    Window size and position / Configuration with arrays in general
    Scheduled Pinned Locked Moved Feature Requests
    1 Posts 1 Posters 2.2k Views 1 Watching
    • berlincountB Offline
      berlincount
      Hi!
      I’m the one who filed https://github.com/MichMich/MagicMirror/pull/484, which added single configuration options like window_x, window_y, window_height, etc …
      MichMich’s recommendation was to use an array like
      window: {
      width: 1920,
      height: 1080,
      x: 0,
      y: 0
      … which as such would be fine, but horrible to override.
      As the config-loading code uses Object.assign(defaults, config) to override defaults from the config, the whole Array would have to be given - even if only one option would be needed.
      As it would be awesome to just take the whole Array passed to the BrowserWindow call, a generic way of overriding individual defaults Array entries (including unsetting some) from the config would be nice. I’m currently having trouble wrapping my head around this, so I’m reaching out :)
      Ideas?
      count
