    Independent display controller based on PIR sensor.
    14 Posts 4 Posters 15.6k Views 6 Watching
    • B
      Beh
      This is not really a module for the MagicMirror application itself, but I wrote it for my own mirror and I want to share it, if anybody has use for it.
      I wanted a turn-off-my-display-control that is independent from the MagicMirror application. It turns off the display after a given countdown time from the last time a motion was detected by a PIR sensor.
      So every time a motion is recognized, the countdown is set to the maximum countdown time. When no motion is noticed for that time, the display is set to sleep. When then a motion is detected, the display is turned on.
      I also provide a systemd service file, if you want to use it as a service.
      If you have use for it, I put it on GitHub:
      [card:deg0nz/MagicMirror-Display-Controller]
      NOTE:
      If you’re looking for an integrated (and probably easier to use) solution, please take a look at paviro’s awesome PIR-Sensor module.
      B 1 Reply Last reply Reply Quote 2
      • B
        bibi @Beh
        @Beh Thx for sharing! One question : what are the physical settings to apply to the sensor itself pls? (Jumper & the 2 knobs)
        • B
          Beh
          Example configurations for wiring are shown here:
          http://www.raspberrypi-spy.co.uk/2013/01/cheap-pir-sensors-and-the-raspberry-pi-part-1/
          and here:
          https://www.raspberrypi.org/learning/parent-detector/worksheet/
          I can’t really tell you the jumper and knob configurations, because I’m using a simple sensor like this:
          https://www.amazon.de/Keyestudio-Pyroelektrische-Infrarot-Bewegungssensor-Bewegungs-Sensor-Arduino/dp/B01GCRQJ0Y/ref=sr_1_9?ie=UTF8&qid=1478275900&sr=8-9&keywords=PIR+sensor
          Maybe you look in the PIR HOWTO thread or ask a question there:
          • B
            bibi @Beh
            @Beh i see thx! maybe it’s better to use your one to somehow bypass these settings which are a bit frustrating. i did’t really get the systemd option (i am new) but as i understood it’s like a crontab, correct?
            • B
              Beh @bibi
              @bibi No, it’s more like having it added to the autostart (like on windows). Then it’s running as a service in the background, which can be controlled via systemd’s systemctl command.
              • B
                bibi
                hi @Beh ! unfortunately your module is not working for me :( could you please help me to figure out why? i have bought the same PIR sensor and plug it in the gpio 14 (physical pin 8) thx!
                • B
                  bibi
                  it’s solved ;-) thx anyway
                  • B
                    bibi
                    @beh hi! i was wondering if there was an easy way to add a fading effect when the mirror goes to sleep and wake up? would be interesting in this as well? thx
                    • B
                      Beh @bibi
                      Hi @bibi, I hope, I understand that right.
                      I don’t think that this is very easy. Because the script just turns the HDMI port of the RaspberryPi to on and off. So a fading effect wouldn’t be quite easy I think
                      • B
                        bibi @Beh
                        @Beh i understand this. No problem and thx for reply! :)
                          shashank @bibi
                          @bibi hi can anyone help me with screenshots the file path where to enter the below commands to start it at boot time
                          cp ./pir_sensor.service /lib/systemd/system
                          systemctl daemon-reload
                          systemctl start pir_sensor.service
                          • B
                            bibi @shashank
                            @shashank hi! unfortunately you will not find the cmd line in the github to enable the service at boot time. As far as i have checked, the systemd should already run at boot but for strange reasons it was not the case for me. Therefore, i had to issue the command : sudo systemctl enable pir_sensor.service
                            good luck!
                            • B
                              Beh
                              Ok, maybe I forgot that in the readme file, or it worked straghtaway on my Pi.
                              I’m going to add sudo systemctl enable pir_sensor.service to the readme file!
                              thanks for the hint :)
                              • M
                                McSorley
                                Sounds more effective than mine. I set an infinite loop to check for motion every second and if no motion is detected for 600 seconds the display goes to sleep.
