    Google Assistant Shopping List display
    27 Posts 9 Posters 14.0k Views 10 Watching
      maxbachmann
      Set Up Permissions
      In order for your skill to have read or write access to customers’ Alexa lists, it must have the appropriate permissions which you can set up in the developer console. Request Lists Read or Lists Write permissions in your skill only when they are required to support the features and services provided by your skill.
      Edit your skill in the developer console.
      Navigate to the Build > Permissions page.
      Select the Lists Read or Lists Write check boxes, or both, depending on the requirements of your skill.
      So you need to ask the for permission for you skill. Although thats still a workaround over a second skill and you can’t directly access them I guess
      • ? Offline
        A Former User @maxbachmann
        @maxbachmann Frankly I don’t know anything about Alexa and its things :{ Sorry.
        • ? Offline
          A Former User @sforsyth
          @sforsyth
          I’ve made this; But not fully tested. Could you test this for me?
          [card:eouia/MMM-GoogleShoppingList]
            maxbachmann
            @Sean same about me just guessing ^^ Never used any cloud based voice solution (always using snips)
            Still need to post my MagicMirror stuff with snips when I get time and a camera to make a good video on it
              sforsyth
              That’s great guys!
              @maxbachmann I actually don’t have Alexa, I’ve only got a Google Home device, so that’s why I was hoping for a Google Shopping List module rather than anything with Alexa. Thanks though!
              @Sean This is awesome! I’ll try to give this a go tonight when I get home. Thanks a million!
                maxbachmann
                ups lol being able to read a text would give me a clear advantage :smiling_face_with_open_mouth_cold_sweat:
                The word google was just to often in the text for me to realise
                  sforsyth @Guest
                  @sean Hey Sean, I’m so sorry for the delay in replying to this, I really appreciate the effort in making it. Unfortunately, it didn’t work for me, it just stops my magic mirror from loading up properly. It just shows my mouse pointer and the screen remains black. As I said before, I’m not a programmer myself, so can’t offer much in the way of debugging, but I have installed several modules before without any problems, so I’m pretty sure it’s nothing basic. Again, sincere apologies for the late reply, life got in the way this week!
                  Thanks again,
                  Sean
                  • ? Offline
                    @sforsyth I need an error log to figure out what was happend.
                    execute npm start dev or pm2 show log and tell me what was shown.
                    ChrisC S 2 Replies Last reply Reply Quote 0
                    • ChrisC Offline
                      Chris @Guest
                      @sean
                      Hello,
                      I tested this module too. I do not have any problems with launching my MagicMiror. The module appears well but remains empty despite the fact that I add items in my shopping list.
                      I started the mirror with the command npm start dev and I have one error that appears:
                      (node:5912) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 9): Error: Failed to launch chrome!
                      /home/pi/MagicMirror/modules/MMM-GoogleShoppingList/node_modules/puppeteer/.local-chromium/linux-579032/chrome-linux/chrome: 1: /home/pi/MagicMirror/modules/MMM-GoogleShoppingList/node_modules/puppeteer/.local-chromium/linux-579032/chrome-linux/chrome: Syntax error: word unexpected (expecting ")")
                      TROUBLESHOOTING: https://github.com/GoogleChrome/puppeteer/blob/master/docs/troubleshooting.md
                      Do you have any idea of the problem?
                      Thank you in advance,
                      Regards,
                        sforsyth @Guest
                        @sean
                        npm start dev gives me the following:
                        WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                        Loading module helpers …
                        App threw an error during load
                        /home/pi/MagicMirror/modules/MMM-GoogleShoppingList/node_helper.js:51
                        async function get(headless) {
                        SyntaxError: Unexpected token function
                        at Object.exports.runInThisContext (vm.js:76:16)
                        at Module._compile (module.js:528:28)
                        at Object.Module._extensions…js (module.js:565:10)
                        at Module.load (module.js:473:32)
                        at tryModuleLoad (module.js:432:12)
                        at Function.Module._load (module.js:424:3)
                        at Module.require (module.js:483:17)
                        at require (internal/module.js:20:19)
                        at loadModule (/home/pi/MagicMirror/js/app.js:127:17)
                        at loadNextModule (/home/pi/MagicMirror/js/app.js:161:5)
                        Whoops! There was an uncaught exception…
                        Launching application.
                        • 3 / 3
