    Please help
    29 Posts 6 Posters 24.8k Views 5 Watching
      moris
      Hi folks, I have a problem with the installation. I use a raspberry pi2 and have only made the configuration for the raspi and since I could z.b. Do not save the lxde since it would not exist. The same also with lightdm.conf. Then I have carried out the automatic installation for magicmirror2 what has worked so far. End to the end run display =: 0 non start? what do I have to do now? Is not an experienced programmer and now I do not know what I must push. At the moment, he does not show a mirror. I am using jessie lite. Please do not know any more. Sorry for the english that is google translated. I am from Germany and my English is not so good
        darrene
        Hi @moris, i’m sorry nobody else has responded.
        The automatic Magicmirror2 installation should have done everything necessary. You might need to rotate the screen. If you need to do this, just type sudo /boot/config.txt and put rotate_display=1 at the end. If it all looks okay already, don’t bother with this!
        to run the Magic mirror, make sure you are in the Magicmirror directory:
        cd MagicMirror
        You will need to make a file in the config folder, called config.js. There is a config.js.sample you can use. Just use cp config/config.js.samaple config/config.js to copy it to the file that is needed
        then type:
        npm start
        and the mirror should start :)
        Hallo @moris, es tut mir leid, dass niemand sonst reagiert hat.
        Die automatische Magicmirror2 Installation sollte alles Notwendige getan haben. Möglicherweise müssen Sie den Bildschirm drehen. Wenn Sie dies tun müssen, geben Sie einfach sudo /boot/config.txt und setzen rotate_display = 1 am Ende. Wenn alles schon okay aussieht, kümmere dich nicht darum!
        Um den Magic-Spiegel auszuführen, stellen Sie sicher, dass Sie sich im Magicmirror-Verzeichnis befinden:
        cd MagicMirror
        Sie müssen eine Datei im config-Ordner namens config.js erstellen. Es gibt eine config.js.sample, die Sie verwenden können. Verwenden Sie einfach
        cp config / config.js.samaple config / config.js
        um es in die Datei zu kopieren, die benötigt wird
        Dann geben Sie ein:
        npm start
        Und der Spiegel sollte beginnen :)
        M 1 Reply Last reply Reply Quote 3
        • cowboysdudeC Offline
          cowboysdude Module Developer
          Yes any issues please post them… many here would be glad to help! It’s a pretty cool thing to see it running the first time :)
          Thanks @darrene !
            moris
            Many thanks I will test. The best I do it all from again so everything works out. With display Rotate I had already tried had I just not how I start the mirror. Then starts always in the mirror mode or must I always start with the command?
              You can start manually [which I personally prefer] using ‘npm start’ OR you can have it start automatically when the pi boots up using pm2… either way.
              Most prefer pm2 as if you have a power outage etc and the pi restarts the mirror restarts too… I just prefer the manual method well actually because I’m a dinosaur… LOL
                bhepler Module Developer
                For quick reference, the guide to using pm2 to automatically start the mirror process can be found here.
                I remember having trouble getting the UI displayed on my Raspberry PI 2, but I can’t remember what I did specifically to get it up and running. Assuming you are using a keyboard & mouse connected directly to the Pi, try this:
                • Start the Pi’s graphical interface (if it is not already running) by entering startx. You should eventually see a desktop, with a mouse cursor, menu, etc.
                • Open a terminal window using the Menu in the upper left.
                • In that terminal window, type cd ~/MagicMirror followed by npm start.
                That should at least give you your interface. If you are using SSH to issue commands to your mirror remotely, try the following:
                • Once you log into the Pi, navigate to the Magic Mirror directory like so: cd ~/MagicMirror
                • Start the magic mirror and specify that you want it to display on the monitor attached to the Pi: DISPLAY=:0 npm start
                It has been a while since I was playing around with my RPi 2. I think these will help.
                  moris @darrene
                  @darrene I have it reinstalled and exactly according to your guidance held. I am in the MagicMirror folder and wants to insert config.js, he gives me the following:
                  Pi @ raspberrypi: ~ $ cd MagicMirror
                  Pi @ raspberrypi: ~ / MagicMirror $ cp config / config.js.samaple config / config.js
                  Cp: ​​target ‘config.js’ is not a directory
                  And I give afterwards npm start a he gives me the following error message raus:
                  Pi @ raspberrypi: ~ / MagicMirror $ npm start
                  Magicmirror@2.0.0 start / home / pi / MagicMirror
                  Electron js / electron.js
                  / Home / pi / MagicMirror / node_modules / electron-prebuilt / dist / electron: errorWhite loading shared libraries: libgtk-x11-2.0.so.0: Can not open sharedObject file: No suchfile or directory
                  Npm ERR! Linux 4.4.26-v7 +
                  Npm ERR! Argv “/ usr / bin / nodejs” “/ usr / bin / npm” “start”
                  Npm ERR! node v6.9.1
                  Npm ERR! npm v3.10.8
                  Npm ERR! file sh
                  Npm ERR! code ELIFECYCLE
                  Npm ERR! errno ENOENT
                  Npm ERR! syscall spawn
                  Npm ERR! Magicmirror@2.0.0 start: electron js / electron.js
                  Npm ERR! spawn ENOENT
                  Npm ERR!
                  Npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js / electron.js’.
                  Npm ERR! Make sure you have the latest version of node.js and npm installed.
                  Npm ERR! If you do, this is most likely a problem with the magicmirror package,
                  Npm ERR! Not with npm itself.
                  Npm ERR! Tell the author that this fails on your system:
                  Npm ERR! Electron js / electron.js
                  Npm ERR! You can get information on how to open an issue for this project with:
                  Npm ERR! Npm bugs magicmirror
                  Npm ERR! Or if you are not available, you can get their info via:
                  Npm ERR! Npm owner ls magicmirror
                  Npm ERR! There is probably additional logging output above.
                  Npm ERR! Please include the following file with any support request:
                  Npm ERR! /home/pi/MagicMirror/npm-debug.log
                  Synonymous rotate_display =: 1 in config.txt entered. Since nothing has done synonymous no turning the display.
                  Startx he made garnix. Something I’m doing wrong. It did with ssh and once without ssh
                    bhepler Module Developer @moris
                    @moris said in Please help:
                    There’s a problem in your second command. There should be no space between config and the slash. There needs to be a period at the end of sample. It should read like so: cp config/config.js.sample config/config.js
                    That line breaks down into command-source-destination. “Copy”-“sample file”-“destination file”. cp config/config.js.sample config/config.js
                      darrene
                      @Moris, when you use the copy (cp) command, I think you have spaces where you shouldn’t.
                      if you are in the MagicMirror folder, the command should be;
                      cp(space)config/config.js.sample(space)config/config.js
                      it is possible to use to auto-complete the text where a file or folder exists if you want to.
                      I am not sure why you are getting the Npm ERR! messages. I’m hoping someone else can help here. Are you using npm start on the pi locally or are you SSH’ing into it? I’ve only ever started mine when I am on the Pi itself.
                      Edit: @bhepler is a faster typer than me! :)
                      your /boot/config.txt should only have =1 and not =:1 for the display_rotate command. Here is an example;
                      # For more options and information see
                      # http://www.raspberrypi.org/documentation/configuration/config-txt.md
                      # Some settings may impact device functionality. See link above for details
                      # uncomment if you get no picture on HDMI for a default "safe" mode
                      #hdmi_safe=1
                      # uncomment this if your display has a black border of unused pixels visible
                      # and your display can output without overscan
                      #disable_overscan=1
                      # uncomment the following to adjust overscan. Use positive numbers if console
                      # goes off screen, and negative if there is too much border
                      #overscan_left=16
                       #overscan_right=16
                      #overscan_top=16
                      #overscan_bottom=16
                      # uncomment to force a console size. By default it will be display's size minus
                      # overscan.
                      #framebuffer_width=1280
                      #framebuffer_height=720
                      # uncomment if hdmi display is not detected and composite is being output
                      #hdmi_force_hotplug=1
                      # uncomment to force a specific HDMI mode (this will force VGA)
                      #hdmi_group=1
                      #hdmi_mode=1
                      # uncomment to force a HDMI mode rather than DVI. This can make audio work in
                      # DMT (computer monitor) modes
                      #hdmi_drive=2
                      # uncomment to increase signal to HDMI, if you have interference, blanking, or
                      # no display
                      #config_hdmi_boost=4
                      # uncomment for composite PAL
                      #sdtv_mode=2
                      #uncomment to overclock the arm. 700 MHz is the default.
                      #arm_freq=800
                      # Uncomment some or all of these to enable the optional hardware interfaces
                      #dtparam=i2c_arm=on
                      #dtparam=i2s=on
                      #dtparam=spi=on
                      # Uncomment this to enable the lirc-rpi module
                      #dtoverlay=lirc-rpi
                      # Additional overlays and parameters are documented /boot/overlays/README
                      # Enable audio (loads snd_bcm2835)
                      dtparam=audio=on
                      display_rotate=1
                      Hope that helps!
                        moris
                        This is really fast here with answers. respect. I have no space between config and slash made that is so created when copying from the text. I wrote exactly as you showed it nevertheless, he says there is no folder available. But I see the sample I wrote samaple the whole time maybe this could be the error? Npm start I have with and without ssh tested in the cd MagicMirror and with both the same error. Has what with the config.js to do because it was not?
                          moris
                          Ok the problem with config.js is allright. I have write samaple the wrong. With sample is korrekt. But npm start have the same problem. Display Rotate. Why the error ?
                          • L Offline
                            leisi
                            Uahahha, i´ve the same or a similar problem:
                            Hardware: Pi3 with following error, Please help me, whats the problem with my mirror?
                            I can´t open the config/config.js file for editing and add. i get this error while npm start:
                            (An answer in german would be nice, thanks)
                            pi@magicmirror:~/MagicMirror $ git pull
                            Already up-to-date.
                            pi@magicmirror:~/MagicMirror $ git status
                            Auf Branch master
                            Ihr Branch ist auf dem selben Stand wie ‘origin/master’.
                            nichts zu committen, Arbeitsverzeichnis unverändert
                            pi@magicmirror:~/MagicMirror $ cp config/config.js.sample config/config.js
                            pi@magicmirror:~/MagicMirror $ npm start
                            magicmirror@2.0.0 start /home/pi/MagicMirror
                            electron js/electron.js
                            npm ERR! Linux 4.4.26-v7+
                            npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
                            npm ERR! node v6.9.1
                            npm ERR! npm v3.10.8
                            npm ERR! code ELIFECYCLE
                            npm ERR! magicmirror@2.0.0 start: electron js/electron.js
                            npm ERR! Exit status 1
                            npm ERR!
                            npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
                            npm ERR! If you do, this is most likely a problem with the magicmirror package,
                            npm ERR! not with npm itself.
                            npm ERR! electron js/electron.js
                            npm ERR! npm bugs magicmirror
                            npm ERR! Or if that isn’t available, you can get their info via:
                            npm ERR! npm owner ls magicmirror
                            npm ERR! /home/pi/MagicMirror/npm-debug.log
                            • L Offline
                              leisi @leisi
                              @leisi said in Please help:
                              Already up-to-date.
                              Auf Branch master
                              npm ERR!
                              add. applies my display_rotate file is correct, without the “:”:
                              “/boot/config.txt should only have =1 and not =:1 for the display_rotate command.”
                                darrene
                                have you tried a sudo apt-get update ?
                                It might be worth giving that a try - afterwards, reboot then try re-running npm start again
                                • L Offline
                                  leisi @darrene
                                  @darrene said in Please help:
                                  sudo apt-get update
                                  After the sudo apt-get update again i get following error again:
                                  (connection via SSH from Mac / my OS is Raspbian Jessie)
                                  pi@magicmirror:~ $ cd MagicMirror
                                  npm ERR!
                                  L K 2 Replies Last reply Reply Quote 0
                                  • L Offline
                                    leisi @leisi
                                    sudo apt-get update
                                    npm ERR!
                                    reboot would naturally also done after the update…
                                    • K Offline
                                      KirAsh4 Moderator @leisi
                                      sudo apt-get update
                                      I lost count on how many times this has come up already. You can not start the mirror using that command when you are remotely SSHd into the rpi. The rpi simply does not know what monitor to use, yours, or the one connected to it. You have to tell it that:
                                      Use the correct command, and then figure out what the problems are.
                                      L 1 Reply Last reply Reply Quote 1
                                      • L Offline
                                        leisi @KirAsh4
                                        @KirAsh4 oh fucking, yes, you´re right, thanks very much for your help.
                                          cowboysdude Module Developer @leisi
                                          While I find it humorous please be careful with replies… we don’t know how many youngsters we have roaming around here. Appreciate it! :)
                                          • L Offline
                                            leisi @cowboysdude
                                            @cowboysdude ok, pardon, my mistkake, i´ll do it next time, i´m so proud of my new magicmirror…
