. I have not installed or configured any modules for over a week. Yesterday morning the screen was black. After a reboot, MM did not work anymore.
