    MM to run only between certain times
    3 Posts 2 Posters 1.1k Views 4 Watching
    • A
      AJSG
      I am building a MM for my child based on a Pico projector and RPI. I would like the screen to come on at a certain time and then switch off at X time. For example start at 06:30 and close at 08:30 to avoid burning the projector.
      Basically I’m building this into an R2 D2 shell, which will wake up with a Leia video (dubbed), then display weather/time for an hour or so and then shut off the projector/screen.
      In theory I’d like this sequence in crontab:
      06:30 switch on projector via USB relay
      06:32 play leia.mp4 via omxplayer
      06:34 load Magic Mirror
      08:30 unload Magic Mirror
      08:31 switch off projector via USB relay
      How can I control Magic Mirror from crontab??
      Should I play the video alarm before MM or within MM??
      Any suggestion would be most welcome.
      Thanks,
      Andrew.
      justjim1220J 1 Reply Last reply
      Reply Quote 1
      • justjim1220J
        justjim1220 Module Developer @AJSG
        @ajsg
        https://github.com/ianperrin/MMM-ModuleScheduler
        https://github.com/fewieden/MMM-AlarmClock
        “Life’s Too Short To Dance With Ugly People”
        Jim Hallock - 1995
        Reply Quote 1
        • A
          AJSG
          Thank you Jim, I will try those. Ideally I would like to go from Desktop to MM via crontab and back, without having to brute force it via pkill or similar.
          Do you have any suggestions?
          I need to be able run the relay scripts, or if connected to a monitor the vcgencmd command before and after MM.
          Thanks,
          Andrew.
