    Google Assistant Shopping List display
    27 Posts 9 Posters 16.6k Views 10 Watching
      A Former User @Chris
      @chris
      I’ve found what was wrong. I’m making an urgent fix. But not completely works.
      The main reason of your issue was, lacking puppeteer had not proper Chromium for Raspberry Pi. It was not a big problem,
      But during making fixture, I found something. Google ShoppingList site has a very lazy loading of contents and I couldn’t catch the exact time when all the contents were loaded.
      That will makes often to get an empty list. I will abandon puppeteer and try other things. But it will take some time. Sorry.
      @sforsyth your node version is too low. async will be working over node version 7.6
      S ChrisC 2 Replies Last reply
        sforsyth @Guest
        @sean Hey Sean, Sorry man, I have no idea what that means when you say my node “version is too low”…
        ? 1 Reply Last reply
          A Former User @sforsyth
          @sforsyth “async” feature would work above node version 7.6. your node version might be lower than 7.6.
          Anyway, I cannot fix the main issue of this module at this moment, so you don’t have to bother yourself with this module. sorry.
            sforsyth @Guest
            @sean Ah. I meant I have no idea what my “node” is. :)
            Anyway, if it doesn’t work, it doesn’t work. Thanks for putting the time in to try it, I really appreciate it!
            • ChrisC
              Chris @Guest
              @sean
              Bonjour,
              Pas de soucis pour moi, j’attendrai que tu ais le temps de te pencher sur le problème.
              Merci pour ton travail,
              Cordialement,
                shavesophere
                @sean Hi Sean, and thanks for the effort put into this module. I too have the same problem as @sforsyth - just a white screen and magic mirror does not load. I have installed puppeteer and chromium as per your install instructions but still no action. I’m Just keeping an eye on this thread looking forward to a fix! Thanks again.
                  A Former User @shavesophere
                  @shavesophere
                  I’ve already updated fixed version a few days ago. So I wonder which version did you test.
                  And I need more detailed error logs to find what was your problem.
                    Ron.kamstra
                    Installed the module but it always says Loading…
                    can you assist?
                      sdetweil @Ron.kamstra
                      @Ron-kamstra Sean has stepped away from MagicMirror
                      @Bugsounet has taken over this module and done some amazing improvements!
                      J 1 Reply Last reply
                        Joe W. @sdetweil
                        same problem, after installing the module, it always says Loading…
                        Any ideas ?
                          sdetweil @Joe W.
                          @joe-w support for MMM-GoogleAssistant is provided on http://forum.bugsounet.fr
                          bugsounetB 1 Reply Last reply
                          • bugsounetB
                            bugsounet Banned @sdetweil
                            @sdetweil if you publish the link of my module board … please send a good link :face_with_tears_of_joy:
                              sdetweil @bugsounet
                              @bugsounet fixed
