    Installing the dependencies - Can't finish the installation.
    9 Posts 6 Posters 4.6k Views 5 Watching
    • M
      magicmirrork
      I started with my new Raspberry Pi 3 B board, all of Wi-Fi settings are done
      typed $(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)" to start download mirror, and this is what happened during the installation.
      I faced the same problem when I tried the evancohen mirror client - during the installing dependencies, same error occur and I can’t go any further.
      What should I do? I reinstalling the Mirror countless times…Is it board problem or Internet connection? maybe auth setup problem?
      Please, if you know how to solve this problem help me. T.T
      rudibaraniR A 2 Replies Last reply Reply Quote 0
      • M
        magicmirrork
        I installing the package.json file manually, and try restart the npm install, here’s what happened <<
        Now I can’t understand any lines now…Still that Method Not Allowed error shows up
        maybe some kind of license file occur the problem???
        • rudibaraniR
          rudibarani Project Sponsor @magicmirrork
          @magicmirrork Did you eventually solve this? I got the same problem yesterday :(
          • A
            akram01w @magicmirrork
            @magicmirrork Did u solve this problem. same problem. i use rasberrypi 3b+ and rasbian strectch. pls help.
            • A
              akram01w @akram01w
              @akram01w use this command
              bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
              • N
                NoNameRo @akram01w
                @akram01w
                you have to upgrade your npm
                npm install -g npm@latest
                • shreyashS
                  shreyash
                  Same problem i face
                  • lavolp3L
                    lavolp3 Module Developer @shreyash
                    @shreyash
                    Have you updated npm?
                    I am not sure about this, but what I would then try is first install npm globally. Possibly using sudo.
                    I would however not advise to install the MM itself via sudo.
                    Try:
                    If that does not work, with sudo
                    sudo npm install -g npm@latest
                    sudo npm n stable
                    The node version above is also not the latest one (> 10.0) but it should be sufficient.
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                    shreyashS 1 Reply Last reply Reply Quote 1
                    • shreyashS
                      shreyash @lavolp3
                      @lavolp3 Thank you !
                      it is done by clear overwrite method !
