    Outdated npm packages occur several vulnerabilities
    1 Posts 1 Posters 3.1k Views 1 Watching
    • A
      awsoo
      Hello,
      a lot of packages are outdated and there are several vulnerabilities which I get after the installation.
      I am not getting run the magic mirror.
      Any suggestions?
      pi@raspberrypi:~/MagicMirror $ node -v
      v10.13.0
      pi@raspberrypi:~/MagicMirror $ npm -v
      6.4.1
      Output after installation on RaspBerry Pi 3, Raspbian Jessie Lite:
      added 945 packages from 964 contributors and audited 2510 packages in 493.451s
      found 79 vulnerabilities (31 low, 32 moderate, 15 high, 1 critical)
        run `npm audit fix` to fix them, or `npm audit` for details
      Outdated packages:
      pi@raspberrypi:~/MagicMirror $ npm outdated
      Package             Current   Wanted   Latest  Location
      body-parser          1.18.2   1.18.3   1.18.3  magicmirror
      chai                  4.1.2    4.2.0    4.2.0  magicmirror
      colors                1.1.2    1.3.2    1.3.2  magicmirror
      danger                3.1.3    3.9.0    6.0.2  magicmirror
      electron              2.0.0   2.0.13    3.0.7  magicmirror
      express              4.16.2   4.16.4   4.16.4  magicmirror
      grunt-markdownlint   1.0.43    1.1.6    2.1.0  magicmirror
      helmet                3.9.0   3.14.0   3.14.0  magicmirror
      jsdom                11.6.2  11.12.0   13.0.0  magicmirror
      jshint                2.9.5    2.9.6    2.9.6  magicmirror
      mocha                 4.1.0    4.1.0    5.2.0  magicmirror
      mocha-logger          1.0.5    1.0.6    1.0.6  magicmirror
      request              2.83.0   2.88.0   2.88.0  magicmirror
      rrule-alt             2.2.7    2.2.8    2.2.8  magicmirror
      simple-git           1.85.0  1.106.0  1.106.0  magicmirror
      socket.io             2.0.4    2.1.1    2.1.1  magicmirror
      spectron              3.7.2    3.7.3    5.0.0  magicmirror
      stylelint             8.4.0    8.4.0    9.7.1  magicmirror
      npm audit fix:
      > phantomjs-prebuilt@2.1.16 install /home/pi/MagicMirror/node_modules/phantomjs-prebuilt
      > node install.js
      PhantomJS not found on PATH
      Unexpected platform or architecture: linux/arm
      It seems there is no binary available for your platform/architecture
      Try to install PhantomJS globally
      npm WARN acorn-jsx@5.0.0 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: phantomjs-prebuilt@2.1.16 (node_modules/phantomjs-prebuilt):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: phantomjs-prebuilt@2.1.16 install: `node install.js`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      + socket.io@2.1.1
      + jshint@2.9.6
      + request@2.88.0
      + mocha-logger@1.0.6
      added 30 packages from 33 contributors, removed 32 packages, updated 37 packages and moved 1 package in 65.581s
      fixed 37 of 79 vulnerabilities in 2510 scanned packages
        1 vulnerability required manual review and could not be updated
        3 package updates for 41 vulns involved breaking changes
        (use `npm audit fix --force` to install breaking changes; or refer to `npm audit` for steps to fix these manually)
      after npm update list of outdated packages:
      danger                3.9.0    3.9.0   6.0.2  magicmirror
      electron             2.0.13   2.0.13   3.0.7  magicmirror
      grunt-markdownlint    1.1.6    1.1.6   2.1.0  magicmirror
      jsdom               11.12.0  11.12.0  13.0.0  magicmirror
      spectron              3.7.3    3.8.0   5.0.0  magicmirror
      After all updates and upgrades the list of npm audit:
      pi@raspberrypi:~/MagicMirror $ npm audit
                             === npm audit security report ===
      # Run  npm install spectron@5.0.0  to resolve 3 vulnerabilities
      SEMVER WARNING: Recommended action is a potentially breaking change
      │ High          │ Regular Expression Denial of Service                         │
      │ Package       │ sshpk                                                        │
      │ Dependency of │ spectron                                                     │
      │ Path          │ spectron > electron-chromedriver > electron-download >       │
      │               │ nugget > request > http-signature > sshpk                    │
      │ More info     │ https://nodesecurity.io/advisories/606                       │
      │ Package       │ sshpk                                                        │
      │ Path          │ spectron > request > http-signature > sshpk                  │
      │ Package       │ sshpk                                                        │
      │ Path          │ spectron > webdriverio > request > http-signature > sshpk    │
      # Run  npm install --save-dev stylelint@9.7.1  to resolve 4 vulnerabilities
      │ Low           │ Prototype Pollution                                          │
      │ Package       │ lodash                                                       │
      │ Dependency of │ stylelint [dev]                                              │
      │ Path          │ stylelint > lodash                                           │
      │ More info     │ https://nodesecurity.io/advisories/577                       │
      │ Path          │ stylelint > postcss-reporter > lodash                        │
      │ Path          │ stylelint > table > lodash                                   │
      │ Low           │ Cryptographically Weak PRNG                                  │
      │ Package       │ randomatic                                                   │
      │ Path          │ stylelint > micromatch > braces > expand-range > fill-range  │
      │               │ > randomatic                                                 │
      │ More info     │ https://nodesecurity.io/advisories/157                       │
      # Run  npm update sshpk --depth 6  to resolve 5 vulnerabilities
      │ Package       │ sshpk                                                        │
      │ Dependency of │ electron                                                     │
      │ Path          │ electron > electron-download > nugget > request >            │
      │               │ http-signature > sshpk                                       │
      │ Package       │ sshpk                                                        │
      │ Dependency of │ request                                                      │
      │ Path          │ request > http-signature > sshpk                             │
      │ Package       │ sshpk                                                        │
      │ Dependency of │ jsdom                                                        │
      │ Path          │ jsdom > request > http-signature > sshpk                     │
      │ Package       │ sshpk                                                        │
      │ Dependency of │ jshint                                                       │
      │ Path          │ jshint > phantom > phantomjs-prebuilt > request >            │
      │ Package       │ sshpk                                                        │
      │ Path          │ jshint > phantomjs-prebuilt > request > http-signature >     │
      │               │ sshpk                                                        │
      │                                Manual Review                                 │
      │            Some vulnerabilities require your attention to resolve            │
      │         Visit https://go.npm.me/audit-guide for additional guidance          │
      │ Patched in    │ >=4.17.5                                                     │
      │ Dependency of │ express-ipfilter                                             │
      │ Path          │ express-ipfilter > lodash                                    │
      One of the suggestions is occurs this:
      pi@raspberrypi:~/MagicMirror $ npm install --save-dev stylelint@9.7.1
      npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/sshpk
      npm ERR! path /home/pi/MagicMirror/node_modules/sshpk
      npm ERR! code EACCES
      npm ERR! errno -13
      npm ERR! syscall access
      npm ERR! Error: EACCES: permission denied, access '/home/pi/MagicMirror/node_modules/sshpk'
      npm ERR!  { [Error: EACCES: permission denied, access '/home/pi/MagicMirror/node_modules/sshpk']
      npm ERR!   stack:
      npm ERR!    'Error: EACCES: permission denied, access \'/home/pi/MagicMirror/node_modules/sshpk\'',
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path: '/home/pi/MagicMirror/node_modules/sshpk' }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator (though this is not recommended).
      npm ERR!     /home/pi/.npm/_logs/2018-11-01T21_58_27_349Z-debug.log
      Some of the packages need sudo to get updated successfully o_O
      Alter all :
      sudo npm install --save-dev spectron@5.0.0 mocha@5.2.0 jsdom@13.0.0 grunt-markdownlint@2.1.0 electron@3.0.7 danger@6.0.2
      output:
      electron  MISSING   3.0.7   3.0.7  magicmirror
      so I tried to install electron again:
      pi@raspberrypi:~/MagicMirror $ npm install electron@latest -g
      npm WARN checkPermissions Missing write access to /usr/lib/node_modules
      npm ERR! path /usr/lib/node_modules
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules'
      npm ERR!  { [Error: EACCES: permission denied, access '/usr/lib/node_modules']
      npm ERR!   stack:
      npm ERR!    'Error: EACCES: permission denied, access \'/usr/lib/node_modules\'',
      npm ERR!   path: '/usr/lib/node_modules' }
      npm ERR!
      npm ERR!
      npm ERR!     /home/pi/.npm/_logs/2018-11-01T22_32_58_797Z-debug.log
      seems to be a bad idea to install electron as sudo.
      After all the installation and upgrades as you can see the audit:
      npm ERR! code ELOCKVERIFY
      npm ERR! Errors were found in your package-lock.json, run  npm install  to fix them.
      npm ERR!     Missing: danger@^6.0.2
      npm ERR!     Missing: grunt-markdownlint@^2.1.0
      npm ERR!     Missing: jsdom@^13.0.0
      npm ERR!     Missing: mocha@^5.2.0
      npm ERR!     Missing: spectron@^5.0.0
      now i tried to start:
      pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 nohup npm start &
      [1] 3939
      pi@raspberrypi:~/MagicMirror $ nohup: ignoring input and appending output to 'nohup.out'
      content of the file nohup.out:
      > magicmirror@2.5.0 start /home/pi/MagicMirror
      > sh run-start.sh
      /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-3.so.0: cannot open shared object file: No such file or directory
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.5.0 start: `sh run-start.sh`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.5.0 start script.
      npm ERR!     /home/pi/.npm/_logs/2018-11-01T22_49_36_884Z-debug.log
      log file 2018-11-01T22_49_36_884Z-debug.log
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@6.4.1
      3 info using node@v10.13.0
      5 info lifecycle magicmirror@2.5.0~prestart: magicmirror@2.5.0
      6 info lifecycle magicmirror@2.5.0~start: magicmirror@2.5.0
      7 verbose lifecycle magicmirror@2.5.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.5.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.5.0~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.5.0~start: Args: [ '-c', 'sh run-start.sh' ]
      11 info lifecycle magicmirror@2.5.0~start: Failed to exec start script
      12 verbose stack Error: magicmirror@2.5.0 start: `sh run-start.sh`
      12 verbose stack spawn ENOENT
      12 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
      12 verbose stack     at ChildProcess.emit (events.js:182:13)
      12 verbose stack     at maybeClose (internal/child_process.js:962:16)
      12 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5)
      13 verbose pkgid magicmirror@2.5.0
      14 verbose cwd /home/pi/MagicMirror
      15 verbose Linux 4.14.71-v7+
      16 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
      17 verbose node v10.13.0
      18 verbose npm  v6.4.1
      19 error file sh
      20 error code ELIFECYCLE
      21 error errno ENOENT
      22 error syscall spawn
      23 error magicmirror@2.5.0 start: `sh run-start.sh`
      23 error spawn ENOENT
      24 error Failed at the magicmirror@2.5.0 start script.
      24 error This is probably not a problem with npm. There is likely additional logging output above.
      25 verbose exit [ 1, true ]
      There are no Permission errors.
      sudo chown -R $(whoami) ~/../../usr/lib/node_modules/
      sudo chown -R $(whoami) ~/.npm/
      Any suggestions?
      I had to install the desktop environment to get it work.
      Best way is to follow the constructions here:
      https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
      Thanks to @lavolp3 https://forum.magicmirror.builders/post/46231
      After the installation of desktop enviroenment I could run the magic mirror without errors. “Launched application.” But nothing could be seen. I removed all began a fresh installation but ended with the same problems and new issiues.
      I think this project is out of the date and needs a lot of time and work to get worked.
