    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 915.5k Views 74 Watching
      BD0G @sdetweil
      I ran the sudo killall chromium-browser and response was
      chromium-browser : no process found
        sdetweil @BD0G
        @BD0G ok
        sudo killall /usr/lib/chromium-browser/chromium-browser
          BD0G
          That killed the browser window I had open and then returned to the command prompt
            sdetweil @BD0G
            @BD0G ok, and the ls results
            I work from my windows machine and ssh into the pi.
            use bitvise ssh client… opens a terminal window and a file browser window at the same time…
            double click on files to edit
            commands in the ssh window… almost never go to the actual mirror screen, except for the dev window
              BD0G
              ls results? You lost me there. ssh has been painfully slow when using Putty.
                sdetweil @BD0G
                @BD0G back a few messages
                ls ~/MagicMirror/modules/MMM-darkSkyForecast
                  BD0G
                  Here it is
                  pi@raspberrypi:~/MagicMirror/modules $ ls ~/MagicMirror/modules/MMM-darkSkyForecast
                  icons node_helper.js README.md
                  MMM-DarkSkyForecast.css node_modules skycons.js
                  MMM-DarkSkyForecast.js package.json
                  mmm-darksky-forecast.njk package-lock.json
                    sdetweil @BD0G
                    @BD0G said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                    file name is uppercase D
                    all has to match
                    change the name of the folder and the entry in config.js
                    S B 2 Replies Last reply Reply Quote 0
                      @BD0G to git clone, find the project on github, push the green clone or download button, then push the clipbpard icon. it will copy the repo url to the clipboard for you
                      past that behind git clone
                        BD0G @sdetweil
                        I renamed the Directory under modules to reflect a capital D in the name DarkSkyForecast. Since there is already a capital D within the name of the module within the config.js file then no change is needed to the config.js. Correct?
                          sdetweil @BD0G
                          Since there is already a capital D within the config.js file
                          the error says otherwise
                          Could not find main module js file for MMM-darkSkyForecast
                          this means Mirror went to the folder, and tried to find MMM-darkSkyForecast.js,
                          but it wasn’t present… ONLY way to get that is from the config.js
                            BD0G
                            OK. I checked and the name of the directory is
                            MMM-DarkSkyForecast (with a capital D)
                            The name of the file below that directory is
                            MMM-DarkSkyForecast.js (with capital D)
                            and the entry in the config.js is
                            module: “MMM-DarkSkyForecast”, (with capital D)
                              sdetweil @BD0G
                              @BD0G ok, fire it up…
                                BD0G
                                This is the exact way I installed as per the instructions upon the GitHub.com page for MMM-DarkSkyForecast
                                Installation
                                Navigate into your MagicMirror modules folder and execute
                                git clone https://github.com/jclarke0000/MMM-DarkSkyForecast.git.
                                Enter the new MMM-DarkSkyForecast directory and execute npm install.
                                It created a directory with a lowercase d within the name MMM-DarkSkyForecast under /MagicMirror/modules
                                  sdetweil @BD0G
                                  @BD0G ok, never seen that happen
                                    BD0G
                                    Wow! Now I see the weather! Now I will change the Celsius to Fahrenheit and wind speed to Miles Per Hour instead of Kilometers Per Hour
                                      sdetweil @BD0G
                                      @BD0G cool…
                                        mrdenmark
                                        @j-e-f-f
                                        is it possible to have a space/blank line between the hourly and daily forecasts in the table view?
                                          sdetweil @mrdenmark
                                          This post is deleted!
                                            mrdenmark @sdetweil
                                            @sdetweil sorry,posted the question to the wrong person-changed now!
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
