    Default Calender relative removes start time
    14 Posts 3 Posters 7.2k Views 3 Watching
    • C Offline
      cptkex
      Hello everyone! First time poster, and a newbie when it comes to Linux and the Raspberry PI.
      I am in the process of creating my own Magic mirror, but i was wondering what i need to do to change how the relative time for calender events is displayed?
      right now, i´ve got it set to absolute up until 5 hours before, then it goes into relative mode.
      So in absolute form
      Meeting 25th november 1000-1800
      But, five hours before this, it goes into relative mode
      Meeting 25th november in five hours - 1800
      It seems to remove the start time of any event, and i would like to have both, so even when it goes relative, i would like to keep the start time after the countdown, so like this:
      Meeting 25th november in five hours 1000-1800
      is it possible and where do i need to alter the code of the pre installed calender module?
      Hoping for some beginner-level help!
      • lavolp3L Offline
        lavolp3 Module Developer @cptkex
        @cptkex That’s an interesting question!
        I’m working on manipulating the calendar and moment.js as well.
        The line you are looking for is line 302
        timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").fromNow());
        .fromnow() creates the “in five hours” entry. You would have to stuff the beginning time into that, maybe it would work like this:
        timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").fromNow()) + moment(event.startDate).format('HH:mm');
        This could work…
        In your calendar, do you really have this entry?
        “Meeting 25th november in five hours - 1800”
        Because then it seems you have already manpulatied the entry to also show the date!?
        C 2 Replies Last reply Reply Quote 0
        • C Offline
          cptkex @lavolp3
          @lavolp3 thanks for that suggestion, ill try that tonight when i get home!
          I will have to check when i get home, i was moving between the three options of absolute, relative and dateheader and i dont really remember if it gave me the date when i switched back to absolute.
          ill doublecheck tonight, because i was trying to achieve my wish of having the start time to be absolute by changing the startdate variable to MMM Do HH:mm. ill get back to you on this. Again, sorry, kind of new at this.
          • lavolp3L Offline
            @cptkex
            Aha! The “dateheaders” option is quite new and I haven’t seen that before. Will check that out as well
            • C Offline
              cptkex @lavolp3
              @lavolp3 I’m home and I was mistaken. It does not show the date when it goes into relative, only the end time. I will try your code later tonight and see if it works.
              • C Offline
                cptkex @lavolp3
                @lavolp3 i tried your addition to the code but it only said
                meeting in 5 hoursInvalid Date-1800
                lavolp3L 2 Replies Last reply Reply Quote 0
                • lavolp3L Offline
                  This post is deleted!
                  • lavolp3L Offline
                    @cptkex There is an open issue that might describe the same issue:
                    https://github.com/MichMich/MagicMirror/issues/1457
                    Yours?
                    Else it might be worth following.
                    • C Offline
                      cptkex @lavolp3
                      @lavolp3 not mine, but thanks, i will keep an eye on it
                      • lavolp3L Offline
                        @cptkex
                        You could try this
                        timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").fromNow()) + this.capFirst(moment(event.startDate, "x").format(this.config.dateEndFormat));
                        I took the dirty way to use the dateEndFormat variable for a starting time.
                        This is just a guess! I haven’t tried it out yet…
                        • BKeyportB Online
                          BKeyport Module Developer
                          because of the ending times, I went 100% absolute. works best on a small screen, too…
                          dateFormat: “M/D h:mm a”,
                          fullDateEventDateFormat: “M/D”,
                          timeFormat: “absolute”,
                          getRelative: 0,
                          urgency: 0,
                          dateEndFormat: “h:mm a”,
                          • lavolp3L Offline
                            lavolp3 Module Developer @BKeyport
                            @bkeyport that’s what I would recommend otherwise as well.
                            I’m using the same config with the timeFormat: ‘dateheaders’ but for some reason I’m missing the ending times…
                            • lavolp3L Offline
                              lavolp3 Module Developer @lavolp3
                              A bit offtopic, sorry, but wanted to write it down:
                              The (quite) new ‘dateheaders’ option is a bit odd.
                              It neglects most of the other options like urgency, today/tomorrow, getrelative, showEnd (i.e. shows only the starting time of an event).
                              I guess it would need to be placed somewhere else in the code and be more integrated.
                              • C Offline
                                cptkex @lavolp3
                                @lavolp3 thanks i will try it!
