    Synology Docker Tutorial?
    15 Posts 9 Posters 5.9k Views 10 Watching
    • O Offline
      odolmach3 @wishmaster270
      @wishmaster270 said in Synology Docker Tutorial?:
      npm run server
      Thank you, that does the Trick!
      • T Offline
        techeros
        karsten13 on my Synology
        Hi everyone so I was having a lot of issues getting MagicMirror installed.
        Do not bother trying to install bastilimbach, it will install but you wont be able to get the calendar working.
        Instead follow these steps on your Synology. I made it simple incase you are not used to working with putty etc etc
        Download and install Putty
        setup the connection to poin to your IP address and port 22
        Once you connect, type your admin user and pass
        1. Uninstall MagicMirror
          Run these commands to completely remove the existing MagicMirror setup:
        Stop and Remove the Container
        bash
        sudo docker stop magicmirror
        sudo docker rm magicmirror
        Remove the Image
        bash
        sudo docker rmi karsten13/magicmirror:latest
        Delete Configuration Files
        (Optional, if you want a clean start):
        sudo rm -rf /volume1/docker/magicmirror
        1. Install MagicMirror
          Follow these steps to reinstall MagicMirror:
        Create Necessary Directories
        Copy code
        mkdir -p /volume1/docker/magicmirror/{config,modules,css}
        sudo chown -R 1000:1000 /volume1/docker/magicmirror
        Pull the MagicMirror Image
        sudo docker pull karsten13/magicmirror:latest
        Run the MagicMirror Container
        sudo docker run -d
        –name magicmirror
        –publish 8036:8080
        –restart unless-stopped
        -e TZ=America/Chicago
        –volume /volume1/docker/magicmirror/config:/opt/magic_mirror/config
        –volume /volume1/docker/magicmirror/modules:/opt/magic_mirror/modules
        –volume /volume1/docker/magicmirror/css:/opt/magic_mirror/css
        1. Verify the Installation
          Check that the container is running:
        sudo docker ps
        Look for magicmirror in the list.
        The STATUS column should say Up.
        Open MagicMirror in your browser:
        http://<Your_NAS_IP>:8036
        Replace <Your_NAS_IP> with your Synology NAS’s IP address in your web browser
        • wishmaster270W Offline
          wishmaster270 Module Developer @techeros
          @techeros Sorry. But you can use the container manager gui in the Web interface for most of the job. No need to pull or remove any images on the shell manually.
          T S 2 Replies Last reply Reply Quote 0
          • T Offline
            techeros @wishmaster270
            @wishmaster270
            Sure, If you could so kindly point me to the documentation, Id love to. Im just getting started with Containers on my synology and have been fighting tooth and nail to get it installed.
            If I select the image kristen13 and install non of the directories are created, nothing works.
            If You use the manual instructions i posted, it works (for me). I have a lot to learn here so , if im way off-base i’m all ears.
            Thanks for chiming in
            T
              sdetweil @wishmaster270
              @wishmaster270 my 416j+ doesn’t officially support docker, so there is no ui.
