    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 823.9k Views 74 Watching
      @BD0G but this could be a clue
      Could not find main module js file for MMM-darkSkyForecast
      the system is case sensitive…
      so, the module name in config.js is 'MMM-DarkSkyForecast"
      (notice u have a lowercase d)
      the folder in modules, should be the same MMM-DarkSkyForecast ( created from the git clone)
        BD0G
        Just checked and the module name in the module directory is
        MMM-darkSkyForecast and that was created by git cloning as stated in the instructions from the GitHub Repository.
        So the name of the directory DOES have a lowercase d in it.
          sdetweil @BD0G
          @BD0G can’t be
          git clone https://github.com/jclarke0000/MMM-DarkSkyForecast.git
          will produce folder MMM-DarkSkyForecast
            sdetweil @BD0G
            @BD0G what are the filenames INSIDE the folder?
              BD0G
              When I issue the ps -ef | grep node
              it returns pi 988 811 3 17:20 pts/0 00:00:00 grep --color=auto node
                sdetweil @BD0G
                @BD0G ok, and how about
                ps -ef | grep chromium
                  BD0G
                  Here is the response
                  pi 904 588 30 17:22 ? 00:00:14 /usr/lib/chromium-browser/chromium-browser --disable-quic --enable-tcp-fast-open --enable-pinch
                  pi 924 904 3 17:22 ? 00:00:01 /usr/lib/chromium-browser/chromium-browser --type=zygote
                  pi 926 924 0 17:22 ? 00:00:00 /usr/lib/chromium-browser/chromium-browser --type=zygote
                  pi 947 904 21 17:22 ? 00:00:08 /usr/lib/chromium-browser/chromium-browser --type=gpu-process --field-trial-handle=7332482715831649297,2455911672236890155,131072 --gpu-preferences=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 --service-request-channel-token=5493558882893021086
                  pi 951 904 6 17:22 ? 00:00:02 /usr/lib/chromium-browser/chromium-browser --type=utility --field-trial-handle=7332482715831649297,2455911672236890155,131072 --lang=en-US --service-sandbox-type=network --disable-quic --service-request-channel-token=14967951688445977275 --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                  pi 1034 926 6 17:23 ? 00:00:01 /usr/lib/chromium-browser/chromium-browser --type=renderer --field-trial-handle=7332482715831649297,2455911672236890155,131072 --lang=en-US --instant-process --enable-offline-auto-reload --enable-offline-auto-reload-visible-only --num-raster-threads=1 --service-request-channel-token=17867901049141360113 --renderer-client-id=7 --no-v8-untrusted-code-mitigations --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                  pi 1135 926 15 17:23 ? 00:00:03 /usr/lib/chromium-browser/chromium-browser --type=renderer --field-trial-handle=7332482715831649297,2455911672236890155,131072 --lang=en-US --extension-process --enable-offline-auto-reload --enable-offline-auto-reload-visible-only --num-raster-threads=1 --service-request-channel-token=8805285444412210348 --renderer-client-id=4 --no-v8-untrusted-code-mitigations --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                  pi 1189 926 16 17:23 ? 00:00:03 /usr/lib/chromium-browser/chromium-browser --type=renderer --field-trial-handle=7332482715831649297,2455911672236890155,131072 --lang=en-US --extension-process --enable-offline-auto-reload --enable-offline-auto-reload-visible-only --num-raster-threads=1 --service-request-channel-token=2818717241021702166 --renderer-client-id=5 --no-v8-untrusted-code-mitigations --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                  pi 1210 947 0 17:23 ? 00:00:00 /usr/lib/chromium-browser/chromium-browser --type=broker
                  pi 1217 811 0 17:23 pts/0 00:00:00 grep --color=auto chromium
                    BD0G @sdetweil
                    Pinky Swear!
                    It did produce a directory with a lowercase d in the name.
                    Here is listing of the directories under modules
                    pi@raspberrypi:~/MagicMirror/modules $ dir
                    default MMM-darkSkyForecast MMM-Remote-Control node_modules README.md
                      sdetweil @BD0G
                      @BD0G ok,
                      pm2 stop 0
                      should have worked
                      sudo killall chromium-browser
                        sdetweil @BD0G
                        @BD0G said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                        MMM-darkSkyForecast
                        thanks…
                        ls ~/MagicMirror/modules/MMM-darkSkyForecast
                        • 24
                        • 25
                        • 26
                        • 27
                        • 28
                        • 33
                        • 34
                        • 26 / 34
