    Little voice testing.....
    25 Posts 8 Posters 14.1k Views 8 Watching
      mdhenriksen @dazza120
      @dazza120 Hey Dazza! I’ve encountered the “ERROR” message with MMM-voice a couple of times as well. I’m not sure what’s going on in your case, but I’ve noticed two things:
      1. The voice recognition still works (at least for me). You just have to say your keyword (Magic Mirror) and the ERROR message will disappear and you will be able to use it as normal.
      2. For me it happens when I close down the window for Magic Mirror without closing the terminal connected to it. Then it will re-open with the error - Probably because it doesn’t get to load in properly.
        dazza120
        @cowboysdude thank you for your response I’ll start a new thread on the voice module thanks
          dazza120 @mdhenriksen
          @mdhenriksen as you said that’s exactly how it behaves, so yes you are right it works as it should but that error is so annoying lol thanks
            @dazza120 Then it’s probably because it doesn’t load in properly. Why don’t you just let it be active on all pages? You can just make the module invisible if you don’t like the icon and text being there.
              @mdhenriksen yeah that’s not it I’ve made it visible in all, I changed it a while ago :) that’s how I noticed but if I go through it with VNC no errors at all, it’s got to be how the web page is handling it, I’ve got the mmm-Hue-Lights erroring as well only when I view it from that but most of the time I’m using the VNC to view it anyway so no real big deal just annoying when I do 😂
