    Independent display controller based on PIR sensor.
    14 Posts 4 Posters 15.5k Views 6 Watching
      Beh
      Example configurations for wiring are shown here:
      http://www.raspberrypi-spy.co.uk/2013/01/cheap-pir-sensors-and-the-raspberry-pi-part-1/
      and here:
      https://www.raspberrypi.org/learning/parent-detector/worksheet/
      I can’t really tell you the jumper and knob configurations, because I’m using a simple sensor like this:
      https://www.amazon.de/Keyestudio-Pyroelektrische-Infrarot-Bewegungssensor-Bewegungs-Sensor-Arduino/dp/B01GCRQJ0Y/ref=sr_1_9?ie=UTF8&qid=1478275900&sr=8-9&keywords=PIR+sensor
      Maybe you look in the PIR HOWTO thread or ask a question there:
        bibi @Beh
        @Beh i see thx! maybe it’s better to use your one to somehow bypass these settings which are a bit frustrating. i did’t really get the systemd option (i am new) but as i understood it’s like a crontab, correct?
          Beh @bibi
          @bibi No, it’s more like having it added to the autostart (like on windows). Then it’s running as a service in the background, which can be controlled via systemd’s systemctl command.
            bibi
            hi @Beh ! unfortunately your module is not working for me :( could you please help me to figure out why? i have bought the same PIR sensor and plug it in the gpio 14 (physical pin 8) thx!
              bibi
              it’s solved ;-) thx anyway
                bibi
                @beh hi! i was wondering if there was an easy way to add a fading effect when the mirror goes to sleep and wake up? would be interesting in this as well? thx
                  Beh @bibi
                  Hi @bibi, I hope, I understand that right.
                  I don’t think that this is very easy. Because the script just turns the HDMI port of the RaspberryPi to on and off. So a fading effect wouldn’t be quite easy I think
                    bibi @Beh
                    @Beh i understand this. No problem and thx for reply! :)
                      shashank @bibi
                      @bibi hi can anyone help me with screenshots the file path where to enter the below commands to start it at boot time
                      cp ./pir_sensor.service /lib/systemd/system
                      systemctl daemon-reload
                      systemctl start pir_sensor.service
                        bibi @shashank
                        @shashank hi! unfortunately you will not find the cmd line in the github to enable the service at boot time. As far as i have checked, the systemd should already run at boot but for strange reasons it was not the case for me. Therefore, i had to issue the command : sudo systemctl enable pir_sensor.service
                        good luck!
                          Beh
                          Ok, maybe I forgot that in the readme file, or it worked straghtaway on my Pi.
                          I’m going to add sudo systemctl enable pir_sensor.service to the readme file!
                          thanks for the hint :)
                            McSorley
                            Sounds more effective than mine. I set an infinite loop to check for motion every second and if no motion is detected for 600 seconds the display goes to sleep.
