    Independent display controller based on PIR sensor.
    14 Posts 4 Posters 14.6k Views 6 Watching
      bibi @Beh
      @Beh i see thx! maybe it’s better to use your one to somehow bypass these settings which are a bit frustrating. i did’t really get the systemd option (i am new) but as i understood it’s like a crontab, correct?
      BehB 1 Reply Last reply Reply Quote 0
      • BehB Offline
        Beh @bibi
        @bibi No, it’s more like having it added to the autostart (like on windows). Then it’s running as a service in the background, which can be controlled via systemd’s systemctl command.
          bibi
          hi @Beh ! unfortunately your module is not working for me :( could you please help me to figure out why? i have bought the same PIR sensor and plug it in the gpio 14 (physical pin 8) thx!
            bibi
            it’s solved ;-) thx anyway
              bibi
              @beh hi! i was wondering if there was an easy way to add a fading effect when the mirror goes to sleep and wake up? would be interesting in this as well? thx
              • BehB Offline
                Beh @bibi
                Hi @bibi, I hope, I understand that right.
                I don’t think that this is very easy. Because the script just turns the HDMI port of the RaspberryPi to on and off. So a fading effect wouldn’t be quite easy I think
                  bibi @Beh
                  @Beh i understand this. No problem and thx for reply! :)
                    shashank @bibi
                    @bibi hi can anyone help me with screenshots the file path where to enter the below commands to start it at boot time
                    cp ./pir_sensor.service /lib/systemd/system
                    systemctl daemon-reload
                    systemctl start pir_sensor.service
                      bibi @shashank
                      @shashank hi! unfortunately you will not find the cmd line in the github to enable the service at boot time. As far as i have checked, the systemd should already run at boot but for strange reasons it was not the case for me. Therefore, i had to issue the command : sudo systemctl enable pir_sensor.service
                      good luck!
                      • BehB Offline
                        Beh
                        Ok, maybe I forgot that in the readme file, or it worked straghtaway on my Pi.
                        I’m going to add sudo systemctl enable pir_sensor.service to the readme file!
                        thanks for the hint :)
