Black screen after starting
But do not I have to enter the IP to run the Remte Module or the MMM NetworkScanner?
I still have another problem :) I do not know if I would like to open a new topic or if I can place it here.
It’s about the module email-mirror, it always shows only “load”, I don’t know what I’m doing wrong
@cyrus1337 said in Black screen after starting:
The “listening” address in the config does not affect the behaviour of the other modules. It does not determine the IP of your mirror!
The other modules get the mirror’s IP from somewhere else, don’t worry.
The address e’re talking about here is there to determine on which network device to listen (if I understand correctly!).
0.0.0.0 specifies “use them all”
You won’t do any harm using that. -
Ok thank you. Then I will use 0.0.0.0
Thanks again for your help !!! That’s really great
