Calendar entries showing end time.
Since installing the last 8 commits, calendar is now showing the end time of events.
All-day events, e.g. birthdays, span two days.What’s changed, how do I get it back to normal?
Thanks.
Strange, does no-one else have the same issue?
It is one of the new features in the latest beta. You can turn it off in config.js.
@alvinger said in Calendar entries showing end time.:
Excellent!. How, what needs to be changed?
@richard238 just set showEnd to false.
showEnd: false,
That’s fixed it, thank you.
The “showEnd:” parameter wasn’t listed in my config.js. When was that changed, where’s the documentation?
I don’t really know. I just stumbled upon it browsing through the code in the development branch as I was thinking about implementing end times in my mirror.
It is not even documented in the README, you have to look in calendar.js to find out about the new options.
When the code is moved to the master branch I am sure they will update the documentation (and also change some defaults to be non-reaking such as showEnd which should be false by default)
