    Application not starting when OpenGL is enabled
    33 Posts 7 Posters 17.7k Views 6 Watching
      Anthony Project Sponsor @dazza120
      @dazza120 I don’t want to make it look better. Just to reduce the size of the module. Thank you anyway for your reply. I’ll message the Dev.
        rts58 @Anthony
        @anthony Hi, I found this post maybe it will help? Also, custom.css is for all modules is in the css directory.
        @strawberry-3-141 said in MMM-forecast-io -- Localized up to the minute weather:
        .MODULENAME {
          transform: scale(0.5, 0.5);
        if you replace modulename with your actual module name, this should give you a height and with of 50% of the actual size
          Anthony Project Sponsor @rts58
          @rts58 That worked. Thank you very much.
          • 4 / 4
