    libCEC LG TV
    6 Posts 3 Posters 2.6k Views 3 Watching
    • R
      rsl
      Re: Send on/off to the screen via IR
      • R
        rsl
        Hi.
        I searched the forum but I can not find the information why the command doest not work:
        TV Off:
        echo “standby 0” | cec-client -s -d 1
        Tv on and scan working fine.
        • R
          rsl
          Ok. I found the answer here:
          https://github.com/Pulse-Eight/libcec/issues/363
          “LG do not support Power Off (Standby) in their CEC implementation”
          I use pir sensor and relay to turn off/on TV. Is there any other solution to turn off/on the screen but that the OSD does not show up?
          • Y
            yawns Moderator
            Since you cannot put your tv into standby via CEC I guess you have to find a hardware way. You should analyze the button panel of your screen and see if you can simulate pressing the power button of your screen via relay/gpio
            • R
              rsl
              There is no power button, there is a small joystick. you have to move and press. I am thinking about controlling the power supply - relay, it works. Only when TV turning on, shows the LG start screen /input screen- OSD
              • L
                lijon
                Are there any secret codes for LG TV…?
